Utiliser Mageia
Conky-conkyrc-scripts-partie 4 - conky 1.10 et +
Dernière mise à jour : 25/04/2023 à 11h09
Chronographe
conkyrc
conky.config = {
    background = true,
    use_xft = true,
    font = 'hooge 05_53:size=6',
    xftalpha = 1,
    update_interval = 1.0,
    total_run_times = 0,
        net_avg_samples = 2,
    own_window = true,
--own_window_color 000000
    own_window_type = 'normal',
    double_buffer = true,
        maximum_width = 320,
    text_buffer_size = 2048,
    draw_shades = false,
    draw_outline = false,
    draw_borders = false,
    draw_graph_borders = false,
    default_color = 'white',
    alignment = 'top_right',
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
    cpu_avg_samples = 2,
    override_utf8_locale = true,
    imlib_cache_size = 10000,
    stippled_borders = 5,
-- Couleurs
    default_color         = '#ffffff',      --ffd579
    default_shade_color   = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600  sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600  sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600  sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600  sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600  sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600  sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600  sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '18p' $HOME/1_accuweather/first_days}°C
conkyrc1 (pour le deuxième lua)
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
cups.lua
--                  Cups and Saucers
--                               Lua conky script
--  author  : Abu Yahya
--  license : Distributed under the terms of GNU GPL v3
--  30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
    name='time',                   arg='%I',                    max_value=12,
    x=170,                         y=170,
    cup_radius=35,
    cup_wall_thickness=90,
    cup_bg_clr=0xffffff,           cup_bg_alpha=0.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=0.0,
    handle_length=70,              handle_circ=5,
    handle_fg_clr=0xFFFFFF,        handle_fg_alpha=0.0, --1.0
    graduation_radius=124,
    graduation_thickness=8,        graduation_mark_circ=1.5,
    graduation_mark_angle=30,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.5,
    saucer_thickness=6,            thick_saucer_circ=11/12,
    saucer_radius=135,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.0,
    inner_saucer=true,
    txt_weight=0,                  txt_size=8.0,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.0,
    caption='',                    caption2='',
    name='time',                   arg='%H',                    max_value=12,
    x=170,                         y=170,
    cup_radius=2.5,
    cup_wall_thickness=3,
    cup_bg_clr=0xffffff,           cup_bg_alpha=1.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=1.0,
    handle_length=40,              handle_circ=4,
    graduation_radius=127,
    graduation_thickness=1,        graduation_mark_circ=0.5,
    graduation_mark_angle=3,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.0,
    inner_saucer=true,
    name='time',                   arg='%M',                    max_value=60,
    x=170,                         y=170,
    cup_radius=55,
    cup_wall_thickness=120,
    graduation_radius=123,
    graduation_thickness=10,       graduation_mark_circ=2.5,
    graduation_mark_angle=90,
    handle_length=110,              handle_circ=3,
    saucer_radius=155,             thin_saucer_circ=11/12,
    name='time',                   arg='%S',                    max_value=60,
    x=170,                         y=170,
    cup_radius=59,
    handle_length=118,              handle_circ=1,
    graduation_radius=125,
    graduation_thickness=6,        graduation_mark_circ=0.5,
    graduation_mark_angle=6,
    saucer_thickness=5,           thick_saucer_circ=1,
    saucer_radius=145,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.4,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.4,
    name='cpu',                    arg='cpu0',                  max_value=100,
    x=170,                         y=100,
    cup_radius=20,
    cup_wall_thickness=40,
    cup_start_angle=0,
    cup_bg_clr=0xFFFFFF,           cup_bg_alpha=0.0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=1,
    caption=' CPU ',               caption2=' %',
    graduation_radius=25,
    graduation_thickness=3,        graduation_mark_circ=2,
    graduation_mark_angle=36,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.6,
    saucer_thickness=3,            thick_saucer_circ=0.85,
    saucer_radius=30,              thin_saucer_circ=0.85,
    saucer_fg_clr=0xFFFFFF,       saucer_fg_alpha= 0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.5,
    inner_saucer=true,
    name='freq_g',                 arg='/',                  max_value=5,
    x=170,                         y=100,
    cup_radius=12,
    cup_wall_thickness=23,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='',           caption2=' GHz',
    graduation_thickness=4,        graduation_mark_circ=4,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.0,
    saucer_thickness=3,            thick_saucer_circ=0.75,
    saucer_radius=35,              thin_saucer_circ=0.75,
---------------1/2
    name='downspeedf',                arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    caption='E. ',             caption2='',
    inner_saucer=true,
    name='upspeedf',               arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_wall_thickness=27,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='S ',             caption2='',
    saucer_radius=35,              thin_saucer_circ=0.85,
------------------2/3
    name='fs_used_perc',           arg='/home',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption=' FS /: ',             caption2=' %',
    inner_saucer=true,
    name='fs_used_perc',           arg='/',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.8,
    caption=' FS H: ',             caption2=' %',
end
-- displays cups and saucers
     max_value = data['max_value']
     x, y = data['x'], data['y']
     caption = data['caption']
     caption2 = data['caption2']
     if xtxt ==nil then xtxt=0 end
     if ytxt ==nil then ytxt=0 end
      if total_angle < 0 then
      else
      end
    end
--cup centre background
  if cup_bg_alpha >0   then
    else
    end
    cairo_stroke(display)
  end
--cup wall fg
  if cup_fg_alpha > 0 then
    else
    end
  end
-- cup handle
  if handle_fg_alpha>0 then
    local stop_handle = (cup_sector_angle * value) +  (handle_circ*0.5)
    else
    end
  end
--saucers
---thick saucer
      then
    if value < (max_value/2)
    end
    else
    end
    --thin saucer
      if inner_saucer == true
      end
    else
    end
   end
--saucer mark
    else
    end
    end
--graduation mark
        local start_arc_grad = 0
        local stop_arc_grad = 0
    local i = 0
        else
        end
            i = i + 1
        end
    end
-- text
  if txt_fg_alpha>0 then
    cairo_stroke (display)
  end
end
        local str, value = '', 0
            str = conky_parse(str)
    else
            value = tonumber(str)
        end
    end
    end
end
function conky_main()
    if conky_window == nil then
        return
    end
    if update_num > 5 then
    end
    cairo_surface_destroy(cs)
    cairo_destroy(display)
end
clocks_rings.lua
    lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
        name='time',
        arg='%I',
        max=12,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=133,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%M',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=140,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%S',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=147,
        thickness=4,
        start_angle=0,
        end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
    -- Draw background ring
    cairo_stroke(cr)
    -- Draw indicator ring
    cairo_stroke(cr)
end
    local xh,yh,xm,ym,xs,ys
    secs=os.date("%S")
    mins=os.date("%M")
    hours=os.date("%I")
    secs_arc=(2*math.pi/60)*secs
    -- Draw hour hand
    cairo_move_to(cr,xc,yc)
    cairo_line_to(cr,xh,yh)
    cairo_set_line_width(cr,5)
    cairo_stroke(cr)
    -- Draw minute hand
    cairo_line_to(cr,xm,ym)
    cairo_set_line_width(cr,3)
    cairo_stroke(cr)
    -- Draw seconds hand
    if show_seconds then
        cairo_line_to(cr,xs,ys)
        cairo_stroke(cr)
    end
end
function conky_clock_rings()
        local str=''
        local value=0
        str=conky_parse(str)
        value=tonumber(str)
        pct=value/pt['max']
        draw_ring(cr,pct,pt)
    end
    local cr=cairo_create(cs)
    update_num=tonumber(updates)
    if update_num>5 then
        end
    end
end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
capture_deecran_2019_06_08_09_26
conky lune
le pack @ prendre ici
Le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Monofur:bold:size=7',
own_window = true,
own_window_hints = 'undecorated,skip_taskbar,skip_pager,below',
draw_graph_borders = true,
stippled_borders = 8,
border_inner_margin = 4,
alignment = 'top_left',
minimum_width = 500,
minimum_height = 500,
gap_x = 130,
gap_y = 230,
no_buffers = false,
uppercase = false,
use_spacer = right,
text_buffer_size = 8192,
imlib_cache_size = 16384,
default_outline_color = '000000',
color1 = '000000',
color2 = '000000',
color3 = '828200',
color4 = '323200',
lua_load = '~/.conky/lua/image.lua',
conky.text = [[
${font Monofur:bold:size=12}${color5}${voffset -9}Phases de la lune ${color}${texeci 9500 bash $HOME/4_Moon/moon_MoonGiant}
${alignc 40}${color5}${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3}'`}${color}${font}
${lua fDrawImage $HOME/4_Moon/-2.png 10 65 60 60}
${lua fDrawImage $HOME/4_Moon/-1.png 80 65 60 60}
${lua fDrawImage $HOME/4_Moon/0.png 157 35 90 90}
${lua fDrawImage $HOME/4_Moon/1.png 265 65 60 60}
${lua fDrawImage $HOME/4_Moon/2.png 340 65 60 60}
${voffset 40}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${alignc 60}${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}
${voffset -42}${color5}${goto 15}${color5}${execi 3600 echo `date --date="-2 day" | awk '{print $2" "$3}'`}\
${goto 87}${execi 3600 echo `date --date="-1 day" | awk '{print $2" "$3}'`}\
${goto 347}${execi 3600 echo `date --date="+2 day" | awk '{print $2" "$3}'`}\
${goto 272}${execi 3600 echo `date --date="+1 day" | awk '{print $2" "$3}'`}${color}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${goto 15}${execpi 600 sed -n '13p' $HOME/4_Moon/raw-fr}\
${goto 87}${execpi 600 sed -n '21p' $HOME/4_Moon/raw-fr}\
${goto 272}${execpi 600 sed -n '29p' $HOME/4_Moon/raw-fr}\
${goto 347}${execpi 600 sed -n '37p' $HOME/4_Moon/raw-fr}
${alignc 40}${color5}Details pour ${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3" "$6}'`}${color}
Visibilité: ${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}${goto 250}Age: ${execpi 600 sed -n '5p' $HOME/4_Moon/raw} J
Angle du Soleil: ${execpi 600 sed -n '2p' $HOME/4_Moon/raw} ° ${goto 250}Angle de Lune: ${execpi 600 sed -n '6p' $HOME/4_Moon/raw} °
Distance du Soleil: ${execpi 600 sed -n '3p' $HOME/4_Moon/raw} kms${goto 250}Distance de la Lune: ${execpi 600 sed -n '4p' $HOME/4_Moon/raw} kms
${alignc 50}${color5}Position de la Lune${color}\
${lua fDrawImage $HOME/4_Moon/rise.png  0 294 400 130}\
${lua fDrawImage $HOME/4_Moon/0.png    45 370 30 30}\
${lua fDrawImage $HOME/4_Moon/0.png   325 370 30 30}\
${Lua fDrawImage $HOME/4_Moon/0.png   185 296 30 30}
#!/bin/bash
#function: moonrise_set
moonrise_set () {
    case "$1" in
         "FirstQuarter")
            echo "Noon/Midnight"
            cp $HOME/4_Moon/riseicons/rise_FirstQuarter.png $HOME/4_Moon/rise.png
         "FullMoon")
            echo "6PM/6AM"
            cp $HOME/4_Moon/riseicons/rise_FullMoon.png $HOME/4_Moon/rise.png
         "LastQuarter")
            echo "Midnight/Noon"
            cp $HOME/4_Moon/riseicons/rise_LastQuarter.png $HOME/4_Moon/rise.png
         "NewMoon")
            echo "6AM/6PM"
            cp $HOME/4_Moon/riseicons/rise_NewMoon.png $HOME/4_Moon/rise.png
         "WaningCrescent")
            echo "3AM/3PM"
            cp $HOME/4_Moon/riseicons/rise_WaningCrescent.png $HOME/4_Moon/rise.png
         "WaningGibbous")
            echo "9PM/9AM"
            cp $HOME/4_Moon/riseicons/rise_WaningGibbous.png $HOME/4_Moon/rise.png
         "WaxingCrescent")
            echo "9AM/9PM"
            cp $HOME/4_Moon/riseicons/rise_WaxingCrescent.png $HOME/4_Moon/rise.png
         "WaxingGibbous")
            echo "3PM/3AM"
            cp $HOME/4_Moon/riseicons/rise_WaxingGibbous.png $HOME/4_Moon/rise.png
            echo "Unavailable"
         esac
kill -STOP $(pidof conky)
#put your hemisphere here: north or south
hemisphere=north
wget -O $HOME/4_Moon/raw "http://www.moongiant.com/phase/today"
rm $HOME/4_Moon/*.png
sed -i -e '/^ *$/d' -e 's/^ *//g' $HOME/4_Moon/raw
sed -i '/var jArray=\|"todayMoonContainer"\|"moonNotToday"/!d' $HOME/4_Moon/raw
sed -i -e '/var jArray/s/","/\n/g' -e 's/<span>\|<b>\|<\\\/span>\|<\\\/b>\|\\n//g' /$HOME/4_Moon/raw
sed -i -e '/var jArray/d' -e 's/^.*\:\[\"//g' /$HOME/4_Moon/raw
sed -i -e 's/"\]};//g' -e 's/^.*today_phase\///g' -e 's/\.jpg.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/^small\///g' -e 's/\.png.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/Illumination: \|Sun Angle: \|Sun Distance: \|Moon Distance: \|Moon Age: \|Moon Angle: //g' -e '43d' /$HOME/4_Moon/raw
#September 30-October 1 fix
for (( i=11; i<=35; i+=8 ))
    do
        if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "September 30" ]]; then
            line=$((i+7))
            sed -i "${line}s/^.*$/Waning Crescent/" /$HOME/4_Moon/raw
        fi
        if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "October 1" ]]; then
            line=$((i+7))
            sed -i "${line}s/^.*$/New Moon/" /$HOME/4_Moon/raw
        fi
    done
today_phase=$(sed -n 8p /$HOME/4_Moon/raw| awk -F "," '{print $2}'| sed 's/ //')
if [[ $today_phase == "September 30" ]]; then
            sed -i '7s/^.*$/Waning Crescent/' /$HOME/4_Moon/raw
            sed -i '10s/^.*$/Phase: Waning Crescent/' /$HOME/4_Moon/raw
fi
if [[ $today_phase == "October 1" ]]; then
            sed -i '7s/^.*$/New Moon/' /$HOME/4_Moon/raw
            sed -i '10s/^.*$/Phase: New Moon/' /$HOME/4_Moon/raw
fi
phase=$(sed -n 7p $HOME/4_Moon/raw|sed 's/ //')
mrise_mset=$(moonrise_set $phase)
sed -i 7a$(moonrise_set $phase) /$HOME/4_Moon/raw
#Day before Yesterday
img_in=$(sed -n 44p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-2.png
#Yesterday
img_in=$(sed -n 45p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-1.png
#Today
img_in=$(sed -n 46p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/0.png
#Tomorrow
img_in=$(sed -n 47p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/1.png
#Day after Tomorrow
img_in=$(sed -n 48p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/2.png
## English to French
cp $HOME/4_Moon/raw $HOME/4_Moon/raw-fr
if [[ -s $HOME/4_Moon/raw-fr ]]; then
        sed -i -e 's/Full Moon/Pleine Lune/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waning Gibbous/Gibeuse décroissante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waxing Gibbous/Gibeuse croissante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waxing Crescent/Lune Montante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/First Quarter/Premier Quartier/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Last Quarter/Dernier Quartier/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waning Crescent/Lune Déscendante/' /$HOME/4_Moon/raw-fr
fi
kill -CONT $(pidof conky)
capture_deecran_2019-07-20_09-40-31
Diamond
(Pour la météo il faut toujours le pack de Théo accuweather)
un de mes vieux ensemble de conky mis en version 1.10
pas de lecteurs jouant
capture_deecran_2019-09-29_11-16-03
avec audacious
capture_deecran_2019-09-29_11-17-10
avec radiotray-ng
capture_deecran_2019-09-29_11-15-05
conkyrcs
time & weather
conky.config = {
    background = true,
    use_xft = true,
    font = 'Liberation Sans:size=9',
    xftalpha = 1,
    own_window = true,
    minimum_width = 470, minimum_height = 170,
        maximum_width = 470,
    gap_x = 30,
    gap_y = 10,
    no_buffers = true,
    uppercase = false,
-- Taille des pointillés
-- Couleurs
    default_color = '#ffffff',--ffd579
conky.text = [[
${execi 180 bash $HOME/1_accuweather/1_accuweather -f}
${font Liberation Sans:size=26}${alignc 20}${time %a %d %b %H:%M}${font}
${goto 70}----------------------------------------------------------------------------
${goto 30}Aujourdh'ui ${goto 110}demain\
${goto 190}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 270}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}${voffset -14}
${goto 360}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${font conkyweather:size=30}${voffset -30}
${goto 40}${execi 600  sed -n '601p' $HOME/1_accuweather/daily_forecast}\
${goto 110}${execi 600  sed -n '602p' $HOME/1_accuweather/daily_forecast}\
${goto 190}${execi 600  sed -n '603p' $HOME/1_accuweather/daily_forecast}\
${goto 270}${execi 600  sed -n '604p' $HOME/1_accuweather/daily_forecast}\
${goto 360}${execi 600  sed -n '605p' $HOME/1_accuweather/daily_forecast}${font}
${goto  40}${texeci 600 sed -n '68p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '47p' $HOME/1_accuweather/daily_forecast}°\
${goto 110}${texeci 600 sed -n '108p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '87p' $HOME/1_accuweather/daily_forecast}°\
${goto 190}${texeci 600 sed -n '148p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '127p' $HOME/1_accuweather/daily_forecast}°\
${goto 270}${texeci 600 sed -n '188p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '167p' $HOME/1_accuweather/daily_forecast}°\
${goto 360}${texeci 600 sed -n '228p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '207p' $HOME/1_accuweather/daily_forecast}°\
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 180 }
cpu
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    minimum_width = 470, minimum_height = 280,
    gap_x = 00,
    gap_y = 210,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[
${voffset 30}${offset 50}Cpu1:${color DDF2FF} ${offset 3}${cpu cpu1}%${alignr 90}${voffset -5}${color #DBDBDB}${cpugraph cpu1 20,240 f1f1f1 DBDBDB}${color}
${voffset -3}${offset 50}CPU Step: ${alignr 80}${color DDF2FF}${freq_g} GHz${color}
${voffset 12}${offset 50}Cpu2:${color DDF2FF} ${offset 3}${cpu cpu2}%${alignr 90}${voffset -9}${color #DDF2FF}${cpugraph cpu2 20,240 f1f1f1 DBDBDB}${color}
${voffset -5}${alignc 10}---------------------------------------------------------------------------------
${voffset 15}${offset 50}RAM: ${alignr 80} $mem/${color #DDF2FF}$memmax${color}
${offset 50}${color #DDF2FF}${membar 5,340}${color}
${offset 50}Swap: ${alignr 80} $swap / ${color #DDF2FF}$swapmax${color}
${offset 50}${color #DDF2FF}${swapbar 5,340}${color}
${offset 50}ROOT:${color #DDF2FF} ${alignr 80} ${fs_free /} / ${fs_size /}
${offset 50}${fs_bar 5,340 /}${color}
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 439 270}
network
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 30,
    gap_y = 470,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[
${offset 25}${font Liberation Sans:size=11}SSID:${font} ${wireless_essid wlo1} ${goto 190}${font Liberation Sans:size=11}Sortant:${font} ${upspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Bitrate:${font} ${wireless_bitrate wlo1} ${goto 190}${font Liberation Sans:size=11}Entrant:${font} ${downspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Local:${font} ${addr wlo1} ${goto 190}${font Liberation Sans:size=11}Signal:${font} ${wireless_link_qual_perc wlo1}%
${lua fDrawImage ~/.conky/diamond/pix/bg1.png  0 0 440 102}
${if_match "${wireless_link_qual_perc wlo1}"<"1"} ${lua fDrawImage ~/.conky/diamond/pix/nonetwork.png  300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"20"}${lua fDrawImage ~/.conky/diamond/pix/networklow.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"50"}${lua fDrawImage ~/.conky/diamond/pix/networkmid.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"80"}${lua fDrawImage ~/.conky/diamond/pix/wlan80.png     300 25 45 45}${else}
${lua fDrawImage ~/.conky/diamond/pix/networkhigh.png 300 25 45 45}${endif}${endif}${endif}${endif}
audacious
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 30,
    gap_y = 580,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[${if_running audacious}
${execi 3 ~/.conky/audacious/scripts/cover.sh}
${voffset -40}${font GE Inspira :size=12}
${goto 160}${execi 3 audtool current-song-tuple-data artist}${font}
${goto 160}${execi 3 audtool current-song-tuple-data title}
${goto 160}${execi 3 audtool current-song-tuple-data album}
${voffset 10}${goto 160}${execi 1 audtool current-song-output-length}  ${goto 358}${execi 1 audtool current-song-length}\
${goto 184}${execbar 2, 168 expr 100 \* $(audtool --current-song-output-length-seconds) \/ $(audtool --current-song-length-seconds)}
${lua fDrawImage ~/.conky/audacious/audacious.png 44 14 68 70}
${else}
${if_running radiotray-ng}
${texeci 3 ~/.conky/radiotrayng/pochette.sh}${lua fDrawImage ~/.conky/diamond/pix/bg1.png  0 0 440 102}
${voffset -36}${alignc -80}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font
${voffset 33}${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
             ${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"}            ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 222 32 50 50}         ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 228 28 35 35}    ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"}        ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 230 29 35 35}      ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"}           ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 222 32 45 45}        ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"}${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 184 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "radio swiss pop"}${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 244 30 35 35}       ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "rfm"}            ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 224 35 45 45}         ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 30 10 78 78}
${else}
${lua fDrawImage ~/.conky/diamond/pochette.png 40 14 68 70}${endif}
${else}
${endif}
Conky radiotray-ng 2021 avec recherche de pochettes
le conkyrc
conky.config = {
    background = true,
    use_xft = true,
    font = 'Liberation Sans:size=7',
    xftalpha = 1,
    own_window = true,
    minimum_width = 400, minimum_height = 100,
--maximum_width 200
    gap_x = 780,
    gap_y = 50,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[
${texeci 8 ~/.conky/radiotrayng/pochette.sh}
${voffset -4}${alignc -90}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font ${goto 340}Vol: ${exec amixer get Master | awk 'NR==5{print $4}' | tr -d {[]}}
${voffset 33}${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
             ${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${lua fDrawImage $HOME/.conky/radiotrayng/images/case.png 0 0 410 108}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"}                 ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 240 32 50 50}         ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"}      ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 248 28 35 35}    ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"}             ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 250 29 35 35}      ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"}                ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 240 32 45 45}        ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"}     ${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 204 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Radio Swiss Pop"}     ${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 250 30 35 35}       ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RFM"}                 ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 244 35 45 45}         ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "80's & 90's hits"}    ${lua fDrawImage ~/.conky/radiotrayng/logos/80-90.png 248 28 35 35}       ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Best Hits Radio 80's"}${lua fDrawImage ~/.conky/radiotrayng/logos/80.png 248 28 35 35}          ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${else}${lua fDrawImage ~/pochette.png 24 14 68 70}${endif}
#${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${lua fDrawImage ~/.conky/radiotrayng/images/stop.png 115 31 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/prev.png 100 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/play.png 115 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/next.png 130 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/pause.png 115 59 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/bar.png 98 78 48 4}
${lua fDrawImage ~/.conky/radiotrayng/images/grip.png 115 78 5 5}
${lua fDrawImage ~/.conky/radiotrayng/images/1-play.png 155 15 10 10}
${voffset -800}
pochette.sh
#!/bin/bash
#créé par loutch
#2018-12-27 modifier par TeoBigusGeekus et loutch pour radiotray-ng et conky 1.10
#2021-02-20 modifier par nic80 et loutch
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep artist |sed 's/^.*" \: "//' |sed 's/",.*$//' > artiste_titre.txt
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep title  |sed 's/^.*" \: "//' |sed 's/",.*$//' >> artiste_titre.txt
titre=$(cat artiste_titre.txt)
lynx --source -useragent="Googlebot-Image/1.0" "www.google.com/search?q=$titre\&tbm=isch" | perl -pe 's!.*<img .* src="([^"]*)".*!$1!' > lienMiniaturefile
sed -i 's/^.* http\:/http\:/' lienMiniaturefile
sed -i '/gstatic/!d' lienMiniaturefile
lienMiniature=$(cat lienMiniaturefile)
lynx -dump "$lienMiniature" > miniatureGoogleImage
capture_deecran_2021-07-03_09-15-10
Météo +Lune
Il faut les deux packs de TeoBigusGeekus du forum Bunsenlabs et le pack meteo+lune 4
Accuweather
https://gitlab.com/teobigusgeekus/Accuweather_conky_script.git
Moongiant
https://gitlab.com/teobigusgeekus/Moongiant_conky_script.git
meteo+lune4
https://www.gnome-look.org/p/1155399/
le conkyrc
conky.config ={
no_buffers = true,
imlib_cache_size = 0,
cpu_avg_samples = 1,
minimum_width = 410, minimum_height = 981,
maximum_width = 430,
gap_x = 5,
gap_y = 0,
border_inner_margin = 0,
border_outer_margin = 0,
background = true,
own_window = true,
own_window_hints = 'undecorated,below,skip_taskbar,skip_pager,',
use_xft = true,
xftalpha = 1,
font = 'CorporateMonoExtraBold:size=10',
uppercase = false,
default_color = '#FFFFFF',
default_shade_color =  '#000000',
color1 = 'b9b4b0', -- gris rosé
color2 = 'CA0000', -- rouge
color3 = '386fd5', -- bleu argent
color6 = 'b10ab3', -- mauve
color7 = 'f3ec1f', -- jaune
color8 = 'CCCCCC',
color9 = 'BBBBBB',
template1 = [[${font CorporateMonoExtraBold:size=\1}]],
template2 = [[${font Folks-Heavy:style=Bold:size=\1}]],
template3 = [[${font Liberation Sans:size=\1}]],
conky.text = [[
${texeci 900 bash $HOME/Accuweather_conky_script/accuweather -f2015} ${texeci 3600 bash $HOME/Wunderground_conky_script/wunderground}${texeci 9500 bash $HOME/Moongiant_conky_script/moon_MoonGiant}
${voffset 15}${alignc}${color1}Sarreguemines
${alignc}${color1}${execi 600 sed -n '4p' $HOME/Accuweather_conky_script/curr_cond}
${voffset 10}${goto 120}${color3}Humidité:            ${alignr 10}${color1}${texeci 600 sed -n '7p' $HOME/Accuweather_conky_script/curr_cond}
             ${goto 120}${color3}Pression:            ${alignr 10}${color1}${texeci 600 sed -n '8p' $HOME/Accuweather_conky_script/curr_cond | awk '{print $2}'} mbar
             ${goto 120}${color3}Indice UV:           ${alignr 10}${color1}${texeci 600 sed -n '9p' $HOME/Accuweather_conky_script/curr_cond}
             ${goto 120}${color3}Converture nuageuse: ${alignr 3}${color1}${texeci 600 sed -n '10p' $HOME/Accuweather_conky_script/curr_cond}
             ${goto 120}${color3}Point de rosée:      ${alignr 10}${color1}${texeci 600 sed -n '12p' $HOME/Accuweather_conky_script/curr_cond}°C
             ${goto 120}${color3}Visibilité:          ${alignr 10}${color1}${execi 600 sed -n '13p' $HOME/Accuweather_conky_script/curr_cond}s
             ${goto 120}${color3}Lever/Coucher:       ${alignr 10}${color1}${execi 600 sed -n '14p' $HOME/Accuweather_conky_script/curr_cond} / ${execi 600 sed -n '15p' $HOME/Accuweather_conky_script/curr_cond}
         ${goto 120}${color3}Vent:                ${alignr 10}${color1}${execi 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond} ${texeci 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond > $HOME/Accuweather_conky_script/vent}
             ${goto 120}${color3}Vitesse:             ${alignr 10}${color1}${execi 600 sed -n '6p' $HOME/Accuweather_conky_script/curr_cond}
${voffset -90}${goto 30}${color1}${template1 14}T: ${execi 600 sed -n '2p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 10} ${goto 30}${color1}${template1 14}R: ${execi 600 sed -n '3p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 90}${template1 9}
${goto 100}Aujourd'hui ${goto 280}Demain
${goto 120}${color3}${texeci 600 sed -n  '5p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${texeci 600 sed -n  '4p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 280}${color3}${execpi 600 sed -n '12p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '11p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 80}${scroll 16 ${execpi 600 sed -n  '6p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 240}${scroll 16 ${execpi 600 sed -n '13p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 60}
 ${goto 70}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 195}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}\
${goto 320}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
 ${goto 70}${color3}${execpi 600 sed -n '19p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '18p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 195}${color3}${execpi 600 sed -n '26p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '25p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 320}${color3}${execpi 600 sed -n '33p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '32p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 55}${scroll 12 ${execpi 600 sed -n '20p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 180}${scroll 12 ${execpi 600 sed -n '27p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 305}${scroll 12 ${execpi 600 sed -n '34p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 75}${alignc}${color1}${template1 15}Calendrier Lunaire${font}
${voffset -5}${alignc}${color2}${template1 9}( Hémisphère Nord en GMT+1 Paris )${font}
${offset 40}
${alignc}${color3}Lever/Coucher:${color2}${template7 9}( Heure locale )$font
${alignc} ${template3 11}↑ ${template1 10}${execi 600 sed -n '18p' $HOME/Accuweather_conky_script/curr_cond} ${template3 11}↓ ${template1 10}${execi 600 sed -n '19p' $HOME/Accuweather_conky_script/curr_cond} = ${execi 600 sed -n '20p' $HOME/Accuweather_conky_script/curr_cond}
${alignc}${color3}Phase ${color1}${execpi 600 sed -n '1p' $HOME/Wunderground_conky_script/lune}
${template2 9}${voffset 20}
${goto 30}Visibilité: ${execpi 600 sed -n '23p' $HOME/Moongiant_conky_script/raw}                       ${goto 260}Angle: ${execpi 600 sed -n '25p' $HOME/Moongiant_conky_script/raw} °
${goto 30}Age: ${execpi 600 sed -n '24p' $HOME/Moongiant_conky_script/raw | awk '{print $1}'} Jour(s)   ${goto 260}Dist.: ${execpi 600 sed -n '26p' $HOME/Moongiant_conky_script/raw}s
${voffset 80}${alignc}${color1}${template1 15}Éphéméride ${font}
${alignc}${color1}Saint(e) du jour
${alignc}${color2}${texeci 1000 wget -O - -q  http://fetedujour.fr/  --user-agent="Mozilla/5.0 (Windows NT 5.1; rv:31.0) Gecko/20100101 Firefox/31.0" | grep h2 | head -1 | cut -d">" -f2 | cut -d"<" -f1 | cut -d":" -f2 }
#fond verticale
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/fond23x866.png 0 115 23 866}
#ligne rouge
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20  90 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 306 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 582 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 850 380 12}
#texte vertical
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/lateralf.png 4 125 15 851}
#icones
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_0.png 20 100 115 69}
${lua fDrawImage $HOME/Accuweather_conky_script/Wind1.png 40 220 70 70}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_1.png 100 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_2.png 260 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_3.png  45 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_4.png 170 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_5.png 295 510 90 52}
${lua fDrawImage $HOME/Wunderground_conky_script/Forecast_Images/Moon_phase.png 160 730 90 90}
capture_deecran_2021-09-26_10-29-07
Lanceur multi-lua
Avec la nouvelle syntaxe voici comment avoir un conky qui @ besoin de plusieurs scripts lua comme sur la version 1.09.
On va créer un fichier
" loader.lua" que l'on va appeler comme ceci dans le conky avant la partie conki.text=[[
lua_load = '~/chemin/du/dossier/loader.lua',
 lua_draw_hook_pre = 'loader_lua',
loader.lua
require 'cairo'
function conky_loader_lua()
usrhome = os.getenv("HOME")
    dofile (usrhome .."/.conky/olgmen/scripts/datah.lua")
    dofile (usrhome .."/.conky/olgmen/scripts/draw_bg.lua")
    dofile (usrhome .."/.conky/lua/image.lua")
    conky_widgets()
end
- dofile .......datah.lua premier lua
-dofile .........draw_bg deuxième lua
-dofile ..........image.lua troisième lua
conky_widgets est la fonction du premier lua
les deux autres lua n'ont pas de fonction donc on ne mets rien.
un autre lanceur
require 'cairo'
    dofile (usrhome .."/.conky/cronograph/scripts/clock_rings.lua")
    dofile (usrhome .."/.conky/cronograph/scripts/multi_rings.lua")
    dofile (usrhome .."/.conky/lua/draw_bg.lua")
        conky_main()
        conky_clock_rings()
end
Exemple
Un conky quatre lua .
capture_deecran_2023-04-24_09-34-43
Meteo.ch
Conkyopen-meteo prise sur le site " prevision-meteo.ch" le site est en Français .
Vous pouvez vous faire un dossier icônes avec celles du site . Chez moi ce sont celles de Vclouds .
le conkyrc :
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    own_window_transparent = false,
        own_window_argb_value = 00,
    minimum_width = 270, minimum_height = 550,
        maximum_width = 270,
    gap_x = 52,
    gap_y = 240,
    no_buffers = true,
    uppercase = false,
-- Couleurs
lua_load = '~/conky-openmeteo/Suisse/configs/loader.lua',
color1 = 'F5B800',
color2 = '00f5ff',
color3 = '828200',
color4 = '323200',
color5 = 'fdb72e',
color7 = '6495ee',
color9 = 'red',
conky.text = [[${execi 1800 bash $HOME/conky-openmeteo/Suisse/suisse.sh}
##### premier cadre #####
### ${voffset -10}${font LED_mono :style=Medium:size=52}${color 434343}${goto 36}${time %H}${goto 136}${time %M}${font LED_mono :size=20:style=Medium}${color 292929}${goto 230}${time %S}$font
#### Date ####
${voffset 72}${alignc -100}${color yellow}${font URW Chancery L :italic:size=20}${time %A %d %B %Y}${voffset -14}
${font URW Chancery L :italic:size=14}${color ffe595}Sarreguemines$color${voffset -10}
${font URW Chancery L :italic:size=30}${goto 20}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.tmp'} ° ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.tmp' > $HOME/conky-openmeteo/Suisse/barographe/temp}${voffset -60}
${font URW Chancery L :italic:size=10}${goto 220}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.wnd_dir'}
                                      ${goto 210}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.wnd_spd'} km/h
                                      ${goto 210}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.wnd_gust'} km/h ${voffset -36}
 ${goto 30}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.pressure' | cut -d'.' -f1} mb ${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.pressure' | cut -d'.' -f1 > $HOME/conky-openmeteo/Suisse/barographe/pression}
 ${goto 30}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.humidity'} % ${voffset -4}
 ${goto 30}${font Liberation Sans :size=10}↑${font URW Chancery L :italic:size=10} ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.city_info.sunrise'}\
${goto 210}${font Liberation Sans :size=10}↓${font URW Chancery L :italic:size=10} ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.city_info.sunset'}${voffset -20}
${alignc}${font URW Chancery L :italic:size=14}${color ffe595}${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.condition'}
#### aujourdh'hui + demain ########
${voffset 26}
 ${goto 60}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.tmin'}°${color}/${color9}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.tmax'}°\
${goto 200}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_1.tmin'}°${color}/${color9}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_1.tmax'}°$color
${font URW Chancery L :italic:size=10}${voffset -26}
 ${goto 40}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.condition'}\
${goto 180}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_1.condition'}
${font URW Chancery L :italic:size=14}${voffset -30}
${goto 40}Aujourd'hui\
${goto 190}Demain
 #### 3 jours suivant ########
${font URW Chancery L :italic:size=12}${voffset 20}
${goto 030}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_2.tmin'}°${color}/${color9}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_2.tmax'}°\
${goto 125}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_3.tmin'}°${color}/${color9}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_3.tmax'}°\
${goto 220}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_4.tmin'}°${color}/${color9}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_4.tmax'}°$color
${voffset -25}
${goto 020}${scroll 12 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_2.condition'}}\
${goto 115}${scroll 12 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_3.condition'}}\
${goto 210}${scroll 10 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_4.condition'}}
${voffset -25}
${goto 030}${execi 360 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 360 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 125}${execi 360 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 360 echo `date --date="3 day" | awk '{print $2}'`}\
${goto 220}${execi 360 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 360 echo `date --date="4 day" | awk '{print $2}'`}
 #### matin +midi+soir ########
${font URW Chancery L :italic:size=10}${voffset 22}
${goto 030}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."6H00".TMP2m' | awk '{printf("%d\n",$1)}'}°\
${goto 125}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."12H00".TMP2m' | awk '{printf("%d\n",$1)}'}°\
${goto 220}${color7}${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."18H00".TMP2m' | awk '{printf("%d\n",$1)}'}°$color
${voffset -25}
${goto 020}${scroll 12 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."7H00".CONDITION'}}\
${goto 115}${scroll 12 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."12H00".CONDITION'}}\
${goto 210}${scroll 12 ${execi 360 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.fcst_day_0.hourly_data."18H00".CONDITION'}}
${voffset -25}
${goto 025}Ce matin\
${goto 120}Ce midi\
${goto 215}Ce soir
${voffset -6}${alignc}${font URW Chancery L :italic:size=14} ${color ffe595}Dernière mise @ jour  ${execpi 600 sed -n '1p' $HOME/conky-openmeteo/Suisse/actualisation | cut -c1-5}
#### Affichage  utilisés dans le conky ####
${lua conky_draw_bg 20 0 98 270 450 0x000000 0.2}
${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/suite-bgv.png 000 090 273 460}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/base5.png    000 040 270 200}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/flip_bg.png  030 003 100 100}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/flip_bg.png  130 003 100 100}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/base5.png    000 260 270 076}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/base5.png    000 360 270 076}
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/base5.png    000 460 270 076}
${lua fDrawImage $HOME/conky-openmeteo/Suisse/now.png   050 096 175 120}\
#${lua fDrawImage $HOME/conky-openmeteo/Suisse/Wind1.png 220 110  45  45}
${lua fDrawImage $HOME/conky-openmeteo/Suisse/d0.png    000 205 135  90}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/d1.png    134 205 135  90}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/d2.png    000 340 070  45}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/d3.png    095 340 070  45}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/d4.png    190 340 070  45}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/h7.png    000 440 070  45}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/h12.png   095 440 070  45}\
${lua fDrawImage $HOME/conky-openmeteo/Suisse/h18.png   190 440 070  45}\
${voffset -4000}
le loader.lua "chemin @ modifier"
require 'cairo'
end
le suisse.sh
#!/usr/bin/bash
###rm $HOME/conky-openmeteo/Suisse/*.png
rm $HOME/.conky/barometr/temp
sleep 2
wget -O $HOME/conky-openmeteo/json/suisse.json "https://prevision-meteo.ch/services/json/sarreguemines"
jq --raw-output . $HOME/conky-openmeteo/json/suisse.json > $HOME/conky-openmeteo/rawdata/rawsuisse
#### temp+40 pour conky barometr ####
num1=$(sed -n 1p $HOME/conky-openmeteo/Suisse/barographe/temp)
num2=40
ans=$(bc -l <<<"$num1+$num2")
echo $ans >> $HOME/.conky/barometr/temp
#### mise à jour unklar ####
date +%T > $HOME/conky-openmeteo/Suisse/actualisation
#### rose des vents  ####
wind_direction=$(jq --raw-output '.current_condition.wnd_dir' $HOME/conky-openmeteo/rawdata/rawsuisse)
if [[ $wind_direction == "S" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"02.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "South" ]]; then
elif [[ $wind_direction == "SSO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"03.png" $HOME/conky-openmeteo/Suisse/wind1.png
elif [[ $wind_direction == "SO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"04.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "OSO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"05.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "O" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"06.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "West" ]]; then
elif [[ $wind_direction == "ONO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"07.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "NO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"08.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "NNO" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"09.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "N" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"10.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "North" ]]; then
elif [[ $wind_direction == "NNE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"11.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "NE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"12.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "ENE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"13.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "E" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"14.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "East" ]]; then
elif [[ $wind_direction == "ESE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"15.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "SE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"16.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "SSE" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"17.png" $HOME/conky-openmeteo/Suisse/Wind1.png
elif [[ $wind_direction == "Variable" ]]; then
    cp $HOME/conky-openmeteo/Suisse/vent/"00.png" $HOME/conky-openmeteo/Suisse/Wind1.png
fi
##### maintenant condition icône ######
icon=$(jq --raw-output '.current_condition.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
if [[ $icon == "Ensoleillé" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Ciel voilé" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Eclaircies" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Faiblement nuageux" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Fortement nuageux" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Nuit nuageuse" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Pluie faible" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Nuit claire" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Averses de neige faible" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Nuit légèrement voilée" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Neige faible" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Pluie modérée" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Averses de pluie faible" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Faibles passages nuageux" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/now.png
elif [[ $icon == "Nuit avec averses" ]]; then
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-avec-averses.png" $HOME/conky-openmeteo/Suisse/now.png
fi
##### aujourd'hui icône fcst_day_0 ######
icon=$(jq --raw-output '.fcst_day_0.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/d0.png
     cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp  $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/d0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/d0.png
fi
##### demain icône fcst_day_1 ######
icon=$(jq --raw-output '.fcst_day_1.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp  $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/d1.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/d1.png
fi
##### jour+2 icône ######
icon=$(jq --raw-output '.fcst_day_2.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp  $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averse-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/d2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/d2.png
fi
##### jour+3 icône ######
icon=$(jq --raw-output '.fcst_day_3.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp  $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/d3.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/d3.png
fi
##### jour+4 icône ######
icon=$(jq --raw-output '.fcst_day_4.condition' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/d4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/d4.png
fi
La suite du suisse.sh (le faux ruhm me dit que je dois le couper)
##### 00h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."0H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h0.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h0.png
fi
##### 02h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."2H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h2.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h2.png
fi
##### 04h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."4H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h4.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h4.png
fi
##### 06h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."6H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h6.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h6.png
fi
##### 08h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."8H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h8.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h8.png
fi
##### 10h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."10H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h10.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h10.png
fi
##### 12h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."12H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h12.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h12.png
fi
##### 14h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."14H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h14.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h14.png
fi
##### 16h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."16H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h16.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h16.png
fi
##### 18h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."18H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h18.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h18.png
fi
##### 20h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."20H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h20.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h20.png
fi
##### 22h00 condition icône ######
icon=$(jq --raw-output '.fcst_day_0.hourly_data."22H00".CONDITION' $HOME/conky-openmeteo/rawdata/rawsuisse)
    cp $HOME/conky-openmeteo/Suisse/icones/"ensoleille.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"ciel-voile.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"eclaircies.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faiblement-nuageux.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"fortement-nuageux.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-nuageuse.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-faible.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-claire.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-neige-faible.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"nuit-legerement-voilee.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"neige-faible.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"pluie-moderee.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"averses-de-pluie-faible.png" $HOME/conky-openmeteo/Suisse/h22.png
    cp $HOME/conky-openmeteo/Suisse/icones/"faibles-passages-nuageux.png" $HOME/conky-openmeteo/Suisse/h22.png
fi
capture_deecran_2023-04-25_10-55-36
Barometr
Bonjour
Un baromêtre qui utilise les prévisions du conky précédent.
conkyrc
conky.config = {
    background = true,
    use_xft = true,
    font = 'Bebas Neue Bold:size=12',
    xftalpha = 1,
    update_interval = 1.0,
    total_run_times = 0,
    own_window = true,
    own_window_transparent = true,
--own_window_color 000000
own_window_argb_visual = true,
--own_window_argb_value = 250,
    own_window_type = 'normal',
    own_window_hints = 'undecorated,below,skip_taskbar,skip_pager',
    double_buffer = true,
    minimum_width = 290, minimum_height = 290,
        maximum_width = 290,
    text_buffer_size = 2048,
    draw_shades = false,
    draw_outline = false,
    draw_borders = false,
    draw_graph_borders = false,
    default_color = 'white',
    default_outline_color = 'white',
    alignment = 'top_left',
    gap_x = 40,
    gap_y = 790,
    no_buffers = true,
    uppercase = false,
    cpu_avg_samples = 2,
    override_utf8_locale = true,
imlib_cache_flush_interval = 60,
    imlib_cache_size = 10000,
    stippled_borders = 5,
-- Couleurs
    default_shade_color = '#333333',
    default_outline_color = 'black',
lua_load = '~/.conky/barometr/loader.lua',
conky.text = [[
${lua conky_draw_bg 126 20 18 260 260 0x000000 0.2}
${lua fDrawImage $HOME/conky-openmeteo/Suisse/fond/suite-bgv.png 15 10 270 270}
${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.wnd_dir' > $HOME/.conky/barometr/dir}
${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.wnd_spd' > $HOME/.conky/barometr/vit}
${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.pressure' | awk '{printf("%d\n",$1)}' > $HOME/.conky/barometr/pre}
${execi 3600 cat $HOME/conky-openmeteo/rawdata/rawsuisse | jq --raw-output '.current_condition.humidity' > $HOME/.conky/barometr/hum}
${voffset -200}
le loader.lua
require 'cairo'
    dofile (usrhome .."/.conky/barometr/barometr.lua")
        conky_main_weather()
end
barometr.lua
--[[ barometr_v.0.1.lua by olgmen 07.12.2010
script displays the weather forecast with http://weather.noaa.gov
Use scripts:
BARGRAPH WIDGET v2.0 by wlourf (12.07.2010)
circlewriting by mrpeachy (2010)
Скрипт выводит прогноз погоды с http://weather.noaa.gov
Использованы скрипты:
require 'cairo'
-- [[ здесь вводятся все параметры ]] --
function conky_main_weather()
weather_settings = {            -- ВЫВОД ГРАФИКИ
{                    -- фон
sectors = 1,
gap_sectors = -1,
radius = 150,
thickness = 150,
bg_colour1 = {{0, 0x000000, 0.0}},    -- fond du grand cercle
{                    -- обод
sectors = 1,
gap_sectors = -1,
radius = 0,
thickness = 3,
bg_colour1 = {{0, 0xFFFFFF, 0.7}},
bg_colour2 = {{0, 0x1B1A25, 1},{0.5, 0x7D7D78, 0.9},{1, 0x5D5D78, 0}}, -- grand cercle
{                    -- фон шкалы барометра
radius = 111,
thickness = 7,
sectors = 1,
fill_sectors = true,
start_angle = -120,
end_angle = 120,
bg_colour1 = {{0, 0xffffff, 0.75}},    -- белый
{                    -- деления шкалы барометра
radius = 110,
thickness = 5,
sectors = 80,
gap_sectors = 1,
start_angle = -120,
end_angle = 120,
bg_colour1 = {{0, 0x000000, 1}},    -- черный
{                    -- деления шкалы термометра
radius = 110,
sectors = 9,
gap_sectors = 21,
start_angle = 125,
end_angle = 235,
bg_colour1 = {{0, 0xffffff, 0.5}},    -- белый
{                    -- термометр
name = "temperature",
arg = conky_parse('${exec sed -n 1p $HOME/.conky/barometr/temp}'),
max = 80,
radius = 110,
thickness = 9,
sectors = 1,
start_angle = 130,
end_angle = 230,
inverse_arc = true,
cap = "r",
bg_colour1 = {{0.0, 0x999999, 0.0},{0.5, 0x999999, 1.0},{1.0, 0x999999, 0.0}},
fg_colour1 = {{0.0, 0xff0000, 0.0},{0.5, 0xff0000, 1.0},{1.0, 0xff0000, 0.0}},
fg_colour2 = {{0.0, 0x6495ee, 0.0},{0.5, 0x6495ee, 1.0},{1.0, 0x6495ee, 0.0}},
bd_colour1 = {{0.0, 0x00FF00, 1.0},{0.5, 0x00FF0, 1.0},{1.0, 0x00FF00, 1.0}},
text_settings = {            -- ВЫВОД ТЕКСТОВ
{                    -- температура
text = "TEMPERATURE " .. conky_parse('${exec sed -n 1p $HOME/conky-openmeteo/Suisse/barographe/temp}') .. "'C",
font_name = "MonogramsToolbox",        -- навание шрифта
font_size = 8,                -- размер шрифта
bold = true,
inside    = true,                -- размещение текста против часовой стрелки
start_angle = 233,
end_angle = 135,
radius = 95,
{                    -- шкала термометра
text = " -40-30-20-10 0 10 20 30 40",
font_name = "URW Chancery L",
font_size = 14,
bold = true,
inside = true,
start_angle = 240,
end_angle = 131,
radius = 125,
{                    -- погода
text = "Tempete   Pluie   Variable   Beau   Tres sec",
font_size = 18,
bold = true,
start_angle = 245,
end_angle = 472,
radius = 118,
{                    -- давление в мм ртутного столба
text = "PRESSION " .. conky_parse('${exec sed -n 1p $HOME/.conky/barometr/pre}') .. "mb",
font_size = 8,
bold = true,
start_angle = 300,
end_angle = 417,
radius = 90,
{                    -- направление и скорость ветра
text = "VIT. " .. conky_parse('${exec sed -n 1p $HOME/.conky/barometr/vit}') .. "km/h",
font_size = 8,
bold = true,
start_angle = 75,
end_angle = 120,
radius = 90,
{                    -- влажность
text = "HUMIDITE " .. conky_parse('${exec sed -n 1p $HOME/.conky/barometr/hum}') .. "%",
font_size = 8,
bold = true,
inside = true,
start_angle = 228,
end_angle = 140,
radius = 78,
{                    -- облачность
text = "DIR. " .. conky_parse('${exec sed -n 1p $HOME/.conky/barometr/dir}'),
font_size = 8,
bold = true,
start_angle = 240,
end_angle = 275,
radius = 90,
image_settings = {            -- вывод центрального изображения
name = os.getenv ('HOME')..'/.conky/barometr/images/wind_rose.png',    -- путь к картинке
needle_settings = {            -- вывод стрелок
name = "vent",                -- направление ветра
arg = conky_parse('${exec sed -n 1p $HOME/.conky/barometr/dir}'),
max = 360,
length_of_arrows = 1.75,            -- длина стрелки
width_of_arrows = 6,            -- ширина стрелки
{                    -- давление
name = "pression",
arg = conky_parse('${exec sed -n 1p $HOME/.conky/barometr/pre}'),
max = 80,
start_angle = 242,
end_angle = 480,
length_of_arrows = 2.75,
width_of_arrows = 3,
----------- END --------------
    if conky_window == nil then return end
    local cs = cairo_xlib_surface_create(conky_window.display, conky_window.drawable, conky_window.visual, conky_window.width, conky_window.height)
    cr = cairo_create(cs)
    if tonumber(conky_parse('${updates}')) > 1 then
        for i in pairs(weather_settings) do
            draw_weather_graph(weather_settings[i])
        end
        for i in pairs(text_settings) do
            draw_circle_text(text_settings[i])
        end
        for i in pairs(image_settings) do
            draw_image(image_settings[i])
        end
        for i in pairs(needle_settings) do
            draw_needle_graph(needle_settings[i])
        end
    end
    cairo_destroy(cr)
    cairo_surface_destroy(cs)
end
-- функция вывода графики
function draw_weather_graph(t)
-- функция перекодировки цвета
    local function rgba_to_r_g_b_a(tcolour)
        colour,alpha=tcolour[2],tcolour[3]
        return ((colour / 0x10000) % 0x100) / 255.,
            ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
    end
    local function calc_delta(tcol1,tcol2)
        --calculate deltas P R G B A to table_colour 1
        for x = 1, #tcol1 do
            tcol1[x].dA    = 0
            tcol1[x].dP = 0
             tcol1[x].dR = 0
            tcol1[x].dG = 0
            tcol1[x].dB = 0
            if tcol2~=nil and #tcol1 == #tcol2 then
                local r1,g1,b1,a1 = rgba_to_r_g_b_a(tcol1[x])
                local r2,g2,b2,a2 = rgba_to_r_g_b_a(tcol2[x])
                tcol1[x].dP = (tcol2[x][1]-tcol1[x][1])/t.sectors
                 tcol1[x].dR = (r2-r1)/t.sectors
                tcol1[x].dG = (g2-g1)/t.sectors
                tcol1[x].dB = (b2-b1)/t.sectors
                tcol1[x].dA = (a2-a1)/t.sectors
            end
        end
        return tcol1
    end
    local function draw_scale (x, y, radius, max)
        local i = 0
        local winkel = math.rad(3)
cairo_set_source_rgba(cr,1,1,1,1)
        for i = 0, max/2 - 1, 1 do
        cairo_set_line_width(cr,1)
        cairo_move_to(cr, x -radius- math.sin(winkel*i)*radius, y-radius - math.cos(winkel*i)*radius)
        cairo_line_to(cr, x-radius - math.sin(winkel*i)*(radius*0.9), y-radius-math.cos(winkel*i)*(radius*0.9))
        cairo_stroke(cr)
        end
    end
    --check values
    local function setup(t)
-- сохраняем данные и настройки
    cairo_save(cr)
-- установки по умолчанию
        if t.name        == nil then t.name= "" end
        if t.arg        == nil then t.arg = "" end
        if t.max        == nil then t.max = 100 end
        if t.x             == nil then t.x = conky_window.width/2 end
        if t.y            == nil then t.y = conky_window.height/2 end
        if t.height        == nil then t.height = conky_window.width end
        if t.width        == nil then t.width = conky_window.width end
        if t.radius        == nil then t.radius = (conky_window.width/2)*0.9 end
        if t.start_angle    == nil then t.start_angle=0 end
        if t.end_angle        == nil then t.end_angle = 360 end
        if t.thickness        == nil then t.thickness = 10 end
        if t.sectors        == nil then t.sectors = 10 end
        if t.gap_sectors    == nil then t.gap_sectors = 1 end
        if t.fill_sector    == nil then t.fill_sector = false end
        if t.sectors        == 1   then t.fill_sector = false end
        if t.border_size    == nil then t.border_size = 0 end
        if t.cap        == nil then t.cap = "p" end
-- цвет фона
        if t.bg_colour1 == nil then
            t.bg_colour1 = {{0, 0x00ffff, 0.1},{0.5, 0x00FFFF, 0.5},{1, 0x00FFFF, 0.1}}
        end
-- цвет параметра
        if t.fg_colour1 == nil then
            t.fg_colour1 = {{0, 0x00FF00, 0.1},{0.5, 0x00FF00, 1},{1, 0x00FF00, 0.1}}
        end
-- цвет окантовки
        if t.bd_colour1 == nil then
            t.bd_colour1 = {{0, 0xFFFF00, 0.5},{0.5, 0xFFFF00, 1},{1, 0xFFFF00, 0.5}}
        end
-- проверяем соотношение ширины кольца и радиуса
        if t.thickness > t.radius then t.thickness = t.radius*0.1 end
        t.int_radius = t.radius - t.thickness
-- проверяем данные углов
        if t.start_angle >= t.end_angle then
             local tmp_angle = t.end_angle
             t.end_angle = t.start_angle
             t.start_angle = tmp_angle
         -- print ("inversed angles")
            if t.end_angle-t.start_angle > 360 and t.start_angle > 0 then
                t.end_angle = 360 + t.start_angle
                print ("reduce angles")
            end
            if t.end_angle + t.start_angle > 360 and t.start_angle <= 0 then
            end
            if t.int_radius < 0 then t.int_radius = 0 end
            if t.int_radius > t.radius then
                local tmp_radius = t.radius
                t.radius = t.int_radius
                t.int_radius = tmp_radius
                print ("inversed radius")
            end
            if t.int_radius == t.radius then
                t.int_radius = 0
                print ("int radius set to 0")
            end
        end
-- проверка таблиц цвета
        for i = 1, #t.bg_colour1 do
            if #t.bg_colour1[i] ~= 3 then t.bg_colour1[i] = {1, 0xFFFFFF, 0.5} end
        end
        for i = 1, #t.fg_colour1 do
            if #t.fg_colour1[i] ~= 3 then t.fg_colour1[i] = {1, 0xFF0000, 1} end
        end
        for i = 1, #t.bd_colour1 do
            if #t.bd_colour1[i] ~= 3 then t.bd_colour1[i] = {1, 0xFFFF00, 1} end
        end
        if t.bg_colour2 ~= nil then
            for i = 1, #t.bg_colour2 do
                if #t.bg_colour2[i] ~= 3 then t.bg_colour2[i] = {1, 0xFFFFFF, 0.5} end
            end
        end
        if t.fg_colour2 ~= nil then
            for i = 1, #t.fg_colour2 do
                if #t.fg_colour2[i] ~= 3 then t.fg_colour2[i] = {1, 0xFF0000, 1} end
            end
        end
        if t.bd_colour2 ~= nil then
            for i = 1, #t.bd_colour2 do
                if #t.bd_colour2[i] ~= 3 then t.bd_colour2[i] = {1, 0xFFFF00, 1} end
            end
        end
        t.fg_colour1 = calc_delta(t.fg_colour1,t.fg_colour2)
        t.bg_colour1 = calc_delta(t.bg_colour1,t.bg_colour2)
        t.bd_colour1 = calc_delta(t.bd_colour1,t.bd_colour2)
    end
    setup(t)
    --initialize cairo context
    cairo_save(cr)
    cairo_translate(cr, t.x, t.y)
    cairo_set_line_join (cr, CAIRO_LINE_JOIN_ROUND)
    cairo_set_line_cap (cr, CAIRO_LINE_CAP_ROUND)
    --get value
    local value = 0
-- --------------------------------------------- обработка вывода температуры
    if t.name == "temperature" then t.name = "" end
    if t.name ~= "" then
        value = tonumber(conky_parse(string.format('${%s %s}', t.name, t.arg)))
    else
        value = tonumber(t.arg)
    end
    if value==nil then value =0 end
    --initialize sectors
    --angle of a sector :
    angleA = ((t.end_angle-t.start_angle)/t.sectors)*math.pi/180
    --value of a sector :
    valueA = t.max/t.sectors
    --first angle of a sector :
    lastAngle = t.start_angle*math.pi/180
    local function draw_sector(type_arc,angle0,angle,valpc, idx)
        --this function draws a portion of arc
         --type of arc, angle0 = strating angle, angle= angle of sector,
         --valpc = percentage inside the sector, idx = sctor number #
         if type_arc=="bg" then         --background
             if valpc==1 then return end
             tcolor=t.bg_colour1
         elseif type_arc=="fg" then    --foreground
             if valpc==0 then return end
             tcolor=t.fg_colour1
         elseif type_arc=="bd" then    --border
             tcolor=t.bd_colour1
         end
        --angles equivalents to gap_sector
        local ext_delta=math.atan(t.gap_sectors/(2*t.radius))
        local int_delta=math.atan(t.gap_sectors/(2*t.int_radius))
        --angles of arcs
        local ext_angle=(angle-ext_delta*2)*valpc
        local int_angle=(angle-int_delta*2)*valpc
        --define colours to use for this sector
        if #tcolor==1 then
            --plain color
            local vR,vG,vB,vA = rgba_to_r_g_b_a(tcolor[1])
                                    vG+tcolor[1].dG*idx,
                                    vB+tcolor[1].dB*idx,
                                    vA+tcolor[1].dA*idx    )
        else
            --radient color
            local pat=cairo_pattern_create_radial(0,0,t.int_radius,0,0,t.radius)
            for i=1, #tcolor do
                local vP,vR,vG,vB,vA = tcolor[i][1], rgba_to_r_g_b_a(tcolor[i])
                cairo_pattern_add_color_stop_rgba (pat,
                                    vP+tcolor[i].dP*idx,
                                    vR+tcolor[i].dR*idx,
                                    vG+tcolor[i].dG*idx,
                                    vB+tcolor[i].dB*idx,
                                    vA+tcolor[i].dA*idx    )
            end
            cairo_set_source (cr, pat)
            cairo_pattern_destroy(pat)
        end
        --start drawing
         cairo_save(cr)
        --x axis is parrallel to start of sector
        local ri,re = t.int_radius ,t.radius
        --point A
        local angle_a
        if t.cap == "p" then
            angle_a = int_delta
            if t.inverse_arc and type_arc ~="bg" then
                angle_a = angle-int_angle-int_delta
            end
            if not(t.inverse_arc) and type_arc =="bg" then
                angle_a = int_delta+int_angle
            end
        else --t.cap=="r"
            angle_a = ext_delta
            if t.inverse_arc and type_arc~="bg" then
                angle_a = angle-ext_angle-ext_delta
            end
            if not(t.inverse_arc) and type_arc=="bg" then
                angle_a = ext_delta+ext_angle
            end
        end
        local ax,ay = ri*math.cos(angle_a),ri*math.sin(angle_a)
        --point B
        local angle_b = ext_delta
                angle_b = angle-ext_angle-ext_delta
            end
                angle_b = ext_delta+ext_angle
            end
        else
            end
            end
        end
        local bx,by = re*math.cos(angle_b),re*math.sin(angle_b)
        -- EXTERNAL ARC B --> C
        if t.inverse_arc then
                b0,b1= ext_delta, angle-ext_delta-ext_angle
            else
                b0,b1= angle-ext_angle-ext_delta, angle-ext_delta
            end
        else
                b0,b1= ext_delta+ext_angle, angle-ext_delta
            else
                b0,b1= ext_delta, ext_angle+ext_delta
            end
        end
        ---POINT D
        local angle_c
            angle_d = angle-int_delta
            if t.inverse_arc and type_arc=="bg" then
                angle_d = angle-int_delta-int_angle
            end
            if not(t.inverse_arc) and type_arc~="bg" then
                angle_d=int_delta+int_angle
            end
        else
            angle_d = angle-ext_delta
                angle_d =angle-ext_delta-ext_angle
            end
                angle_d = ext_angle+ext_delta
            end
        end
        local dx,dy = ri*math.cos(angle_d),ri*math.sin(angle_d)
        -- INTERNAL ARC D --> A
        if t.cap=="p" then
                    d0,d1= angle-int_delta-int_angle,int_delta
                else
                    d0,d1= angle-int_delta, angle- int_angle-int_delta
                end
            else
                    d0,d1= angle-int_delta, int_delta+int_angle
                else
                    d0,d1= int_delta+int_angle, int_delta
                end
            end
        else
                    d0,d1= angle-ext_delta-ext_angle,ext_delta
                else
                    d0,d1= angle-ext_delta, angle- ext_angle-ext_delta
                end
            else
                    d0,d1= angle-ext_delta,ext_delta+ext_angle
                else
                    d0,d1= ext_angle+ext_delta, ext_delta
                end
            end
        end
        --draw sector
        cairo_move_to(cr,ax,ay)
        cairo_line_to(cr,bx,by)
        cairo_arc(cr,0,0,re,b0,b1)
        cairo_line_to(cr,dx,dy)
         cairo_close_path (cr);
        --stroke or fill sector
             cairo_stroke(cr)
         else
             cairo_fill(cr)
         end
         cairo_restore(cr)
     end
    --draw sectors
    local n0,n1,n2 = 1,t.sectors,1
    if t.inverse_arc then n0,n1,n2 = t.sectors,1,-1 end
    local index = 0
    for i = n0,n1,n2 do
        index = index +1
        local valueZ=1
        local cstA, cstB = (i-1),i
        if t.inverse_arc then cstA,cstB = (t.sectors-i), (t.sectors-i+1) end
        if value>valueA *cstA and value<valueA*cstB then
            if not t.fill_sector then
                valueZ = (value-valueA*cstA)/valueA
            end
        else
            if value<valueA*cstB then valueZ=0 end
        end
        local start_angle= lastAngle+(i-1)*angleA
        if t.foreground ~= false then
            draw_sector("fg",start_angle,angleA,valueZ, index)
        end
        if t.background ~= false then
            draw_sector("bg",start_angle,angleA,valueZ, i)
        end
        if t.border_size>0 then draw_sector("bd",start_angle,angleA,1, i) end
    end
    cairo_restore(cr)
end
--[[END OF RING-SECTORS WIDGET]]
-- [[ TEXT ]] --
-- функция добавления незначащих нулей
function addzero100(num)
    if tonumber(num) == nil then return end    --tonumber(num) == 0 end
    if tonumber(num) < 10 then
        return "00" .. num
    elseif tonumber(num) <100 then
        return "0" .. num
    else
        return num
    end
end
function string:split(delimiter)
    local result = { }
    local from  = 1
    local delim_from, delim_to = string.find(self, delimiter, from)
    while delim_from do
        table.insert(result, string.sub(self, from, delim_from-1))
        from = delim_to + 1
    end
    table.insert(result, string.sub(self, from))
    return result
end
function rgb_to_r_g_b2(tcolour)
    return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
end
            tcol1[x].dA    = 0
            tcol1[x].dP = 0
             tcol1[x].dR = 0
            tcol1[x].dG = 0
            tcol1[x].dB = 0
            end
        end
    return tcol1
end
function draw_circle_text(t)
-- проверка вводимых параметров и установка параметров по умолчанию
    if t.text    == nil then t.text = "Conky c'est pour pour le moral !" end
    if t.font_name    == nil then t.font_name = "Free Sans" end
    if t.font_size    == nil then t.font_size = 14 end
    if t.start_angle    == nil then t.start_angle = 120 end
    if t.end_angle        == nil then t.end_angle = 240 end
    if t.italic        == nil then t.italic = false end
    if t.oblique        == nil then t.oblique = false end
    if t.bold        == nil then t.bold = false end
    if t.inside        == nil then inside = nil end
    if t.align        == nil then t.align = 0 end
    local slant = CAIRO_FONT_SLANT_NORMAL
    local weight =CAIRO_FONT_WEIGHT_NORMAL
    if t.italic then slant = CAIRO_FONT_SLANT_ITALIC end
    if t.oblique then slant = CAIRO_FONT_SLANT_OBLIQUE end
    if t.bold then weight = CAIRO_FONT_WEIGHT_BOLD end
    cairo_select_font_face(cr, t.font_name, slant,weight)
    local inum = string.len(t.text)
    if t.inside ~= nil then
        deg = (t.start_angle - t.end_angle)/(inum - 1)
    else
        range = t.end_angle
        deg = (t.end_angle - t.start_angle)/(inum-1)
    end
    degrads = 1*(math.pi/180)
    local textcut = string.gsub(t.text, ".", "%1@@@")
    texttable = string.split(textcut, "@@@")
    for i = 1, inum do
        ival = i
            interval = (degrads*(t.start_angle - (deg*(i - 1)))) + t.align
            interval2 = degrads*(t.start_angle - (deg*(i - 1)))
        else
            interval = (degrads*(t.start_angle + (deg*(i - 1)))) + t.align
            interval2 = degrads*(t.start_angle + (deg*(i - 1)))
        end
        txs = 0 + t.radius*(math.sin(interval))
        tys = 0 - t.radius*(math.cos(interval))
        cairo_set_font_size (cr, t.font_size)
        cairo_set_source_rgba(cr, 1, 1, 1, 1)
        cairo_move_to (cr, txs + t.x, tys + t.y)
            cairo_rotate (cr, interval2 + (180*math.pi/180))
        else
            cairo_rotate (cr, interval2)
        end
        cairo_show_text (cr, (texttable[i]))
            cairo_rotate (cr, -interval2 - (180*math.pi/180))
        else
            cairo_rotate (cr, -interval2)
        end
    end
end
function draw_image(t)
-- создаём имидж изображения
    image_bg = cairo_image_surface_create_from_png (t.name)
-- забираем данные о ширине и высоте изображения из образа
    w1 = cairo_image_surface_get_width (image_bg)
    h1 = cairo_image_surface_get_height (image_bg)
-- выводим изображение
    cairo_set_source_surface (cr, image_bg, t.x - w1/2, t.y - h1/2)
    cairo_paint (cr)
    cairo_surface_destroy (image_bg)
end
function draw_needle_graph (t)
    if t.name        == nil then t.name= "time" end
    if t.arg        == nil then t.arg = "%S" end
    if t.max        == nil then t.max = 60 end
    if t.radius        == nil then t.radius = 100 end
    if t.start_angle    == nil then t.start_angle = 0 end
    if t.width_of_arrows    == nil then t.width_of_arrows = 2 end
    if t.length_of_arrows    == nil then t.length_of_arrows = 2.2 end
    if t.name == "vent" then
        if t.arg    == "S"        then t.arg = 180.0 end
        if t.arg    == "NNE"    then t.arg = 202.5 end
        if t.arg    == "SO"        then t.arg = 225.0 end
        if t.arg    == "ENE"    then t.arg = 247.5 end
        if t.arg    == "O"        then t.arg = 270.0 end
        if t.arg    == "ESE"    then t.arg = 292.5 end
        if t.arg    == "NO"        then t.arg = 315.0 end
        if t.arg    == "SSE"    then t.arg = 337.5 end
        if t.arg    == "N"        then t.arg = 360.0 end
        if t.arg    == "SSO"    then t.arg = 22.5 end
        if t.arg    == "NE"        then t.arg = 45.0 end
        if t.arg    == "OSO"    then t.arg = 67.5 end
        if t.arg    == "E"        then t.arg = 90.0 end
        if t.arg    == "ONO"    then t.arg = 112.5 end
        if t.arg    == "SE"        then t.arg = 135.0 end
        if t.arg    == "NNO"    then t.arg = 157.5 end
    end
    value = tonumber(conky_parse(t.arg))
    if value == nil then value = 0 end
-- начальный угол
    local sa = t.start_angle * (math.pi / 180)
-- конечный угол
    local ea = t.end_angle * (math.pi / 180)
-- расчет угла движения стрелки
    gamma = math.pi/2-math.atan(t.width_of_arrows/(t.radius*t.length_of_arrows))
    arc = ((ea - sa)/t.max)* value + sa
    arc0=arc-gamma
    arc1=arc+gamma
    xx = t.x + t.radius*math.sin(arc)*t.length_of_arrows
    yy = t.y - t.radius*math.cos(arc)*t.length_of_arrows
    x0 = t.x + t.width_of_arrows*math.sin(arc0)
    y0 = t.y - t.width_of_arrows*math.cos(arc0)
    x1 = t.x + t.width_of_arrows*math.sin(arc1)
    y1 = t.y - t.width_of_arrows*math.cos(arc1)
    cairo_set_source_rgba(cr, 0, 0, 0, 0.5)
-- рисуем стрелку
-- dessiner une flèche
    cairo_move_to (cr, x0, y0)
    cairo_curve_to (cr, x0, y0, xx, yy, x1, y1)
    cairo_arc(cr, t.x, t.y, t.width_of_arrows, arc1, arc0)
    pat = cairo_pattern_create_radial (t.x, t.y, t.radius/10, t.x, t.y, t.radius*t.length_of_arrows)
-- для ветра устанавливаем цвет синий переходящий в красный (не очень заметно)
--régler la couleur du vent de bleu à rouge (pas très visible)
        cairo_pattern_add_color_stop_rgba (pat, 0.6, 0.4, 0.6, 0.9, 0.8)   --bleu
        cairo_pattern_add_color_stop_rgba (pat, 0.6, 1, 1, 0.8, 1) --rouge
    else
-- для давления красный
-- pour la pression rouge
        cairo_pattern_add_color_stop_rgba (pat, 0, 0.8, 0, 0, 0.8)
        cairo_pattern_add_color_stop_rgba (pat, 1, 1, 0, 0, 1)  -- rouge
    end
    cairo_fill (cr)
    cairo_pattern_destroy (pat)
end
--[[  Немного поясню, из чего состоит строка
 cairo_pattern_add_color_stop_rgba (pat, 1, 1, 0, 0, 0.5)
цифры означают: 1- слой, 1-красный, 0-зеленый, 0-синий, 0.5-насыщенность
слой имеет значения от 0 до 1]]--
--[[[ Je vais expliquer un peu en quoi consiste la chaîne de caractères
les nombres signifient : 1-couche, 1-rouge, 0-vert, 0-bleu, 0,5-saturation
la couche a des valeurs de 0 à 1]]--.
capture_deecran_2023-04-25_11-06-05
