Jeux
Installer Steam sur sa Mageia
Dernière mise à jour : 18/08/2024 à 10h02
Requis
installation_steam
Ou en terminal :
urpmi steam
Steam
/home/$user/.steam/
Et vos jeux :
steam_2024
nvidia_allow_flipping
Si vous avez une carte graphique AMD
A compléter.
sysctl --system
[root@localhost ~]# sysctl --system
* Applique /usr/lib/sysctl.d/30-tracker.conf …
fs.inotify.max_user_watches = 65536
* Applique /usr/lib/sysctl.d/50-default.conf …
kernel.sysrq = 16
kernel.core_uses_pid = 1
net.ipv4.conf.default.rp_filter = 2
sysctl: change la clé « net.ipv4.conf.all.rp_filter »: Argument invalide
net.ipv4.conf.default.accept_source_route = 0
sysctl: change la clé « net.ipv4.conf.all.accept_source_route »: Argument invalide
net.ipv4.conf.default.promote_secondaries = 1
sysctl: change la clé « net.ipv4.conf.all.promote_secondaries »: Argument invalide
net.ipv4.ping_group_range = 0 2147483647
net.core.default_qdisc = fq_codel
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
fs.protected_regular = 1
fs.protected_fifos = 1
* Applique /usr/lib/sysctl.d/50-pid-max.conf …
kernel.pid_max = 4194304
* Applique /etc/sysctl.d/51-alt-sysrq.conf …
kernel.sysrq = 1
* Applique /etc/sysctl.d/51-drakx.conf …
net.ipv4.conf.all.rp_filter = 1
net.ipv4.tcp_window_scaling = 1
net.ipv4.tcp_timestamps = 1
net.ipv4.conf.all.log_martians = 1
net.ipv4.icmp_echo_ignore_all = 0
net.ipv4.icmp_echo_ignore_broadcasts = 0
net.ipv4.icmp_ignore_bogus_error_responses = 1
* Applique /usr/lib/sysctl.d/97-kde-baloo-filewatch-inotify.conf …
fs.inotify.max_user_watches = 524288
* Applique /etc/sysctl.d/99-sysctl.conf …
vm.max_map_count = 1048576
[root@localhost ~]# cat /proc/sys/vm/max_map_count
1048576
sysctl --system
sysctl -a | grep split
Quelques liens utiles
