Dernière mise à jour : 27/09/2021 à 08h54
Chronographe
conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'hooge 05_53:size=6',
xftalpha = 1,
update_interval = 1.0,
total_run_times = 0,
net_avg_samples = 2,
own_window = true,
--own_window_color 000000
own_window_type = 'normal',
double_buffer = true,
maximum_width = 320,
text_buffer_size = 2048,
draw_shades = false,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
default_color = 'white',
alignment = 'top_right',
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
cpu_avg_samples = 2,
override_utf8_locale = true,
imlib_cache_size = 10000,
stippled_borders = 5,
-- Couleurs
default_color = '#ffffff', --ffd579
default_shade_color = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600 sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600 sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600 sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600 sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600 sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600 sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600 sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '18p' $HOME/1_accuweather/first_days}°C
]];conkyrc1 (pour le deuxième lua)
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
]];cups.lua
-- Cups and Saucers
-- Lua conky script
-- author : Abu Yahya
-- license : Distributed under the terms of GNU GPL v3
-- 30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
name='time', arg='%I', max_value=12,
x=170, y=170,
cup_radius=35,
cup_wall_thickness=90,
cup_bg_clr=0xffffff, cup_bg_alpha=0.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0,
handle_length=70, handle_circ=5,
handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0
graduation_radius=124,
graduation_thickness=8, graduation_mark_circ=1.5,
graduation_mark_angle=30,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5,
saucer_thickness=6, thick_saucer_circ=11/12,
saucer_radius=135, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0,
inner_saucer=true,
txt_weight=0, txt_size=8.0,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0,
caption='', caption2='',
name='time', arg='%H', max_value=12,
x=170, y=170,
cup_radius=2.5,
cup_wall_thickness=3,
cup_bg_clr=0xffffff, cup_bg_alpha=1.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=1.0,
handle_length=40, handle_circ=4,
graduation_radius=127,
graduation_thickness=1, graduation_mark_circ=0.5,
graduation_mark_angle=3,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.0,
inner_saucer=true,
name='time', arg='%M', max_value=60,
x=170, y=170,
cup_radius=55,
cup_wall_thickness=120,
graduation_radius=123,
graduation_thickness=10, graduation_mark_circ=2.5,
graduation_mark_angle=90,
handle_length=110, handle_circ=3,
saucer_radius=155, thin_saucer_circ=11/12,
name='time', arg='%S', max_value=60,
x=170, y=170,
cup_radius=59,
handle_length=118, handle_circ=1,
graduation_radius=125,
graduation_thickness=6, graduation_mark_circ=0.5,
graduation_mark_angle=6,
saucer_thickness=5, thick_saucer_circ=1,
saucer_radius=145, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.4,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.4,
name='cpu', arg='cpu0', max_value=100,
x=170, y=100,
cup_radius=20,
cup_wall_thickness=40,
cup_start_angle=0,
cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=1,
caption=' CPU ', caption2=' %',
graduation_radius=25,
graduation_thickness=3, graduation_mark_circ=2,
graduation_mark_angle=36,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6,
saucer_thickness=3, thick_saucer_circ=0.85,
saucer_radius=30, thin_saucer_circ=0.85,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5,
inner_saucer=true,
name='freq_g', arg='/', max_value=5,
x=170, y=100,
cup_radius=12,
cup_wall_thickness=23,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='', caption2=' GHz',
graduation_thickness=4, graduation_mark_circ=4,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0,
saucer_thickness=3, thick_saucer_circ=0.75,
saucer_radius=35, thin_saucer_circ=0.75,
---------------1/2
name='downspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
caption='E. ', caption2='',
inner_saucer=true,
name='upspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_wall_thickness=27,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='S ', caption2='',
saucer_radius=35, thin_saucer_circ=0.85,
------------------2/3
name='fs_used_perc', arg='/home', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption=' FS /: ', caption2=' %',
inner_saucer=true,
name='fs_used_perc', arg='/', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.8,
caption=' FS H: ', caption2=' %',
end
-- displays cups and saucers
max_value = data['max_value']
x, y = data['x'], data['y']
caption = data['caption']
caption2 = data['caption2']
if xtxt ==nil then xtxt=0 end
if ytxt ==nil then ytxt=0 end
if total_angle < 0 then
else
end
end
--cup centre background
if cup_bg_alpha >0 then
else
end
cairo_stroke(display)
end
--cup wall fg
if cup_fg_alpha > 0 then
else
end
end
-- cup handle
if handle_fg_alpha>0 then
local stop_handle = (cup_sector_angle * value) + (handle_circ*0.5)
else
end
end
--saucers
---thick saucer
then
if value < (max_value/2)
end
else
end
--thin saucer
if inner_saucer == true
end
else
end
end
--saucer mark
else
end
end
--graduation mark
local start_arc_grad = 0
local stop_arc_grad = 0
local i = 0
else
end
i = i + 1
end
end
-- text
if txt_fg_alpha>0 then
cairo_stroke (display)
end
end
local str, value = '', 0
str = conky_parse(str)
else
value = tonumber(str)
end
end
end
end
function conky_main()
if conky_window == nil then
return
end
if update_num > 5 then
end
cairo_surface_destroy(cs)
cairo_destroy(display)
end
clocks_rings.lua
lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
name='time',
arg='%I',
max=12,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=133,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%M',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=140,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%S',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=147,
thickness=4,
start_angle=0,
end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
-- Draw background ring
cairo_stroke(cr)
-- Draw indicator ring
cairo_stroke(cr)
end
local xh,yh,xm,ym,xs,ys
secs=os.date("%S")
mins=os.date("%M")
hours=os.date("%I")
secs_arc=(2*math.pi/60)*secs
-- Draw hour hand
cairo_move_to(cr,xc,yc)
cairo_line_to(cr,xh,yh)
cairo_set_line_width(cr,5)
cairo_stroke(cr)
-- Draw minute hand
cairo_line_to(cr,xm,ym)
cairo_set_line_width(cr,3)
cairo_stroke(cr)
-- Draw seconds hand
if show_seconds then
cairo_line_to(cr,xs,ys)
cairo_stroke(cr)
end
end
function conky_clock_rings()
local str=''
local value=0
str=conky_parse(str)
value=tonumber(str)
pct=value/pt['max']
draw_ring(cr,pct,pt)
end
local cr=cairo_create(cs)
update_num=tonumber(updates)
if update_num>5 then
end
end
end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
conky lune
le pack @ prendre ici
Le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Monofur:bold:size=7',
own_window = true,
own_window_hints = 'undecorated,skip_taskbar,skip_pager,below',
draw_graph_borders = true,
stippled_borders = 8,
border_inner_margin = 4,
alignment = 'top_left',
minimum_width = 500,
minimum_height = 500,
gap_x = 130,
gap_y = 230,
no_buffers = false,
uppercase = false,
use_spacer = right,
text_buffer_size = 8192,
imlib_cache_size = 16384,
default_outline_color = '000000',
color1 = '000000',
color2 = '000000',
color3 = '828200',
color4 = '323200',
lua_load = '~/.conky/lua/image.lua',
conky.text = [[
${font Monofur:bold:size=12}${color5}${voffset -9}Phases de la lune ${color}${texeci 9500 bash $HOME/4_Moon/moon_MoonGiant}
${alignc 40}${color5}${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3}'`}${color}${font}
${lua fDrawImage $HOME/4_Moon/-2.png 10 65 60 60}
${lua fDrawImage $HOME/4_Moon/-1.png 80 65 60 60}
${lua fDrawImage $HOME/4_Moon/0.png 157 35 90 90}
${lua fDrawImage $HOME/4_Moon/1.png 265 65 60 60}
${lua fDrawImage $HOME/4_Moon/2.png 340 65 60 60}
${voffset 40}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${alignc 60}${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}
${voffset -42}${color5}${goto 15}${color5}${execi 3600 echo `date --date="-2 day" | awk '{print $2" "$3}'`}\
${goto 87}${execi 3600 echo `date --date="-1 day" | awk '{print $2" "$3}'`}\
${goto 347}${execi 3600 echo `date --date="+2 day" | awk '{print $2" "$3}'`}\
${goto 272}${execi 3600 echo `date --date="+1 day" | awk '{print $2" "$3}'`}${color}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${goto 15}${execpi 600 sed -n '13p' $HOME/4_Moon/raw-fr}\
${goto 87}${execpi 600 sed -n '21p' $HOME/4_Moon/raw-fr}\
${goto 272}${execpi 600 sed -n '29p' $HOME/4_Moon/raw-fr}\
${goto 347}${execpi 600 sed -n '37p' $HOME/4_Moon/raw-fr}
${alignc 40}${color5}Details pour ${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3" "$6}'`}${color}
Visibilité: ${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}${goto 250}Age: ${execpi 600 sed -n '5p' $HOME/4_Moon/raw} J
Angle du Soleil: ${execpi 600 sed -n '2p' $HOME/4_Moon/raw} ° ${goto 250}Angle de Lune: ${execpi 600 sed -n '6p' $HOME/4_Moon/raw} °
Distance du Soleil: ${execpi 600 sed -n '3p' $HOME/4_Moon/raw} kms${goto 250}Distance de la Lune: ${execpi 600 sed -n '4p' $HOME/4_Moon/raw} kms
${alignc 50}${color5}Position de la Lune${color}\
${lua fDrawImage $HOME/4_Moon/rise.png 0 294 400 130}\
${lua fDrawImage $HOME/4_Moon/0.png 45 370 30 30}\
${lua fDrawImage $HOME/4_Moon/0.png 325 370 30 30}\
${Lua fDrawImage $HOME/4_Moon/0.png 185 296 30 30}
#!/bin/bash
#function: moonrise_set
moonrise_set () {
case "$1" in
"FirstQuarter")
echo "Noon/Midnight"
cp $HOME/4_Moon/riseicons/rise_FirstQuarter.png $HOME/4_Moon/rise.png
"FullMoon")
echo "6PM/6AM"
cp $HOME/4_Moon/riseicons/rise_FullMoon.png $HOME/4_Moon/rise.png
"LastQuarter")
echo "Midnight/Noon"
cp $HOME/4_Moon/riseicons/rise_LastQuarter.png $HOME/4_Moon/rise.png
"NewMoon")
echo "6AM/6PM"
cp $HOME/4_Moon/riseicons/rise_NewMoon.png $HOME/4_Moon/rise.png
"WaningCrescent")
echo "3AM/3PM"
cp $HOME/4_Moon/riseicons/rise_WaningCrescent.png $HOME/4_Moon/rise.png
"WaningGibbous")
echo "9PM/9AM"
cp $HOME/4_Moon/riseicons/rise_WaningGibbous.png $HOME/4_Moon/rise.png
"WaxingCrescent")
echo "9AM/9PM"
cp $HOME/4_Moon/riseicons/rise_WaxingCrescent.png $HOME/4_Moon/rise.png
"WaxingGibbous")
echo "3PM/3AM"
cp $HOME/4_Moon/riseicons/rise_WaxingGibbous.png $HOME/4_Moon/rise.png
echo "Unavailable"
esac
kill -STOP $(pidof conky)
#put your hemisphere here: north or south
hemisphere=north
wget -O $HOME/4_Moon/raw "http://www.moongiant.com/phase/today"
rm $HOME/4_Moon/*.png
sed -i -e '/^ *$/d' -e 's/^ *//g' $HOME/4_Moon/raw
sed -i '/var jArray=\|"todayMoonContainer"\|"moonNotToday"/!d' $HOME/4_Moon/raw
sed -i -e '/var jArray/s/","/\n/g' -e 's/<span>\|<b>\|<\\\/span>\|<\\\/b>\|\\n//g' /$HOME/4_Moon/raw
sed -i -e '/var jArray/d' -e 's/^.*\:\[\"//g' /$HOME/4_Moon/raw
sed -i -e 's/"\]};//g' -e 's/^.*today_phase\///g' -e 's/\.jpg.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/^small\///g' -e 's/\.png.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/Illumination: \|Sun Angle: \|Sun Distance: \|Moon Distance: \|Moon Age: \|Moon Angle: //g' -e '43d' /$HOME/4_Moon/raw
#September 30-October 1 fix
for (( i=11; i<=35; i+=8 ))
do
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "September 30" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/Waning Crescent/" /$HOME/4_Moon/raw
fi
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "October 1" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/New Moon/" /$HOME/4_Moon/raw
fi
done
today_phase=$(sed -n 8p /$HOME/4_Moon/raw| awk -F "," '{print $2}'| sed 's/ //')
if [[ $today_phase == "September 30" ]]; then
sed -i '7s/^.*$/Waning Crescent/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: Waning Crescent/' /$HOME/4_Moon/raw
fi
if [[ $today_phase == "October 1" ]]; then
sed -i '7s/^.*$/New Moon/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: New Moon/' /$HOME/4_Moon/raw
fi
phase=$(sed -n 7p $HOME/4_Moon/raw|sed 's/ //')
mrise_mset=$(moonrise_set $phase)
sed -i 7a$(moonrise_set $phase) /$HOME/4_Moon/raw
#Day before Yesterday
img_in=$(sed -n 44p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-2.png
#Yesterday
img_in=$(sed -n 45p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-1.png
#Today
img_in=$(sed -n 46p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/0.png
#Tomorrow
img_in=$(sed -n 47p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/1.png
#Day after Tomorrow
img_in=$(sed -n 48p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/2.png
## English to French
cp $HOME/4_Moon/raw $HOME/4_Moon/raw-fr
if [[ -s $HOME/4_Moon/raw-fr ]]; then
sed -i -e 's/Full Moon/Pleine Lune/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Gibbous/Gibeuse décroissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Gibbous/Gibeuse croissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Crescent/Lune Montante/' $HOME/4_Moon/raw-fr
sed -i -e 's/First Quarter/Premier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Last Quarter/Dernier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Crescent/Lune Déscendante/' /$HOME/4_Moon/raw-fr
fi
kill -CONT $(pidof conky)
Diamond
(Pour la météo il faut toujours le pack de Théo accuweather)
un de mes vieux ensemble de conky mis en version 1.10
pas de lecteurs jouant
avec audacious
avec radiotray-ng
conkyrcs
time & weather
conky.config = {
background = true,
use_xft = true,
font = 'Liberation Sans:size=9',
xftalpha = 1,
own_window = true,
minimum_width = 470, minimum_height = 170,
maximum_width = 470,
gap_x = 30,
gap_y = 10,
no_buffers = true,
uppercase = false,
-- Taille des pointillés
-- Couleurs
default_color = '#ffffff',--ffd579
conky.text = [[
${execi 180 bash $HOME/1_accuweather/1_accuweather -f}
${font Liberation Sans:size=26}${alignc 20}${time %a %d %b %H:%M}${font}
${goto 70}----------------------------------------------------------------------------
${goto 30}Aujourdh'ui ${goto 110}demain\
${goto 190}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 270}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}${voffset -14}
${goto 360}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${font conkyweather:size=30}${voffset -30}
${goto 40}${execi 600 sed -n '601p' $HOME/1_accuweather/daily_forecast}\
${goto 110}${execi 600 sed -n '602p' $HOME/1_accuweather/daily_forecast}\
${goto 190}${execi 600 sed -n '603p' $HOME/1_accuweather/daily_forecast}\
${goto 270}${execi 600 sed -n '604p' $HOME/1_accuweather/daily_forecast}\
${goto 360}${execi 600 sed -n '605p' $HOME/1_accuweather/daily_forecast}${font}
${goto 40}${texeci 600 sed -n '68p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '47p' $HOME/1_accuweather/daily_forecast}°\
${goto 110}${texeci 600 sed -n '108p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '87p' $HOME/1_accuweather/daily_forecast}°\
${goto 190}${texeci 600 sed -n '148p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '127p' $HOME/1_accuweather/daily_forecast}°\
${goto 270}${texeci 600 sed -n '188p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '167p' $HOME/1_accuweather/daily_forecast}°\
${goto 360}${texeci 600 sed -n '228p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '207p' $HOME/1_accuweather/daily_forecast}°\
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 180 }
cpu
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
minimum_width = 470, minimum_height = 280,
gap_x = 00,
gap_y = 210,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${voffset 30}${offset 50}Cpu1:${color DDF2FF} ${offset 3}${cpu cpu1}%${alignr 90}${voffset -5}${color #DBDBDB}${cpugraph cpu1 20,240 f1f1f1 DBDBDB}${color}
${voffset -3}${offset 50}CPU Step: ${alignr 80}${color DDF2FF}${freq_g} GHz${color}
${voffset 12}${offset 50}Cpu2:${color DDF2FF} ${offset 3}${cpu cpu2}%${alignr 90}${voffset -9}${color #DDF2FF}${cpugraph cpu2 20,240 f1f1f1 DBDBDB}${color}
${voffset -5}${alignc 10}---------------------------------------------------------------------------------
${voffset 15}${offset 50}RAM: ${alignr 80} $mem/${color #DDF2FF}$memmax${color}
${offset 50}${color #DDF2FF}${membar 5,340}${color}
${offset 50}Swap: ${alignr 80} $swap / ${color #DDF2FF}$swapmax${color}
${offset 50}${color #DDF2FF}${swapbar 5,340}${color}
${offset 50}ROOT:${color #DDF2FF} ${alignr 80} ${fs_free /} / ${fs_size /}
${offset 50}${fs_bar 5,340 /}${color}
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 439 270}
network
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 30,
gap_y = 470,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${offset 25}${font Liberation Sans:size=11}SSID:${font} ${wireless_essid wlo1} ${goto 190}${font Liberation Sans:size=11}Sortant:${font} ${upspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Bitrate:${font} ${wireless_bitrate wlo1} ${goto 190}${font Liberation Sans:size=11}Entrant:${font} ${downspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Local:${font} ${addr wlo1} ${goto 190}${font Liberation Sans:size=11}Signal:${font} ${wireless_link_qual_perc wlo1}%
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 102}
${if_match "${wireless_link_qual_perc wlo1}"<"1"} ${lua fDrawImage ~/.conky/diamond/pix/nonetwork.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"20"}${lua fDrawImage ~/.conky/diamond/pix/networklow.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"50"}${lua fDrawImage ~/.conky/diamond/pix/networkmid.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"80"}${lua fDrawImage ~/.conky/diamond/pix/wlan80.png 300 25 45 45}${else}
${lua fDrawImage ~/.conky/diamond/pix/networkhigh.png 300 25 45 45}${endif}${endif}${endif}${endif}
audacious
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 30,
gap_y = 580,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[${if_running audacious}
${execi 3 ~/.conky/audacious/scripts/cover.sh}
${voffset -40}${font GE Inspira :size=12}
${goto 160}${execi 3 audtool current-song-tuple-data artist}${font}
${goto 160}${execi 3 audtool current-song-tuple-data title}
${goto 160}${execi 3 audtool current-song-tuple-data album}
${voffset 10}${goto 160}${execi 1 audtool current-song-output-length} ${goto 358}${execi 1 audtool current-song-length}\
${goto 184}${execbar 2, 168 expr 100 \* $(audtool --current-song-output-length-seconds) \/ $(audtool --current-song-length-seconds)}
${lua fDrawImage ~/.conky/audacious/audacious.png 44 14 68 70}
${else}
${if_running radiotray-ng}
${texeci 3 ~/.conky/radiotrayng/pochette.sh}${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 102}
${voffset -36}${alignc -80}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font
${voffset 33}${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 222 32 50 50} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 228 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 230 29 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 222 32 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"}${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 184 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "radio swiss pop"}${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 244 30 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "rfm"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 224 35 45 45} ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 30 10 78 78}
${else}
${lua fDrawImage ~/.conky/diamond/pochette.png 40 14 68 70}${endif}
${else}
${endif}
Conky radiotray-ng 2021 avec recherche de pochettes
le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Liberation Sans:size=7',
xftalpha = 1,
own_window = true,
minimum_width = 400, minimum_height = 100,
--maximum_width 200
gap_x = 780,
gap_y = 50,
no_buffers = true,
uppercase = false,
-- Couleurs
conky.text = [[
${texeci 8 ~/.conky/radiotrayng/pochette.sh}
${voffset -4}${alignc -90}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font ${goto 340}Vol: ${exec amixer get Master | awk 'NR==5{print $4}' | tr -d {[]}}
${voffset 33}${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
${alignc}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${lua fDrawImage $HOME/.conky/radiotrayng/images/case.png 0 0 410 108}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 240 32 50 50} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 248 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 250 29 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 240 32 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"} ${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 204 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Radio Swiss Pop"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 250 30 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RFM"} ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 244 35 45 45} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "80's & 90's hits"} ${lua fDrawImage ~/.conky/radiotrayng/logos/80-90.png 248 28 35 35} ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Best Hits Radio 80's"}${lua fDrawImage ~/.conky/radiotrayng/logos/80.png 248 28 35 35} ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${else}${lua fDrawImage ~/pochette.png 24 14 68 70}${endif}
#${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 19 10 78 78}
${lua fDrawImage ~/.conky/radiotrayng/images/stop.png 115 31 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/prev.png 100 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/play.png 115 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/next.png 130 45 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/pause.png 115 59 13 13}
${lua fDrawImage ~/.conky/radiotrayng/images/bar.png 98 78 48 4}
${lua fDrawImage ~/.conky/radiotrayng/images/grip.png 115 78 5 5}
${lua fDrawImage ~/.conky/radiotrayng/images/1-play.png 155 15 10 10}
${voffset -800}
pochette.sh
#!/bin/bash
#créé par loutch
#2018-12-27 modifier par TeoBigusGeekus et loutch pour radiotray-ng et conky 1.10
#2021-02-20 modifier par nic80 et loutch
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep artist |sed 's/^.*" \: "//' |sed 's/",.*$//' > artiste_titre.txt
qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | grep title |sed 's/^.*" \: "//' |sed 's/",.*$//' >> artiste_titre.txt
titre=$(cat artiste_titre.txt)
lynx --source -useragent="Googlebot-Image/1.0" "www.google.com/search?q=$titre\&tbm=isch" | perl -pe 's!.*<img .* src="([^"]*)".*!$1!' > lienMiniaturefile
sed -i 's/^.* http\:/http\:/' lienMiniaturefile
sed -i '/gstatic/!d' lienMiniaturefile
lienMiniature=$(cat lienMiniaturefile)
lynx -dump "$lienMiniature" > miniatureGoogleImage
Météo +Lune
Il faut les deux packs de TeoBigusGeekus du forum Bunsenlabs et le pack meteo+lune 4
Accuweather
https://gitlab.com/teobigusgeekus/Accuweather_conky_script.git
Moongiant
https://gitlab.com/teobigusgeekus/Moongiant_conky_script.git
meteo+lune4
https://www.gnome-look.org/p/1155399/
le conkyrc
conky.config ={
no_buffers = true,
imlib_cache_size = 0,
cpu_avg_samples = 1,
minimum_width = 410, minimum_height = 981,
maximum_width = 430,
gap_x = 5,
gap_y = 0,
border_inner_margin = 0,
border_outer_margin = 0,
background = true,
own_window = true,
own_window_hints = 'undecorated,below,skip_taskbar,skip_pager,',
use_xft = true,
xftalpha = 1,
font = 'CorporateMonoExtraBold:size=10',
uppercase = false,
default_color = '#FFFFFF',
default_shade_color = '#000000',
color1 = 'b9b4b0', -- gris rosé
color2 = 'CA0000', -- rouge
color3 = '386fd5', -- bleu argent
color6 = 'b10ab3', -- mauve
color7 = 'f3ec1f', -- jaune
color8 = 'CCCCCC',
color9 = 'BBBBBB',
template1 = [[${font CorporateMonoExtraBold:size=\1}]],
template2 = [[${font Folks-Heavy:style=Bold:size=\1}]],
template3 = [[${font Liberation Sans:size=\1}]],
conky.text = [[
${texeci 900 bash $HOME/Accuweather_conky_script/accuweather -f2015} ${texeci 3600 bash $HOME/Wunderground_conky_script/wunderground}${texeci 9500 bash $HOME/Moongiant_conky_script/moon_MoonGiant}
${voffset 15}${alignc}${color1}Sarreguemines
${alignc}${color1}${execi 600 sed -n '4p' $HOME/Accuweather_conky_script/curr_cond}
${voffset 10}${goto 120}${color3}Humidité: ${alignr 10}${color1}${texeci 600 sed -n '7p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Pression: ${alignr 10}${color1}${texeci 600 sed -n '8p' $HOME/Accuweather_conky_script/curr_cond | awk '{print $2}'} mbar
${goto 120}${color3}Indice UV: ${alignr 10}${color1}${texeci 600 sed -n '9p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Converture nuageuse: ${alignr 3}${color1}${texeci 600 sed -n '10p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Point de rosée: ${alignr 10}${color1}${texeci 600 sed -n '12p' $HOME/Accuweather_conky_script/curr_cond}°C
${goto 120}${color3}Visibilité: ${alignr 10}${color1}${execi 600 sed -n '13p' $HOME/Accuweather_conky_script/curr_cond}s
${goto 120}${color3}Lever/Coucher: ${alignr 10}${color1}${execi 600 sed -n '14p' $HOME/Accuweather_conky_script/curr_cond} / ${execi 600 sed -n '15p' $HOME/Accuweather_conky_script/curr_cond}
${goto 120}${color3}Vent: ${alignr 10}${color1}${execi 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond} ${texeci 600 sed -n '5p' $HOME/Accuweather_conky_script/curr_cond > $HOME/Accuweather_conky_script/vent}
${goto 120}${color3}Vitesse: ${alignr 10}${color1}${execi 600 sed -n '6p' $HOME/Accuweather_conky_script/curr_cond}
${voffset -90}${goto 30}${color1}${template1 14}T: ${execi 600 sed -n '2p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 10} ${goto 30}${color1}${template1 14}R: ${execi 600 sed -n '3p' $HOME/Accuweather_conky_script/curr_cond}°C
${voffset 90}${template1 9}
${goto 100}Aujourd'hui ${goto 280}Demain
${goto 120}${color3}${texeci 600 sed -n '5p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${texeci 600 sed -n '4p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 280}${color3}${execpi 600 sed -n '12p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '11p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 80}${scroll 16 ${execpi 600 sed -n '6p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 240}${scroll 16 ${execpi 600 sed -n '13p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 60}
${goto 70}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 195}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}\
${goto 320}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${goto 70}${color3}${execpi 600 sed -n '19p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '18p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 195}${color3}${execpi 600 sed -n '26p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '25p' $HOME/Accuweather_conky_script/daily_forecast}°\
${goto 320}${color3}${execpi 600 sed -n '33p' $HOME/Accuweather_conky_script/daily_forecast}°${color}/${color2}${execpi 600 sed -n '32p' $HOME/Accuweather_conky_script/daily_forecast}°${color1}
${goto 55}${scroll 12 ${execpi 600 sed -n '20p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 180}${scroll 12 ${execpi 600 sed -n '27p' $HOME/Accuweather_conky_script/daily_forecast}}\
${goto 305}${scroll 12 ${execpi 600 sed -n '34p' $HOME/Accuweather_conky_script/daily_forecast}}
${voffset 75}${alignc}${color1}${template1 15}Calendrier Lunaire${font}
${voffset -5}${alignc}${color2}${template1 9}( Hémisphère Nord en GMT+1 Paris )${font}
${offset 40}
${alignc}${color3}Lever/Coucher:${color2}${template7 9}( Heure locale )$font
${alignc} ${template3 11}↑ ${template1 10}${execi 600 sed -n '18p' $HOME/Accuweather_conky_script/curr_cond} ${template3 11}↓ ${template1 10}${execi 600 sed -n '19p' $HOME/Accuweather_conky_script/curr_cond} = ${execi 600 sed -n '20p' $HOME/Accuweather_conky_script/curr_cond}
${alignc}${color3}Phase ${color1}${execpi 600 sed -n '1p' $HOME/Wunderground_conky_script/lune}
${template2 9}${voffset 20}
${goto 30}Visibilité: ${execpi 600 sed -n '23p' $HOME/Moongiant_conky_script/raw} ${goto 260}Angle: ${execpi 600 sed -n '25p' $HOME/Moongiant_conky_script/raw} °
${goto 30}Age: ${execpi 600 sed -n '24p' $HOME/Moongiant_conky_script/raw | awk '{print $1}'} Jour(s) ${goto 260}Dist.: ${execpi 600 sed -n '26p' $HOME/Moongiant_conky_script/raw}s
${voffset 80}${alignc}${color1}${template1 15}Éphéméride ${font}
${alignc}${color1}Saint(e) du jour
${alignc}${color2}${texeci 1000 wget -O - -q http://fetedujour.fr/ --user-agent="Mozilla/5.0 (Windows NT 5.1; rv:31.0) Gecko/20100101 Firefox/31.0" | grep h2 | head -1 | cut -d">" -f2 | cut -d"<" -f1 | cut -d":" -f2 }
#fond verticale
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/fond23x866.png 0 115 23 866}
#ligne rouge
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 90 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 306 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 582 380 12}
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/rouge2.png 20 850 380 12}
#texte vertical
${lua fDrawImage $HOME/conky/meteo+lune4/icones/base/lateralf.png 4 125 15 851}
#icones
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_0.png 20 100 115 69}
${lua fDrawImage $HOME/Accuweather_conky_script/Wind1.png 40 220 70 70}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_1.png 100 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_2.png 260 380 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_3.png 45 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_4.png 170 510 90 52}
${lua fDrawImage $HOME/Accuweather_conky_script/forecast_2015/forecast_5.png 295 510 90 52}
${lua fDrawImage $HOME/Wunderground_conky_script/Forecast_Images/Moon_phase.png 160 730 90 90}
