Dernière mise à jour : 24/04/2023 à 14h53
Chronographe
conkyrc
conky.config = { background = true, use_xft = true, font = 'hooge 05_53:size=6', xftalpha = 1, update_interval = 1.0, total_run_times = 0, net_avg_samples = 2, own_window = true, own_window_transparent = true, --own_window_color 000000 own_window_argb_visual = true, --own_window_argb_value = 250, own_window_type = 'normal', own_window_hints = 'undecorated,below,skip_taskbar,skip_pager', double_buffer = true, minimum_width = 320, minimum_height = 320, maximum_width = 320, text_buffer_size = 2048, draw_shades = false, draw_outline = false, draw_borders = false, draw_graph_borders = false, default_color = 'white', default_outline_color = 'white', alignment = 'top_right', gap_x = 120, gap_y = 70, no_buffers = true, uppercase = false, cpu_avg_samples = 2, override_utf8_locale = true, imlib_cache_flush_interval = 60, imlib_cache_size = 10000, stippled_borders = 5, -- Couleurs default_color = '#ffffff', --ffd579 default_shade_color = '#333333', default_outline_color = 'black', color0 = 'white', color1 = 'orange', color2 = 'green', color3 = '#000000', color4 = '#FF0000', color5 = '#696969', color6 = '#BDB76B', color7 = '#00FF01', color8 = '#cccccc', lua_load = '~/.conky/cronograph/scripts/cups.lua', lua_draw_hook_post = 'main', }; conky.text = [[ ${execi 3600 bash $HOME/1_accuweather/1_accuweather -f2016} ${voffset 85}${goto 85}${font hooge 05_53:size=12}${time %H:%M}${font}${goto 215}UPTIME: ${voffset 2}${goto 72}${time %a %d %b}${goto 215}${uptime} ${voffset 2}${goto 90}${time %Y}${alignc -75}Temp.${hwmon 0 temp 1}°C ${voffset 84}${goto 75}Signal: ${wireless_link_qual_perc wlo1} % ${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600 sed -n '22p' $HOME/1_accuweather/curr_cond}${font} ${voffset -60}${goto 154}${font hooge 05_53:size=12}${execpi 600 sed -n '2p' ~/1_accuweather/curr_cond}°C${font} ${voffset -16}${goto 200}${execpi 600 sed -n '4p' ~/1_accuweather/curr_cond | cut -c1-14} ${goto 200}${execpi 600 sed -n '4p' ~/1_accuweather/curr_cond | cut -c15-30} ${goto 200}Vent: ${execpi 600 sed -n '5p' ~/1_accuweather/curr_cond} ${execpi 600 sed -n '6p' ~/1_accuweather/curr_cond} ${goto 200}Hum: ${execpi 600 sed -n '7p' ~/1_accuweather/curr_cond} ${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600 sed -n '27p' $HOME/1_accuweather/first_days}${font} ${voffset 1}${goto 220}${execi 600 sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C ${goto 225}${execi 3600 echo `date --date="1 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="1 day" | awk '{print $2}'`}\ ${voffset -10}${font conkyweather:size=20} ${goto 90}${execi 600 sed -n '28p' $HOME/1_accuweather/first_days} ${voffset -34}${goto 226}${execi 600 sed -n '29p' $HOME/1_accuweather/first_days}${font} ${voffset -1} ${goto 80}${execi 600 sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '13p' $HOME/1_accuweather/first_days}°C\ ${goto 215}${execi 600 sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '18p' $HOME/1_accuweather/first_days}°C ${goto 80}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\ ${goto 215}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`} ${execpi 1 cat ~/.conky/cronograph/scripts/blinkingLED} ]];
conkyrc1 (pour le deuxième lua)
conky.config = { background = true, use_xft = true, font = 'hooge 05_53:size=6', xftalpha = 1, update_interval = 1.0, total_run_times = 0, net_avg_samples = 2, own_window = true, own_window_transparent = true, --own_window_color 000000 own_window_argb_visual = true, --own_window_argb_value = 250, own_window_type = 'normal', own_window_hints = 'undecorated,below,skip_taskbar,skip_pager', double_buffer = true, minimum_width = 320, minimum_height = 320, maximum_width = 320, text_buffer_size = 2048, draw_shades = false, draw_outline = false, draw_borders = false, draw_graph_borders = false, default_color = 'white', default_outline_color = 'white', alignment = 'top_right', gap_x = 120, gap_y = 70, no_buffers = true, uppercase = false, cpu_avg_samples = 2, override_utf8_locale = true, imlib_cache_flush_interval = 60, imlib_cache_size = 10000, stippled_borders = 5, -- Couleurs default_color = '#ffffff', --ffd579 default_shade_color = '#333333', default_outline_color = 'black', color0 = 'white', color1 = 'orange', color2 = 'green', color3 = '#000000', color4 = '#FF0000', color5 = '#696969', color6 = '#BDB76B', color7 = '#00FF01', color8 = '#cccccc', lua_load = '~/.conky/cronograph/scripts/clock_rings2a.lua', lua_draw_hook_pre = 'clock_rings', }; conky.text = [[ ]];
cups.lua
--- --============================================================================== -- Cups and Saucers -- Lua conky script -- -- author : Abu Yahya -- license : Distributed under the terms of GNU GPL v3 -- 30.05.2012 -- v.1.0.1 --============================================================================== require 'cairo' -------------------------------------------------------------------------------- ----Adjustable Settings coffee_table = { { name='time', arg='%I', max_value=12, x=170, y=170, cup_radius=35, cup_wall_thickness=90, cup_bg_clr=0xffffff, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_length=70, handle_circ=5, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0 graduation_radius=124, graduation_thickness=8, graduation_mark_circ=1.5, graduation_mark_angle=30, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5, saucer_thickness=6, thick_saucer_circ=11/12, saucer_radius=135, thin_saucer_circ=11/12, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0, inner_saucer=true, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0, caption='', caption2='', }, { name='time', arg='%H', max_value=12, x=170, y=170, cup_radius=2.5, cup_wall_thickness=3, cup_bg_clr=0xffffff, cup_bg_alpha=1.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=1.0, handle_length=40, handle_circ=4, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0 graduation_radius=127, graduation_thickness=1, graduation_mark_circ=0.5, graduation_mark_angle=3, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5, saucer_thickness=6, thick_saucer_circ=11/12, saucer_radius=135, thin_saucer_circ=11/12, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.0, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0, inner_saucer=true, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0, caption='', caption2='', }, { name='time', arg='%M', max_value=60, x=170, y=170, cup_radius=55, cup_wall_thickness=120, cup_bg_clr=0xffffff, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, graduation_radius=123, graduation_thickness=10, graduation_mark_circ=2.5, graduation_mark_angle=90, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5, handle_length=110, handle_circ=3, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0 saucer_thickness=6, thick_saucer_circ=11/12, saucer_radius=155, thin_saucer_circ=11/12, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0, caption='', caption2='', }, { name='time', arg='%S', max_value=60, x=170, y=170, cup_radius=59, cup_wall_thickness=120, cup_bg_clr=0xffffff, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0 handle_length=118, handle_circ=1, graduation_radius=125, graduation_thickness=6, graduation_mark_circ=0.5, graduation_mark_angle=6, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5, saucer_thickness=5, thick_saucer_circ=1, saucer_radius=145, thin_saucer_circ=11/12, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.4, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.4, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0, caption='', caption2='', }, { name='cpu', arg='cpu0', max_value=100, x=170, y=100, cup_radius=20, cup_wall_thickness=40, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= -5, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=1, caption=' CPU ', caption2=' %', graduation_radius=25, graduation_thickness=3, graduation_mark_circ=2, graduation_mark_angle=36, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6, saucer_thickness=3, thick_saucer_circ=0.85, saucer_radius=30, thin_saucer_circ=0.85, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, inner_saucer=true, }, { name='freq_g', arg='/', max_value=5, x=170, y=100, cup_radius=12, cup_wall_thickness=23, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= 10, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=1, caption='', caption2=' GHz', graduation_radius=25, graduation_thickness=4, graduation_mark_circ=4, graduation_mark_angle=30, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0, saucer_thickness=3, thick_saucer_circ=0.75, saucer_radius=35, thin_saucer_circ=0.75, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, }, ---------------1/2 { name='downspeedf', arg='wlo1', max_value=100, x=100, y=170, cup_radius=12, cup_wall_thickness=23, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= -5, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=1, caption='E. ', caption2='', graduation_radius=25, graduation_thickness=3, graduation_mark_circ=2, graduation_mark_angle=36, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6, saucer_thickness=3, thick_saucer_circ=0.85, saucer_radius=30, thin_saucer_circ=0.85, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, inner_saucer=true, }, { name='upspeedf', arg='wlo1', max_value=100, x=100, y=170, cup_radius=12, cup_wall_thickness=27, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= 10, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=1, caption='S ', caption2='', graduation_radius=25, graduation_thickness=4, graduation_mark_circ=4, graduation_mark_angle=30, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0, saucer_thickness=3, thick_saucer_circ=0.85, saucer_radius=35, thin_saucer_circ=0.85, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, }, ------------------2/3 { name='fs_used_perc', arg='/home', max_value=100, x=170, y=240, cup_radius=12, cup_wall_thickness=27, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= 10, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=1, caption=' FS /: ', caption2=' %', graduation_radius=25, graduation_thickness=3, graduation_mark_circ=2, graduation_mark_angle=36, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6, saucer_thickness=3, thick_saucer_circ=0.85, saucer_radius=30, thin_saucer_circ=0.85, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, inner_saucer=true, }, { name='fs_used_perc', arg='/', max_value=100, x=170, y=240, cup_radius=12, cup_wall_thickness=27, cup_start_angle=0, cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0, cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0, handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, handle_length=40, handle_circ=4, xtxt=-20, ytxt= -5, txt_weight=0, txt_size=8.0, txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.8, caption=' FS H: ', caption2=' %', graduation_radius=25, graduation_thickness=4, graduation_mark_circ=4, graduation_mark_angle=36, graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0, saucer_thickness=3, thick_saucer_circ=0.85, saucer_radius=35, thin_saucer_circ=0.85, saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3, saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5, }, } --Fixed code -do not edit unless you know what you are doing------------------------------------------------------------------------ ------------------------------------------------------------------------------- -- converts color in hexa to decimal function rgb_to_r_g_b(clr, alpha) return ((clr / 0x10000) % 0x100) / 255., ((clr / 0x100) % 0x100) / 255., (clr % 0x100) / 255., alpha end ------------------------------------------------------------------------------- ------------------------------------------------------------------------ -- displays cups and saucers local function draw_coffee_table(display, data, value) max_value = data['max_value'] x, y = data['x'], data['y'] if x==nil then x=conky_window.width/2 end if y==nil then y=conky_window.height/2 end cup_radius = data['cup_radius'] if cup_radius==nil then cup_radius=conky_window.width/4 end cup_wall_thickness = data['cup_wall_thickness'] if cup_wall_thickness==nil then cup_wall_thickness=20 end handle_length, handle_circ = data['handle_length'], data['handle_circ'] if handle_length==nil then handle_length=20 end if handle_circ==nil then handle_circ=1 end cup_start_angle = data['cup_start_angle'] if cup_start_angle == nil then cup_start_angle =0 end total_angle = data['total_angle'] if total_angle == nil then total_angle=360 end cup_sector_angle = (math.abs(total_angle))/max_value cup_end_angle = total_angle + cup_start_angle cup_bg_clr, cup_bg_alpha = data['cup_bg_clr'], data['cup_bg_alpha'] if cup_bg_clr==nil then cup_bg_clr =0xffffff end cup_fg_clr, cup_fg_alpha = data['cup_fg_clr'], data['cup_fg_alpha'] if cup_fg_clr==nil then cup_fg_clr =0xffffff end if cup_fg_alpha==nil then cup_fg_alpha=0 end handle_fg_clr, handle_fg_alpha = data['handle_fg_clr'], data['handle_fg_alpha'] if handle_fg_clr==nil then handle_fg_clr = 0xffffff end if handle_fg_alpha==nil then handle_fg_alpha=0 end saucer_radius = data['saucer_radius'] if saucer_radius==nil then saucer_radius=conky_window.width/2 end total_saucer_angle=data['total_saucer_angle'] if total_saucer_angle==nil then total_saucer_angle=360 end saucer_sector_angle=(math.abs(total_saucer_angle))/max_value saucer_thickness = data['saucer_thickness'] if saucer_thickness==nil then saucer_thickness=6 end saucer_fg_clr = data['saucer_fg_clr'] if saucer_fg_clr ==nil then saucer_fg_clr=0 end saucer_fg_alpha = data['saucer_fg_alpha'] if saucer_fg_alpha ==nil then saucer_fg_alpha=0 end saucer_mark_fg_alpha = data['saucer_mark_fg_alpha'] if saucer_mark_fg_alpha ==nil then saucer_mark_fg_alpha=0 end saucer_mark_fg_clr = data['saucer_mark_fg_clr'] if saucer_mark_fg_clr ==nil then saucer_mark_fg_clr=0xffffff end thick_saucer_circ = data['thick_saucer_circ'] if thick_saucer_circ==nil then thick_saucer_circ =0.9 end thin_saucer_circ = data['thin_saucer_circ'] if thin_saucer_circ==nil then thin_saucer_circ =0.9 end inner_saucer = data['inner_saucer'] graduation_radius = data['graduation_radius'] if graduation_radius ==nil then graduation_radius = conky_window.width/3 end graduation_thickness, graduation_mark_circ = data['graduation_thickness'], data['graduation_mark_circ'] if graduation_thickness ==nil then graduation_thickness = 2 end if graduation_mark_circ ==nil then graduation_mark_circ = 1 end graduation_mark_angle = data['graduation_mark_angle'] if graduation_mark_angle == nil then graduation_mark_angle = total_angle/10 end graduation_fg_clr, graduation_fg_alpha = data['graduation_fg_clr'], data['graduation_fg_alpha'] if graduation_fg_clr ==nil then graduation_fg_clr= 0xffffff end if graduation_fg_alpha==nil then graduation_fg_alpha =0 end txt_weight, txt_size = data['txt_weight'], data['txt_size'] if txt_weight == nil then txt_weight=1 end if txt_size == nil then txt_size=8 end txt_fg_clr, txt_fg_alpha = data['txt_fg_clr'], data['txt_fg_alpha'] if txt_fg_clr ==nil then txt_fg_clr= 0xffffff end if txt_fg_alpha==nil then txt_fg_alpha =0 end caption = data['caption'] if caption==nil then caption='' end caption2 = data['caption2'] if caption2==nil then caption2='' end xtxt, ytxt= data ['xtxt'], data['ytxt'] if xtxt ==nil then xtxt=0 end if ytxt ==nil then ytxt=0 end --convert degree to rad and rotate (0 degree is top/north) function angle_to_position(start_angle, current_angle) if total_angle < 0 then local pos = start_angle - current_angle return ( ( pos * (math.pi / 180) ) - (math.pi / 2) ) else local pos = current_angle + start_angle return ( ( pos * (math.pi / 180) ) - (math.pi / 2) ) end end --cup centre background if cup_bg_alpha >0 then if total_angle < 0 then cairo_arc_negative(display, x, y, cup_radius, angle_to_position(cup_start_angle, 0), angle_to_position(cup_end_angle, 0)) else cairo_arc(display, x, y, cup_radius, angle_to_position(cup_start_angle, 0), angle_to_position(cup_start_angle, cup_end_angle)) end cairo_set_source_rgba(display, rgb_to_r_g_b(cup_bg_clr, cup_bg_alpha)) cairo_set_line_width(display, cup_wall_thickness) cairo_stroke(display) end --cup wall fg if cup_fg_alpha > 0 then local fg_stop_arc = (cup_sector_angle * value) if total_angle < 0 then cairo_arc_negative(display, x, y, cup_radius, angle_to_position(cup_start_angle, 0), angle_to_position(cup_start_angle, fg_stop_arc)) else cairo_arc(display, x, y, cup_radius, angle_to_position(cup_start_angle, 0), angle_to_position(cup_start_angle, fg_stop_arc)) end cairo_set_source_rgba(display, rgb_to_r_g_b(cup_fg_clr, cup_fg_alpha)) cairo_set_line_width(display, cup_wall_thickness) cairo_stroke(display) end -- cup handle if handle_fg_alpha>0 then local start_handle = (cup_sector_angle * value) - (handle_circ*0.5) local stop_handle = (cup_sector_angle * value) + (handle_circ*0.5) if total_angle < 0 then cairo_arc_negative(display, x, y, cup_radius, angle_to_position(cup_start_angle, start_handle), angle_to_position(cup_start_angle, stop_handle)) else cairo_arc(display, x, y, cup_radius, angle_to_position(cup_start_angle, start_handle), angle_to_position(cup_start_angle, stop_handle)) end cairo_set_line_width(display, handle_length) cairo_set_source_rgba(display, rgb_to_r_g_b(handle_fg_clr, handle_fg_alpha)) cairo_stroke(display) end --saucers ---thick saucer if saucer_fg_alpha > 0 and (thin_saucer_circ >0 or thick_saucer_circ > 0) then if value < (max_value/2) then j = value + ((max_value*total_saucer_angle)/720) else j = value - ((max_value*total_saucer_angle)/720) end local start_saucer = (saucer_sector_angle * j) - (value*saucer_sector_angle*0.5*thick_saucer_circ) local stop_saucer = (saucer_sector_angle * j) + (value*saucer_sector_angle*0.5*thick_saucer_circ) if total_angle < 0 then cairo_arc_negative(display, x, y, saucer_radius, angle_to_position(cup_start_angle, start_saucer), angle_to_position(cup_start_angle, stop_saucer)) else cairo_arc(display, x, y, saucer_radius, angle_to_position(cup_start_angle, start_saucer), angle_to_position(cup_start_angle, stop_saucer)) end cairo_set_source_rgba(display, rgb_to_r_g_b(saucer_fg_clr, saucer_fg_alpha)) cairo_set_line_width(display, saucer_thickness) cairo_stroke(display) --thin saucer if inner_saucer == true then rt = (saucer_radius - 0.5) + (0.5 * saucer_thickness) else rt = (saucer_radius + 0.5) - (0.5 * saucer_thickness) end local start_thin_saucer = (saucer_sector_angle * j) - (max_value *0.5*saucer_sector_angle*thin_saucer_circ) local stop_thin_saucer = (saucer_sector_angle * j) + (max_value *0.5*saucer_sector_angle*thin_saucer_circ) if total_angle < 0 then cairo_arc_negative(display, x, y, rt, angle_to_position(cup_start_angle, start_thin_saucer), angle_to_position(cup_start_angle, stop_thin_saucer)) else cairo_arc(display, x, y, rt, angle_to_position(cup_start_angle, start_thin_saucer), angle_to_position(cup_start_angle, stop_thin_saucer)) end cairo_set_source_rgba(display, rgb_to_r_g_b(saucer_fg_clr, saucer_fg_alpha)) cairo_set_line_width(display, 1) cairo_stroke(display) end --saucer mark if saucer_mark_fg_alpha > 0 then local start_cm = (saucer_sector_angle * value) - (handle_circ *0.5 ) local stop_cm = (saucer_sector_angle * value) + (handle_circ *0.5 ) if total_angle < 0 then cairo_arc_negative(display, x, y, saucer_radius, angle_to_position(cup_start_angle, start_cm), angle_to_position(cup_start_angle, stop_cm)) else cairo_arc(display, x, y, saucer_radius, angle_to_position(cup_start_angle, start_cm), angle_to_position(cup_start_angle, stop_cm)) end cairo_set_source_rgba(display, rgb_to_r_g_b(saucer_mark_fg_clr, saucer_mark_fg_alpha)) cairo_set_line_width(display, saucer_thickness) cairo_stroke(display) end --graduation mark if graduation_radius > 0 and graduation_thickness > 0 and graduation_mark_angle > 0 then number_graduation = (math.abs(total_angle) +1)/ graduation_mark_angle local start_arc_grad = 0 local stop_arc_grad = 0 local i = 0 while i < number_graduation do local start_arc_grad = (graduation_mark_angle * (i)) - (graduation_mark_circ *0.5) local stop_arc_grad = (graduation_mark_angle * (i)) + (graduation_mark_circ *0.5) if total_angle < 0 then cairo_arc_negative(display, x, y, graduation_radius, angle_to_position(cup_start_angle, start_arc_grad), angle_to_position(cup_start_angle, stop_arc_grad)) else cairo_arc(display, x, y, graduation_radius, angle_to_position(cup_start_angle, start_arc_grad), angle_to_position(cup_start_angle, stop_arc_grad)) end cairo_set_source_rgba(display,rgb_to_r_g_b(graduation_fg_clr,graduation_fg_alpha)) cairo_set_line_width(display, graduation_thickness) cairo_stroke(display) i = i + 1 end end -- text if txt_fg_alpha>0 then cairo_select_font_face (display, "hooge 05_53", CAIRO_FONT_SLANT_NORMAL, txt_weight); cairo_set_font_size (display,txt_size) cairo_set_source_rgba (display, rgb_to_r_g_b(txt_fg_clr, txt_fg_alpha)) cairo_move_to (display,x+xtxt,y+ytxt) cairo_show_text (display, caption ) cairo_show_text (display,value)cairo_show_text (display, caption2 ) cairo_stroke (display) end end ------------------------------------------------------------------------------- -- loads data and displays table_settings function display_coffee_table(display) local function load_coffee_table(display, data) local str, value = '', 0 if data['name'] == 'time2' then local max_value = data['max_value'] str = string.format('${time %s}', data['arg']) str = conky_parse(str) local value2 = tonumber(str:sub(0,2)) if value2 == max_value then value2 = 0 end value = value2 + (tonumber(str:sub(4,5))/60) else str = string.format('${%s %s}',data['name'], data['arg']) str = conky_parse(str) value = tonumber(str) end if value == nil then value = 0 end draw_coffee_table(display, data, value) end for i in pairs(coffee_table) do load_coffee_table(display, coffee_table[i]) end end ------------------------------------------------------------------------------- runscheck = 0 -- fix for draw shades running script twice on every update function conky_main() if conky_window == nil then return end local cs = cairo_xlib_surface_create(conky_window.display, conky_window.drawable, conky_window.visual, conky_window.width, conky_window.height) local display = cairo_create(cs) local updates = conky_parse('${updates}') update_num = tonumber(updates) if update_num > 5 then cairo_set_antialias (display, CAIRO_ANTIALIAS_SUBPIXEL) display_coffee_table(display) cairo_set_antialias (display, CAIRO_ANTIALIAS_DEFAULT) end cairo_surface_destroy(cs) cairo_destroy(display) end
clocks_rings.lua
--[[ Clock Rings by londonali1010 (2009) This script draws percentage meters as rings, and also draws clock hands if you want! It is fully customisable; all options are described in the script. This script is based off a combination of my clock.lua script and my rings.lua script. IMPORTANT: if you are using the 'cpu' function, it will cause a segmentation fault if it tries to draw a ring straight away. The if statement near the end of the script uses a delay to make sure that this doesn't happen. It calculates the length of the delay by the number of updates since Conky started. Generally, a value of 5s is long enough, so if you update Conky every 1s, use update_num > 5 in that if statement (the default). If you only update Conky every 2s, you should change it to update_num > 3; conversely if you update Conky every 0.5s, you should use update_num > 10. ALSO, if you change your Conky, is it best to use "killall conky; conky" to update it, otherwise the update_num will not be reset and you will get an error. To call this script in Conky, use the following (assuming that you save this script to ~/scripts/rings.lua): lua_load ~/scripts/clock_rings-v1.1.1.lua lua_draw_hook_pre clock_rings Changelog: + v1.1.1 -- Fixed minor bug that caused the script to crash if conky_parse() returns a nil value (20.10.2009) + v1.1 -- Added colour option for clock hands (07.10.2009) + v1.0 -- Original release (30.09.2009) ]] settings_table = { { -- Edit this table to customise your rings. -- You can create more rings simply by adding more elements to settings_table. -- "name" is the type of stat to display; you can choose from 'cpu', 'memperc', 'fs_used_perc', 'battery_used_perc'. name='time', -- "arg" is the argument to the stat type, e.g. if in Conky you would write ${cpu cpu0}, 'cpu0' would be the argument. If you would not use an argument in the Conky variable, use ''. arg='%I', -- "max" is the maximum value of the ring. If the Conky variable outputs a percentage, use 100. max=12, -- "bg_colour" is the colour of the base ring. bg_colour=0xFFFFFF, -- "bg_alpha" is the alpha value of the base ring. bg_alpha=0.0, -- "fg_colour" is the colour of the indicator part of the ring. fg_colour=0xFFFFFF, -- "fg_alpha" is the alpha value of the indicator part of the ring. fg_alpha=0.0, -- "x" and "y" are the x and y coordinates of the centre of the ring, relative to the top left corner of the Conky window. x=150, y=150, -- "radius" is the radius of the ring. radius=133, -- "thickness" is the thickness of the ring, centred around the radius. thickness=4, -- "start_angle" is the starting angle of the ring, in degrees, clockwise from top. Value can be either positive or negative. start_angle=0, -- "end_angle" is the ending angle of the ring, in degrees, clockwise from top. Value can be either positive or negative, but must be larger than start_angle. end_angle=360 }, { name='time', arg='%M', max=60, bg_colour=0xFFFFFF, bg_alpha=0.0, fg_colour=0xFFFFFF, fg_alpha=0.0, x=150, y=150, radius=140, thickness=4, start_angle=0, end_angle=360 }, { name='time', arg='%S', max=60, bg_colour=0xFFFFFF, bg_alpha=0.0, fg_colour=0xFFFFFF, fg_alpha=0.0, x=150, y=150, radius=147, thickness=4, start_angle=0, end_angle=360 }, } -- Use these settings to define the origin and extent of your clock. clock_r=127 -- "clock_x" and "clock_y" are the coordinates of the centre of the clock, in pixels, from the top left of the Conky window. clock_x=170 clock_y=170 -- Colour & alpha of the clock hands clock_colour=0xFFFFFF clock_alpha=1 -- Do you want to show the seconds hand? show_seconds=true require 'cairo' function rgb_to_r_g_b(colour,alpha) return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha end function draw_ring(cr,t,pt) local w,h=conky_window.width,conky_window.height local xc,yc,ring_r,ring_w,sa,ea=pt['x'],pt['y'],pt['radius'],pt['thickness'],pt['start_angle'],pt['end_angle'] local bgc, bga, fgc, fga=pt['bg_colour'], pt['bg_alpha'], pt['fg_colour'], pt['fg_alpha'] local angle_0=sa*(2*math.pi/360)-math.pi/2 local angle_f=ea*(2*math.pi/360)-math.pi/2 local t_arc=t*(angle_f-angle_0) -- Draw background ring cairo_arc(cr,xc,yc,ring_r,angle_0,angle_f) cairo_set_source_rgba(cr,rgb_to_r_g_b(bgc,bga)) cairo_set_line_width(cr,ring_w) cairo_stroke(cr) -- Draw indicator ring cairo_arc(cr,xc,yc,ring_r,angle_0,angle_0+t_arc) cairo_set_source_rgba(cr,rgb_to_r_g_b(fgc,fga)) cairo_stroke(cr) end function draw_clock_hands(cr,xc,yc) local secs,mins,hours,secs_arc,mins_arc,hours_arc local xh,yh,xm,ym,xs,ys secs=os.date("%S") mins=os.date("%M") hours=os.date("%I") secs_arc=(2*math.pi/60)*secs mins_arc=(2*math.pi/60)*mins+secs_arc/60 hours_arc=(2*math.pi/12)*hours+mins_arc/12 -- Draw hour hand xh=xc+0.7*clock_r*math.sin(hours_arc) yh=yc-0.7*clock_r*math.cos(hours_arc) cairo_move_to(cr,xc,yc) cairo_line_to(cr,xh,yh) cairo_set_line_cap(cr,CAIRO_LINE_CAP_ROUND) cairo_set_line_width(cr,5) cairo_set_source_rgba(cr,rgb_to_r_g_b(clock_colour,clock_alpha)) cairo_stroke(cr) -- Draw minute hand xm=xc+clock_r*math.sin(mins_arc) ym=yc-clock_r*math.cos(mins_arc) cairo_move_to(cr,xc,yc) cairo_line_to(cr,xm,ym) cairo_set_line_width(cr,3) cairo_stroke(cr) -- Draw seconds hand if show_seconds then xs=xc+clock_r*math.sin(secs_arc) ys=yc-clock_r*math.cos(secs_arc) cairo_move_to(cr,xc,yc) cairo_line_to(cr,xs,ys) cairo_set_line_width(cr,1) -- (cr,1) cairo_stroke(cr) end end function conky_clock_rings() local function setup_rings(cr,pt) local str='' local value=0 str=string.format('${%s %s}',pt['name'],pt['arg']) str=conky_parse(str) value=tonumber(str) if value == nil then value = 0 end pct=value/pt['max'] draw_ring(cr,pct,pt) end -- Check that Conky has been running for at least 5s if conky_window==nil then return end local cs=cairo_xlib_surface_create(conky_window.display,conky_window.drawable,conky_window.visual, conky_window.width,conky_window.height) local cr=cairo_create(cs) local updates=conky_parse('${updates}') update_num=tonumber(updates) if update_num>5 then for i in pairs(settings_table) do setup_rings(cr,settings_table[i]) end end draw_clock_hands(cr,clock_x,clock_y) end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif} ${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif} ${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif} ${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
conky lune
le pack @ prendre ici
Le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Monofur:bold:size=7',
own_window = true,
own_window_hints = 'undecorated,skip_taskbar,skip_pager,below',
draw_graph_borders = true,
stippled_borders = 8,
border_inner_margin = 4,
alignment = 'top_left',
minimum_width = 500,
minimum_height = 500,
gap_x = 130,
gap_y = 230,
no_buffers = false,
uppercase = false,
use_spacer = right,
text_buffer_size = 8192,
imlib_cache_size = 16384,
default_outline_color = '000000',
color1 = '000000',
color2 = '000000',
color3 = '828200',
color4 = '323200',
lua_load = '~/.conky/lua/image.lua',
conky.text = [[
${font Monofur:bold:size=12}${color5}${voffset -9}Phases de la lune ${color}${texeci 9500 bash $HOME/4_Moon/moon_MoonGiant}
${alignc 40}${color5}${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3}'`}${color}${font}
${lua fDrawImage $HOME/4_Moon/-2.png 10 65 60 60}
${lua fDrawImage $HOME/4_Moon/-1.png 80 65 60 60}
${lua fDrawImage $HOME/4_Moon/0.png 157 35 90 90}
${lua fDrawImage $HOME/4_Moon/1.png 265 65 60 60}
${lua fDrawImage $HOME/4_Moon/2.png 340 65 60 60}
${voffset 40}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${alignc 60}${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}
${voffset -42}${color5}${goto 15}${color5}${execi 3600 echo `date --date="-2 day" | awk '{print $2" "$3}'`}\
${goto 87}${execi 3600 echo `date --date="-1 day" | awk '{print $2" "$3}'`}\
${goto 347}${execi 3600 echo `date --date="+2 day" | awk '{print $2" "$3}'`}\
${goto 272}${execi 3600 echo `date --date="+1 day" | awk '{print $2" "$3}'`}${color}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${goto 15}${execpi 600 sed -n '13p' $HOME/4_Moon/raw-fr}\
${goto 87}${execpi 600 sed -n '21p' $HOME/4_Moon/raw-fr}\
${goto 272}${execpi 600 sed -n '29p' $HOME/4_Moon/raw-fr}\
${goto 347}${execpi 600 sed -n '37p' $HOME/4_Moon/raw-fr}
${alignc 40}${color5}Details pour ${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3" "$6}'`}${color}
Visibilité: ${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}${goto 250}Age: ${execpi 600 sed -n '5p' $HOME/4_Moon/raw} J
Angle du Soleil: ${execpi 600 sed -n '2p' $HOME/4_Moon/raw} ° ${goto 250}Angle de Lune: ${execpi 600 sed -n '6p' $HOME/4_Moon/raw} °
Distance du Soleil: ${execpi 600 sed -n '3p' $HOME/4_Moon/raw} kms${goto 250}Distance de la Lune: ${execpi 600 sed -n '4p' $HOME/4_Moon/raw} kms
${alignc 50}${color5}Position de la Lune${color}\
${lua fDrawImage $HOME/4_Moon/rise.png 0 294 400 130}\
${lua fDrawImage $HOME/4_Moon/0.png 45 370 30 30}\
${lua fDrawImage $HOME/4_Moon/0.png 325 370 30 30}\
${Lua fDrawImage $HOME/4_Moon/0.png 185 296 30 30}
#!/bin/bash
#function: moonrise_set
moonrise_set () {
case "$1" in
"FirstQuarter")
echo "Noon/Midnight"
cp $HOME/4_Moon/riseicons/rise_FirstQuarter.png $HOME/4_Moon/rise.png
"FullMoon")
echo "6PM/6AM"
cp $HOME/4_Moon/riseicons/rise_FullMoon.png $HOME/4_Moon/rise.png
"LastQuarter")
echo "Midnight/Noon"
cp $HOME/4_Moon/riseicons/rise_LastQuarter.png $HOME/4_Moon/rise.png
"NewMoon")
echo "6AM/6PM"
cp $HOME/4_Moon/riseicons/rise_NewMoon.png $HOME/4_Moon/rise.png
"WaningCrescent")
echo "3AM/3PM"
cp $HOME/4_Moon/riseicons/rise_WaningCrescent.png $HOME/4_Moon/rise.png
"WaningGibbous")
echo "9PM/9AM"
cp $HOME/4_Moon/riseicons/rise_WaningGibbous.png $HOME/4_Moon/rise.png
"WaxingCrescent")
echo "9AM/9PM"
cp $HOME/4_Moon/riseicons/rise_WaxingCrescent.png $HOME/4_Moon/rise.png
"WaxingGibbous")
echo "3PM/3AM"
cp $HOME/4_Moon/riseicons/rise_WaxingGibbous.png $HOME/4_Moon/rise.png
echo "Unavailable"
esac
kill -STOP $(pidof conky)
#put your hemisphere here: north or south
hemisphere=north
wget -O $HOME/4_Moon/raw "http://www.moongiant.com/phase/today"
rm $HOME/4_Moon/*.png
sed -i -e '/^ *$/d' -e 's/^ *//g' $HOME/4_Moon/raw
sed -i '/var jArray=\|"todayMoonContainer"\|"moonNotToday"/!d' $HOME/4_Moon/raw
sed -i -e '/var jArray/s/","/\n/g' -e 's/<span>\|<b>\|<\\\/span>\|<\\\/b>\|\\n//g' /$HOME/4_Moon/raw
sed -i -e '/var jArray/d' -e 's/^.*\:\[\"//g' /$HOME/4_Moon/raw
sed -i -e 's/"\]};//g' -e 's/^.*today_phase\///g' -e 's/\.jpg.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/^small\///g' -e 's/\.png.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/Illumination: \|Sun Angle: \|Sun Distance: \|Moon Distance: \|Moon Age: \|Moon Angle: //g' -e '43d' /$HOME/4_Moon/raw
#September 30-October 1 fix
for (( i=11; i<=35; i+=8 ))
do
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "September 30" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/Waning Crescent/" /$HOME/4_Moon/raw
fi
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "October 1" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/New Moon/" /$HOME/4_Moon/raw
fi
done
today_phase=$(sed -n 8p /$HOME/4_Moon/raw| awk -F "," '{print $2}'| sed 's/ //')
if [[ $today_phase == "September 30" ]]; then
sed -i '7s/^.*$/Waning Crescent/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: Waning Crescent/' /$HOME/4_Moon/raw
fi
if [[ $today_phase == "October 1" ]]; then
sed -i '7s/^.*$/New Moon/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: New Moon/' /$HOME/4_Moon/raw
fi
phase=$(sed -n 7p $HOME/4_Moon/raw|sed 's/ //')
mrise_mset=$(moonrise_set $phase)
sed -i 7a$(moonrise_set $phase) /$HOME/4_Moon/raw
#Day before Yesterday
img_in=$(sed -n 44p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-2.png
#Yesterday
img_in=$(sed -n 45p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-1.png
#Today
img_in=$(sed -n 46p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/0.png
#Tomorrow
img_in=$(sed -n 47p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/1.png
#Day after Tomorrow
img_in=$(sed -n 48p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/2.png
## English to French
cp $HOME/4_Moon/raw $HOME/4_Moon/raw-fr
if [[ -s $HOME/4_Moon/raw-fr ]]; then
sed -i -e 's/Full Moon/Pleine Lune/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Gibbous/Gibeuse décroissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Gibbous/Gibeuse croissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Crescent/Lune Montante/' $HOME/4_Moon/raw-fr
sed -i -e 's/First Quarter/Premier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Last Quarter/Dernier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Crescent/Lune Déscendante/' /$HOME/4_Moon/raw-fr
fi
kill -CONT $(pidof conky)
Diamond
(Pour la météo il faut toujours le pack de Théo accuweather)
un de mes vieux ensemble de conky mis en version 1.10
pas de lecteurs jouant
avec audacious
avec radiotray-ng
conkyrcs
time & weather
conky.config = {
background = true,
use_xft = true,
font = 'Liberation Sans:size=9',
xftalpha = 1,
own_window = true,
minimum_width = 470, minimum_height = 170,
maximum_width = 470,
gap_x = 30,
gap_y = 10,
no_buffers = true,
uppercase = false,
-- Taille des pointillés
-- Couleurs
default_color = '#ffffff',--ffd579
conky.text = [[
${execi 180 bash $HOME/1_accuweather/1_accuweather -f}
${font Liberation Sans:size=26}${alignc 20}${time %a %d %b %H:%M}${font}
${goto 70}----------------------------------------------------------------------------
${goto 30}Aujourdh'ui ${goto 110}demain\
${goto 190}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 270}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}${voffset -14}
${goto 360}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${font conkyweather:size=30}${voffset -30}
${goto 40}${execi 600 sed -n '601p' $HOME/1_accuweather/daily_forecast}\
${goto 110}${execi 600 sed -n '602p' $HOME/1_accuweather/daily_forecast}\
${goto 190}${execi 600 sed -n '603p' $HOME/1_accuweather/daily_forecast}\
${goto 270}${execi 600 sed -n '604p' $HOME/1_accuweather/daily_forecast}\
${goto 360}${execi 600 sed -n '605p' $HOME/1_accuweather/daily_forecast}${font}
${goto 40}${texeci 600 sed -n '68p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '47p' $HOME/1_accuweather/daily_forecast}°\
${goto 110}${texeci 600 sed -n '108p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '87p' $HOME/1_accuweather/daily_forecast}°\
${goto 190}${texeci 600 sed -n '148p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '127p' $HOME/1_accuweather/daily_forecast}°\
${goto 270}${texeci 600 sed -n '188p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '167p' $HOME/1_accuweather/daily_forecast}°\
${goto 360}${texeci 600 sed -n '228p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '207p' $HOME/1_accuweather/daily_forecast}°\
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 180 }
cpu
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
minimum_width = 470, minimum_height = 280,
gap_x = 00,
gap_y = 210,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${voffset 30}${offset 50}Cpu1:${color DDF2FF} ${offset 3}${cpu cpu1}%${alignr 90}${voffset -5}${color #DBDBDB}${cpugraph cpu1 20,240 f1f1f1 DBDBDB}${color}
${voffset -3}${offset 50}CPU Step: ${alignr 80}${color DDF2FF}${freq_g} GHz${color}
${voffset 12}${offset 50}Cpu2:${color DDF2FF} ${offset 3}${cpu cpu2}%${alignr 90}${voffset -9}${color #DDF2FF}${cpugraph cpu2 20,240 f1f1f1 DBDBDB}${color}
${voffset -5}${alignc 10}---------------------------------------------------------------------------------
${voffset 15}${offset 50}RAM: ${alignr 80} $mem/${color #DDF2FF}$memmax${color}
${offset 50}${color #DDF2FF}${membar 5,340}${color}
${offset 50}Swap: ${alignr 80} $swap / ${color #DDF2FF}$swapmax${color}
${offset 50}${color #DDF2FF}${swapbar 5,340}${color}
${offset 50}ROOT:${color #DDF2FF} ${alignr 80} ${fs_free /} / ${fs_size /}
${offset 50}${fs_bar 5,340 /}${color}
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 439 270}
network
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 30,
gap_y = 470,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${offset 25}${font Liberation Sans:size=11}SSID:${font} ${wireless_essid wlo1} ${goto 190}${font Liberation Sans:size=11}Sortant:${font} ${upspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Bitrate:${font} ${wireless_bitrate wlo1} ${goto 190}${font Liberation Sans:size=11}Entrant:${font} ${downspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Local:${font} ${addr wlo1} ${goto 190}${font Liberation Sans:size=11}Signal:${font} ${wireless_link_qual_perc wlo1}%
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 102}
${if_match "${wireless_link_qual_perc wlo1}"<"1"} ${lua fDrawImage ~/.conky/diamond/pix/nonetwork.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"20"}${lua fDrawImage ~/.conky/diamond/pix/networklow.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"50"}${lua fDrawImage ~/.conky/diamond/pix/networkmid.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"80"}${lua fDrawImage ~/.conky/diamond/pix/wlan80.png 300 25 45 45}${else}
${lua fDrawImage ~/.conky/diamond/pix/networkhigh.png 300 25 45 45}${endif}${endif}${endif}${endif}
audacious
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 30,
gap_y = 580,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[${if_running audacious}
${execi 3 ~/.conky/audacious/scripts/cover.sh}
${voffset -40}${font GE Inspira :size=12}
${goto 160}${execi 3 audtool current-song-tuple-data artist}${font}
${goto 160}${execi 3 audtool current-song-tuple-data title}
${goto 160}${execi 3 audtool current-song-tuple-data album}
${voffset 10}${goto 160}${execi 1 audtool current-song-output-length} ${goto 358}${execi 1 audtool current-song-length}\
${goto 184}${execbar 2, 168 expr 100 \* $(audtool --current-song-output-length-seconds) \/ $(audtool --current-song-length-seconds)}
${lua fDrawImage ~/.conky/audacious/audacious.png 44 14 68 70}
${else}
${if_running radiotray-ng}
${texeci 3 ~/.conky/radiotrayng/pochette.sh}${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 102}
${voffset -36}${alignc -80}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font
${voffset 33}${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 222 32 50 50} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 228 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 230 29 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 222 32 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"}${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 184 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "radio swiss pop"}${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 244 30 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "rfm"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 224 35 45 45} ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 30 10 78 78}
${else}
${lua fDrawImage ~/.conky/diamond/pochette.png 40 14 68 70}${endif}
${else}
${endif}
Conky radiotray-ng 2021 avec recherche de pochettes
le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Liberation Sans:size=7',
xftalpha = 1,
own_window = true,
minimum_width = 400, minimum_height = 100,
--maximum_width 200
gap_x = 780,
gap_y = 50,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${texeci 8 ~/.conky/radiotrayng/pochette.sh}
${voffset -4}${alignc -90}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font ${goto 340}Vol: ${exec amixer get Master | awk 'NR==5{print $4}' | tr -d {[]}}
${voffset 33}${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${lua fDrawImage $HOME/.conky/radiotrayng/images/case.png 0 0 410 108}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 240 32 50 50} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 248 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 250 29 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 240 32 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"} ${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 204 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Radio Swiss Pop"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 250 30 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RFM"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 244 35 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "80's & 90's hits"} ${lua fDrawImage ~/.conky/radiotrayng/logos/80-90.png 248 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Best Hits Radio 80's"}${lua fDrawImage ~/.conky/radiotrayng/logos/80.png 248 28 35 35} ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${else}${lua fDrawImage ~/pochette.png 24 14 68 70}${endif}
#${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${lua fDrawImage ~/.conky/radiotrayng/images/stop.png 115 31 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/prev.png 100 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/play.png 115 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/next.png 130 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/pause.png 115 59 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/bar.png 98 78 48 4}
${lua fDrawImage ~/.conky/radiotrayng/images/grip.png 115 78 5 5}
${lua fDrawImage ~/.conky/radiotrayng/images/1-play.png 155 15 10 10}
${voffset -800}
pochette.sh
#!/bin/bash
#créé par loutch
#2018-12-27 modifier par TeoBigusGeekus et loutch pour radiotray-ng et conky 1.10
#2021-02-20 modifier par nic80 et loutch
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep artist |sed 's/^.*" \: "//' |sed 's/",.*$//' > artiste_titre.txt
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep title |sed 's/^.*" \: "//' |sed 's/",.*$//' >> artiste_titre.txt
titre=$(cat artiste_titre.txt)
lynx --source -useragent="Googlebot-Image/1.0" "www.google.com/search?q=$titre\&tbm=isch" | perl -pe 's!.*<img .* src="([^"]*)".*!$1!' > lienMiniaturefile
sed -i 's/^.* http\:/http\:/' lienMiniaturefile
sed -i '/gstatic/!d' lienMiniaturefile
lienMiniature=$(cat lienMiniaturefile)
lynx -dump "$lienMiniature" > miniatureGoogleImage
Météo +Lune
Il faut les deux packs de TeoBigusGeekus du forum Bunsenlabs et le pack meteo+lune 4
Accuweather
https://gitlab.com/teobigusgeekus/Accuweather_conky_script.git
Moongiant
https://gitlab.com/teobigusgeekus/Moongiant_conky_script.git
meteo+lune4
https://www.gnome-look.org/p/1155399/
le conkyrc
conky.config ={
no_buffers = true,
imlib_cache_size = 0,
cpu_avg_samples = 1,
minimum_width = 410, minimum_height = 981,
maximum_width = 430,
gap_x = 5,
gap_y = 0,
border_inner_margin = 0,
border_outer_margin = 0,
background = true,
own_window = true,
own_window_hints = 'undecorated,below,skip_taskbar,skip_pager,',
use_xft = true,
xftalpha = 1,
font = 'CorporateMonoExtraBold:size=10',
uppercase = false,
default_color = '#FFFFFF',
default_shade_color = '#000000',
color1 = 'b9b4b0', -- gris rosé
color2 = 'CA0000', -- rouge
color3 = '386fd5', -- bleu argent
color6 = 'b10ab3', -- mauve
color7 = 'f3ec1f', -- jaune
color8 = 'CCCCCC',
color9 = 'BBBBBB',
template1 = [[${font CorporateMonoExtraBold:size=\1}]],
template2 = [[${font Folks-Heavy:style=Bold:size=\1}]],
template3 = [[${font Liberation Sans:size=\1}]],
conky.text = [[
${texeci 900 bash $HOME/Accuweather_conky_script/accuweather -f2015} ${texeci 3600 bash $HOME/Wunderground_conky_script/wunderground}${texeci 9500 bash $HOME/Moongiant_conky_script/moon_MoonGiant}
${voffset 15}${alignc}${color1}Sarreguemines
${alignc}${color1}${execi 600 sed -n '4p' $HOME/Accuweather_conky_script/curr_cond}
${voffset 10}${goto 120}${color3}Humidité: ${alignr 10}${color1}${texeci 600 sed -n '7p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Pression: ${alignr 10}${color1}${texeci 600 sed -n '8p' $HOME/Accuweather_conky_script/curr_cond | awk '{print $2}'} mbar
${goto 120}${color3}Indice UV: ${alignr 10}${color1}${texeci 600 sed -n '9p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Converture nuageuse: ${alignr 3}${color1}${texeci 600 sed -n '10p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Point de rosée: ${alignr 10}${color1}${texeci 600 sed -n '12p' $HOME/Accuweather_conky_script/curr_cond}°C
${goto 120}${color3}Visibilité: ${alignr 10}${color1}${execi 600 sed -n '13p' $HOME/Accuweather_conky_script/curr_cond}s
${goto 120}${color3}Lever/Coucher: ${alignr 10}${color1}${execi 600 sed -n '14p' $HOME/Accuweather_conky_script/curr_cond} / ${execi 600 sed -n '15p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Vent: ${alignr 10}${color1}${execi 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond} ${texeci 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond > $HOME/Accuweather_conky_script/vent}
${goto 120}${color3}Vitesse: ${alignr 10}${color1}${execi 600 sed -n '6p' $HOME/Accuweather_conky_script/curr_cond}
${voffset -90}${goto 30}${color1}${template1 14}T: ${execi 600 sed -n '2p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 10} ${goto 30}${color1}${template1 14}R: ${execi 600 sed -n '3p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 90}${template1 9}
${goto 100}Aujourd'hui ${goto 280}Demain
${goto 120}${color3}${texeci 600 sed -n '5p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${texeci 600 sed -n '4p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 280}${color3}${execpi 600 sed -n '12p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '11p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 80}${scroll 16 ${execpi 600 sed -n '6p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 240}${scroll 16 ${execpi 600 sed -n '13p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 60}
${goto 70}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 195}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}\
${goto 320}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${goto 70}${color3}${execpi 600 sed -n '19p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '18p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 195}${color3}${execpi 600 sed -n '26p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '25p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 320}${color3}${execpi 600 sed -n '33p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '32p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 55}${scroll 12 ${execpi 600 sed -n '20p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 180}${scroll 12 ${execpi 600 sed -n '27p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 305}${scroll 12 ${execpi 600 sed -n '34p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 75}${alignc}${color1}${template1 15}Calendrier Lunaire${font}
${voffset -5}${alignc}${color2}${template1 9}( Hémisphère Nord en GMT+1 Paris )${font}
${offset 40}
${alignc}${color3}Lever/Coucher:${color2}${template7 9}( Heure locale )$font
${alignc} ${template3 11}↑ ${template1 10}${execi 600 sed -n '18p' $HOME/Accuweather_conky_script/curr_cond} ${template3 11}↓ ${template1 10}${execi 600 sed -n '19p' $HOME/Accuweather_conky_script/curr_cond} = ${execi 600 sed -n '20p' $HOME/Accuweather_conky_script/curr_cond}
${alignc}${color3}Phase ${color1}${execpi 600 sed -n '1p' $HOME/Wunderground_conky_script/lune}
${template2 9}${voffset 20}
${goto 30}Visibilité: ${execpi 600 sed -n '23p' $HOME/Moongiant_conky_script/raw} ${goto 260}Angle: ${execpi 600 sed -n '25p' $HOME/Moongiant_conky_script/raw} °
${goto 30}Age: ${execpi 600 sed -n '24p' $HOME/Moongiant_conky_script/raw | awk '{print $1}'} Jour(s) ${goto 260}Dist.: ${execpi 600 sed -n '26p' $HOME/Moongiant_conky_script/raw}s
${voffset 80}${alignc}${color1}${template1 15}Éphéméride ${font}
${alignc}${color1}Saint(e) du jour
${alignc}${color2}${texeci 1000 wget -O - -q http://fetedujour.fr/ --user-agent="Mozilla/5.0 (Windows NT 5.1; rv:31.0) Gecko/20100101 Firefox/31.0" | grep h2 | head -1 | cut -d">" -f2 | cut -d"<" -f1 | cut -d":" -f2 }
#fond verticale
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/fond23x866.png 0 115 23 866}
#ligne rouge
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 90 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 306 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 582 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 850 380 12}
#texte vertical
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/lateralf.png 4 125 15 851}
#icones
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_0.png 20 100 115 69}
${lua fDrawImage $HOME/Accuweather_conky_script/Wind1.png 40 220 70 70}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_1.png 100 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_2.png 260 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_3.png 45 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_4.png 170 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_5.png 295 510 90 52}
${lua fDrawImage $HOME/Wunderground_conky_script/Forecast_Images/Moon_phase.png 160 730 90 90}
Lanceur multi-lua
Avec la nouvelle syntaxe voici comment avoir un conky qui @ besoin de plusieurs scripts lua comme sur la version 1.09.
On va créer un fichier
" loader.lua" que l'on va appeler comme ceci dans le conky avant la partie conki.text=[[
lua_load = '~/chemin/du/dossier/loader.lua',
lua_draw_hook_pre = 'loader_lua',
loader.lua
require 'cairo'
function conky_loader_lua()
usrhome = os.getenv("HOME")
dofile (usrhome .."/.conky/olgmen/scripts/datah.lua")
dofile (usrhome .."/.conky/olgmen/scripts/draw_bg.lua")
dofile (usrhome .."/.conky/lua/image.lua")
conky_widgets()
end
- dofile .......datah.lua premier lua
-dofile .........draw_bg deuxième lua
-dofile ..........image.lua troisième lua
conky_widgets est la fonction du premier lua
les deux autres lua n'ont pas de fonction donc on ne mets rien.
un autre lanceur
require 'cairo'
dofile (usrhome .."/.conky/cronograph/scripts/clock_rings.lua")
dofile (usrhome .."/.conky/cronograph/scripts/multi_rings.lua")
dofile (usrhome .."/.conky/lua/draw_bg.lua")
conky_main()
conky_clock_rings()
end
Exemple
Un conky quatre lua .
