Utiliser Mageia
Conky-conkyrc-scripts-partie 4 - conky 1.10 et +
Dernière mise à jour : 29/09/2019 à 11h42
Chronographe
conkyrc
conky.config = {
    background = true,
    use_xft = true,
    font = 'hooge 05_53:size=6',
    xftalpha = 1,
    update_interval = 1.0,
    total_run_times = 0,
        net_avg_samples = 2,
    own_window = true,
--own_window_color 000000
    own_window_type = 'normal',
    double_buffer = true,
        maximum_width = 320,
    text_buffer_size = 2048,
    draw_shades = false,
    draw_outline = false,
    draw_borders = false,
    draw_graph_borders = false,
    default_color = 'white',
    alignment = 'top_right',
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
    cpu_avg_samples = 2,
    override_utf8_locale = true,
    imlib_cache_size = 10000,
    stippled_borders = 5,
-- Couleurs
    default_color         = '#ffffff',      --ffd579
    default_shade_color   = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600  sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600  sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600  sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600  sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600  sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600  sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600  sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '18p' $HOME/1_accuweather/first_days}°C
conkyrc1 (pour le deuxième lua)
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
cups.lua
--                  Cups and Saucers
--                               Lua conky script
--  author  : Abu Yahya
--  license : Distributed under the terms of GNU GPL v3
--  30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
    name='time',                   arg='%I',                    max_value=12,
    x=170,                         y=170,
    cup_radius=35,
    cup_wall_thickness=90,
    cup_bg_clr=0xffffff,           cup_bg_alpha=0.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=0.0,
    handle_length=70,              handle_circ=5,
    handle_fg_clr=0xFFFFFF,        handle_fg_alpha=0.0, --1.0
    graduation_radius=124,
    graduation_thickness=8,        graduation_mark_circ=1.5,
    graduation_mark_angle=30,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.5,
    saucer_thickness=6,            thick_saucer_circ=11/12,
    saucer_radius=135,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.0,
    inner_saucer=true,
    txt_weight=0,                  txt_size=8.0,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.0,
    caption='',                    caption2='',
    name='time',                   arg='%H',                    max_value=12,
    x=170,                         y=170,
    cup_radius=2.5,
    cup_wall_thickness=3,
    cup_bg_clr=0xffffff,           cup_bg_alpha=1.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=1.0,
    handle_length=40,              handle_circ=4,
    graduation_radius=127,
    graduation_thickness=1,        graduation_mark_circ=0.5,
    graduation_mark_angle=3,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.0,
    inner_saucer=true,
    name='time',                   arg='%M',                    max_value=60,
    x=170,                         y=170,
    cup_radius=55,
    cup_wall_thickness=120,
    graduation_radius=123,
    graduation_thickness=10,       graduation_mark_circ=2.5,
    graduation_mark_angle=90,
    handle_length=110,              handle_circ=3,
    saucer_radius=155,             thin_saucer_circ=11/12,
    name='time',                   arg='%S',                    max_value=60,
    x=170,                         y=170,
    cup_radius=59,
    handle_length=118,              handle_circ=1,
    graduation_radius=125,
    graduation_thickness=6,        graduation_mark_circ=0.5,
    graduation_mark_angle=6,
    saucer_thickness=5,           thick_saucer_circ=1,
    saucer_radius=145,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.4,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.4,
    name='cpu',                    arg='cpu0',                  max_value=100,
    x=170,                         y=100,
    cup_radius=20,
    cup_wall_thickness=40,
    cup_start_angle=0,
    cup_bg_clr=0xFFFFFF,           cup_bg_alpha=0.0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=1,
    caption=' CPU ',               caption2=' %',
    graduation_radius=25,
    graduation_thickness=3,        graduation_mark_circ=2,
    graduation_mark_angle=36,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.6,
    saucer_thickness=3,            thick_saucer_circ=0.85,
    saucer_radius=30,              thin_saucer_circ=0.85,
    saucer_fg_clr=0xFFFFFF,       saucer_fg_alpha= 0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.5,
    inner_saucer=true,
    name='freq_g',                 arg='/',                  max_value=5,
    x=170,                         y=100,
    cup_radius=12,
    cup_wall_thickness=23,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='',           caption2=' GHz',
    graduation_thickness=4,        graduation_mark_circ=4,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.0,
    saucer_thickness=3,            thick_saucer_circ=0.75,
    saucer_radius=35,              thin_saucer_circ=0.75,
---------------1/2
    name='downspeedf',                arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    caption='E. ',             caption2='',
    inner_saucer=true,
    name='upspeedf',               arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_wall_thickness=27,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='S ',             caption2='',
    saucer_radius=35,              thin_saucer_circ=0.85,
------------------2/3
    name='fs_used_perc',           arg='/home',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption=' FS /: ',             caption2=' %',
    inner_saucer=true,
    name='fs_used_perc',           arg='/',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.8,
    caption=' FS H: ',             caption2=' %',
end
-- displays cups and saucers
     max_value = data['max_value']
     x, y = data['x'], data['y']
     caption = data['caption']
     caption2 = data['caption2']
     if xtxt ==nil then xtxt=0 end
     if ytxt ==nil then ytxt=0 end
      if total_angle < 0 then
      else
      end
    end
--cup centre background
  if cup_bg_alpha >0   then
    else
    end
    cairo_stroke(display)
  end
--cup wall fg
  if cup_fg_alpha > 0 then
    else
    end
  end
-- cup handle
  if handle_fg_alpha>0 then
    local stop_handle = (cup_sector_angle * value) +  (handle_circ*0.5)
    else
    end
  end
--saucers
---thick saucer
      then
    if value < (max_value/2)
    end
    else
    end
    --thin saucer
      if inner_saucer == true
      end
    else
    end
   end
--saucer mark
    else
    end
    end
--graduation mark
        local start_arc_grad = 0
        local stop_arc_grad = 0
    local i = 0
        else
        end
            i = i + 1
        end
    end
-- text
  if txt_fg_alpha>0 then
    cairo_stroke (display)
  end
end
        local str, value = '', 0
            str = conky_parse(str)
    else
            value = tonumber(str)
        end
    end
    end
end
function conky_main()
    if conky_window == nil then
        return
    end
    if update_num > 5 then
    end
    cairo_surface_destroy(cs)
    cairo_destroy(display)
end
clocks_rings.lua
    lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
        name='time',
        arg='%I',
        max=12,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=133,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%M',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=140,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%S',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=147,
        thickness=4,
        start_angle=0,
        end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
    -- Draw background ring
    cairo_stroke(cr)
    -- Draw indicator ring
    cairo_stroke(cr)
end
    local xh,yh,xm,ym,xs,ys
    secs=os.date("%S")
    mins=os.date("%M")
    hours=os.date("%I")
    secs_arc=(2*math.pi/60)*secs
    -- Draw hour hand
    cairo_move_to(cr,xc,yc)
    cairo_line_to(cr,xh,yh)
    cairo_set_line_width(cr,5)
    cairo_stroke(cr)
    -- Draw minute hand
    cairo_line_to(cr,xm,ym)
    cairo_set_line_width(cr,3)
    cairo_stroke(cr)
    -- Draw seconds hand
    if show_seconds then
        cairo_line_to(cr,xs,ys)
        cairo_stroke(cr)
    end
end
function conky_clock_rings()
        local str=''
        local value=0
        str=conky_parse(str)
        value=tonumber(str)
        pct=value/pt['max']
        draw_ring(cr,pct,pt)
    end
    local cr=cairo_create(cs)
    update_num=tonumber(updates)
    if update_num>5 then
        end
    end
end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
capture_deecran_2019_06_08_09_26
conky lune
le pack @ prendre ici
Le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Monofur:bold:size=7',
own_window = true,
own_window_hints = 'undecorated,skip_taskbar,skip_pager,below',
draw_graph_borders = true,
stippled_borders = 8,
border_inner_margin = 4,
alignment = 'top_left',
minimum_width = 500,
minimum_height = 500,
gap_x = 130,
gap_y = 230,
no_buffers = false,
uppercase = false,
use_spacer = right,
text_buffer_size = 8192,
imlib_cache_size = 16384,
default_outline_color = '000000',
color1 = '000000',
color2 = '000000',
color3 = '828200',
color4 = '323200',
lua_load = '~/.conky/lua/image.lua',
conky.text = [[
${font Monofur:bold:size=12}${color5}${voffset -9}Phases de la lune ${color}${texeci 9500 bash $HOME/4_Moon/moon_MoonGiant}
${alignc 40}${color5}${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3}'`}${color}${font}
${lua fDrawImage $HOME/4_Moon/-2.png 10 65 60 60}
${lua fDrawImage $HOME/4_Moon/-1.png 80 65 60 60}
${lua fDrawImage $HOME/4_Moon/0.png 157 35 90 90}
${lua fDrawImage $HOME/4_Moon/1.png 265 65 60 60}
${lua fDrawImage $HOME/4_Moon/2.png 340 65 60 60}
${voffset 40}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${alignc 60}${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}
${voffset -42}${color5}${goto 15}${color5}${execi 3600 echo `date --date="-2 day" | awk '{print $2" "$3}'`}\
${goto 87}${execi 3600 echo `date --date="-1 day" | awk '{print $2" "$3}'`}\
${goto 347}${execi 3600 echo `date --date="+2 day" | awk '{print $2" "$3}'`}\
${goto 272}${execi 3600 echo `date --date="+1 day" | awk '{print $2" "$3}'`}${color}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${goto 15}${execpi 600 sed -n '13p' $HOME/4_Moon/raw-fr}\
${goto 87}${execpi 600 sed -n '21p' $HOME/4_Moon/raw-fr}\
${goto 272}${execpi 600 sed -n '29p' $HOME/4_Moon/raw-fr}\
${goto 347}${execpi 600 sed -n '37p' $HOME/4_Moon/raw-fr}
${alignc 40}${color5}Details pour ${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3" "$6}'`}${color}
Visibilité: ${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}${goto 250}Age: ${execpi 600 sed -n '5p' $HOME/4_Moon/raw} J
Angle du Soleil: ${execpi 600 sed -n '2p' $HOME/4_Moon/raw} ° ${goto 250}Angle de Lune: ${execpi 600 sed -n '6p' $HOME/4_Moon/raw} °
Distance du Soleil: ${execpi 600 sed -n '3p' $HOME/4_Moon/raw} kms${goto 250}Distance de la Lune: ${execpi 600 sed -n '4p' $HOME/4_Moon/raw} kms
${alignc 50}${color5}Position de la Lune${color}\
${lua fDrawImage $HOME/4_Moon/rise.png  0 294 400 130}\
${lua fDrawImage $HOME/4_Moon/0.png    45 370 30 30}\
${lua fDrawImage $HOME/4_Moon/0.png   325 370 30 30}\
${Lua fDrawImage $HOME/4_Moon/0.png   185 296 30 30}
#!/bin/bash
#function: moonrise_set
moonrise_set () {
    case "$1" in
         "FirstQuarter")
            echo "Noon/Midnight"
            cp $HOME/4_Moon/riseicons/rise_FirstQuarter.png $HOME/4_Moon/rise.png
         "FullMoon")
            echo "6PM/6AM"
            cp $HOME/4_Moon/riseicons/rise_FullMoon.png $HOME/4_Moon/rise.png
         "LastQuarter")
            echo "Midnight/Noon"
            cp $HOME/4_Moon/riseicons/rise_LastQuarter.png $HOME/4_Moon/rise.png
         "NewMoon")
            echo "6AM/6PM"
            cp $HOME/4_Moon/riseicons/rise_NewMoon.png $HOME/4_Moon/rise.png
         "WaningCrescent")
            echo "3AM/3PM"
            cp $HOME/4_Moon/riseicons/rise_WaningCrescent.png $HOME/4_Moon/rise.png
         "WaningGibbous")
            echo "9PM/9AM"
            cp $HOME/4_Moon/riseicons/rise_WaningGibbous.png $HOME/4_Moon/rise.png
         "WaxingCrescent")
            echo "9AM/9PM"
            cp $HOME/4_Moon/riseicons/rise_WaxingCrescent.png $HOME/4_Moon/rise.png
         "WaxingGibbous")
            echo "3PM/3AM"
            cp $HOME/4_Moon/riseicons/rise_WaxingGibbous.png $HOME/4_Moon/rise.png
            echo "Unavailable"
         esac
kill -STOP $(pidof conky)
#put your hemisphere here: north or south
hemisphere=north
wget -O $HOME/4_Moon/raw "http://www.moongiant.com/phase/today"
rm $HOME/4_Moon/*.png
sed -i -e '/^ *$/d' -e 's/^ *//g' $HOME/4_Moon/raw
sed -i '/var jArray=\|"todayMoonContainer"\|"moonNotToday"/!d' $HOME/4_Moon/raw
sed -i -e '/var jArray/s/","/\n/g' -e 's/<span>\|<b>\|<\\\/span>\|<\\\/b>\|\\n//g' /$HOME/4_Moon/raw
sed -i -e '/var jArray/d' -e 's/^.*\:\[\"//g' /$HOME/4_Moon/raw
sed -i -e 's/"\]};//g' -e 's/^.*today_phase\///g' -e 's/\.jpg.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/^small\///g' -e 's/\.png.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/Illumination: \|Sun Angle: \|Sun Distance: \|Moon Distance: \|Moon Age: \|Moon Angle: //g' -e '43d' /$HOME/4_Moon/raw
#September 30-October 1 fix
for (( i=11; i<=35; i+=8 ))
    do
        if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "September 30" ]]; then
            line=$((i+7))
            sed -i "${line}s/^.*$/Waning Crescent/" /$HOME/4_Moon/raw
        fi
        if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "October 1" ]]; then
            line=$((i+7))
            sed -i "${line}s/^.*$/New Moon/" /$HOME/4_Moon/raw
        fi
    done
today_phase=$(sed -n 8p /$HOME/4_Moon/raw| awk -F "," '{print $2}'| sed 's/ //')
if [[ $today_phase == "September 30" ]]; then
            sed -i '7s/^.*$/Waning Crescent/' /$HOME/4_Moon/raw
            sed -i '10s/^.*$/Phase: Waning Crescent/' /$HOME/4_Moon/raw
fi
if [[ $today_phase == "October 1" ]]; then
            sed -i '7s/^.*$/New Moon/' /$HOME/4_Moon/raw
            sed -i '10s/^.*$/Phase: New Moon/' /$HOME/4_Moon/raw
fi
phase=$(sed -n 7p $HOME/4_Moon/raw|sed 's/ //')
mrise_mset=$(moonrise_set $phase)
sed -i 7a$(moonrise_set $phase) /$HOME/4_Moon/raw
#Day before Yesterday
img_in=$(sed -n 44p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-2.png
#Yesterday
img_in=$(sed -n 45p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-1.png
#Today
img_in=$(sed -n 46p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/0.png
#Tomorrow
img_in=$(sed -n 47p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/1.png
#Day after Tomorrow
img_in=$(sed -n 48p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/2.png
## English to French
cp $HOME/4_Moon/raw $HOME/4_Moon/raw-fr
if [[ -s $HOME/4_Moon/raw-fr ]]; then
        sed -i -e 's/Full Moon/Pleine Lune/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waning Gibbous/Gibeuse décroissante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waxing Gibbous/Gibeuse croissante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waxing Crescent/Lune Montante/' $HOME/4_Moon/raw-fr
        sed -i -e 's/First Quarter/Premier Quartier/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Last Quarter/Dernier Quartier/' $HOME/4_Moon/raw-fr
        sed -i -e 's/Waning Crescent/Lune Déscendante/' /$HOME/4_Moon/raw-fr
fi
kill -CONT $(pidof conky)
capture_deecran_2019-07-20_09-40-31
Diamond
(Pour la météo il faut toujours le pack de Théo accuweather)
un de mes vieux ensemble de conky mis en version 1.10
pas de lecteurs jouant
capture_deecran_2019-09-29_11-16-03
avec audacious
capture_deecran_2019-09-29_11-17-10
avec radiotray-ng
capture_deecran_2019-09-29_11-15-05
conkyrcs
time & weather
conky.config = {
    background = true,
    use_xft = true,
    font = 'Liberation Sans:size=9',
    xftalpha = 1,
    own_window = true,
    minimum_width = 470, minimum_height = 170,
        maximum_width = 470,
    gap_x = 30,
    gap_y = 10,
    no_buffers = true,
    uppercase = false,
-- Taille des pointillés
-- Couleurs
    default_color = '#ffffff',--ffd579
conky.text = [[
${execi 180 bash $HOME/1_accuweather/1_accuweather -f}
${font Liberation Sans:size=26}${alignc 20}${time %a %d %b %H:%M}${font}
${goto 70}----------------------------------------------------------------------------
${goto 30}Aujourdh'ui ${goto 110}demain\
${goto 190}${execi 3600 echo `date --date="2 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="2 day" | awk '{print $2}'`}\
${goto 270}${execi 3600 echo `date --date="3 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="3 day" | awk '{print $2}'`}${voffset -14}
${goto 360}${execi 3600 echo `date --date="4 day" | awk '{print $1}' | cut -c1-3`}.${execi 3600 echo `date --date="4 day" | awk '{print $2}'`}
${font conkyweather:size=30}${voffset -30}
${goto 40}${execi 600  sed -n '601p' $HOME/1_accuweather/daily_forecast}\
${goto 110}${execi 600  sed -n '602p' $HOME/1_accuweather/daily_forecast}\
${goto 190}${execi 600  sed -n '603p' $HOME/1_accuweather/daily_forecast}\
${goto 270}${execi 600  sed -n '604p' $HOME/1_accuweather/daily_forecast}\
${goto 360}${execi 600  sed -n '605p' $HOME/1_accuweather/daily_forecast}${font}
${goto  40}${texeci 600 sed -n '68p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '47p' $HOME/1_accuweather/daily_forecast}°\
${goto 110}${texeci 600 sed -n '108p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '87p' $HOME/1_accuweather/daily_forecast}°\
${goto 190}${texeci 600 sed -n '148p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '127p' $HOME/1_accuweather/daily_forecast}°\
${goto 270}${texeci 600 sed -n '188p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '167p' $HOME/1_accuweather/daily_forecast}°\
${goto 360}${texeci 600 sed -n '228p' $HOME/1_accuweather/daily_forecast}°/${texeci 600 sed -n '207p' $HOME/1_accuweather/daily_forecast}°\
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 440 180 }
cpu
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    minimum_width = 470, minimum_height = 280,
    gap_x = 00,
    gap_y = 210,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[
${voffset 30}${offset 50}Cpu1:${color DDF2FF} ${offset 3}${cpu cpu1}%${alignr 90}${voffset -5}${color #DBDBDB}${cpugraph cpu1 20,240 f1f1f1 DBDBDB}${color}
${voffset -3}${offset 50}CPU Step: ${alignr 80}${color DDF2FF}${freq_g} GHz${color}
${voffset 12}${offset 50}Cpu2:${color DDF2FF} ${offset 3}${cpu cpu2}%${alignr 90}${voffset -9}${color #DDF2FF}${cpugraph cpu2 20,240 f1f1f1 DBDBDB}${color}
${voffset -5}${alignc 10}---------------------------------------------------------------------------------
${voffset 15}${offset 50}RAM: ${alignr 80} $mem/${color #DDF2FF}$memmax${color}
${offset 50}${color #DDF2FF}${membar 5,340}${color}
${offset 50}Swap: ${alignr 80} $swap / ${color #DDF2FF}$swapmax${color}
${offset 50}${color #DDF2FF}${swapbar 5,340}${color}
${offset 50}ROOT:${color #DDF2FF} ${alignr 80} ${fs_free /} / ${fs_size /}
${offset 50}${fs_bar 5,340 /}${color}
${lua fDrawImage ~/.conky/diamond/pix/bg1.png 0 0 439 270}
network
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 30,
    gap_y = 470,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[
${offset 25}${font Liberation Sans:size=11}SSID:${font} ${wireless_essid wlo1} ${goto 190}${font Liberation Sans:size=11}Sortant:${font} ${upspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Bitrate:${font} ${wireless_bitrate wlo1} ${goto 190}${font Liberation Sans:size=11}Entrant:${font} ${downspeed wlo1}
${offset 25}${font Liberation Sans:size=11}Local:${font} ${addr wlo1} ${goto 190}${font Liberation Sans:size=11}Signal:${font} ${wireless_link_qual_perc wlo1}%
${lua fDrawImage ~/.conky/diamond/pix/bg1.png  0 0 440 102}
${if_match "${wireless_link_qual_perc wlo1}"<"1"} ${lua fDrawImage ~/.conky/diamond/pix/nonetwork.png  300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"20"}${lua fDrawImage ~/.conky/diamond/pix/networklow.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"50"}${lua fDrawImage ~/.conky/diamond/pix/networkmid.png 300 25 45 45}${else}
${if_match "${wireless_link_qual_perc wlo1}"<"80"}${lua fDrawImage ~/.conky/diamond/pix/wlan80.png     300 25 45 45}${else}
${lua fDrawImage ~/.conky/diamond/pix/networkhigh.png 300 25 45 45}${endif}${endif}${endif}${endif}
audacious
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 30,
    gap_y = 580,
    no_buffers = true,
    uppercase = false,
-- Couleurs
conky.text = [[${if_running audacious}
${execi 3 ~/.conky/audacious/scripts/cover.sh}
${voffset -40}${font GE Inspira :size=12}
${goto 160}${execi 3 audtool current-song-tuple-data artist}${font}
${goto 160}${execi 3 audtool current-song-tuple-data title}
${goto 160}${execi 3 audtool current-song-tuple-data album}
${voffset 10}${goto 160}${execi 1 audtool current-song-output-length}  ${goto 358}${execi 1 audtool current-song-length}\
${goto 184}${execbar 2, 168 expr 100 \* $(audtool --current-song-output-length-seconds) \/ $(audtool --current-song-length-seconds)}
${lua fDrawImage ~/.conky/audacious/audacious.png 44 14 68 70}
${else}
${if_running radiotray-ng}
${texeci 3 ~/.conky/radiotrayng/pochette.sh}${lua fDrawImage ~/.conky/diamond/pix/bg1.png  0 0 440 102}
${voffset -36}${alignc -80}${font GE Inspira:size=12}${execi 5 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}$font
${voffset 33}${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.artist'}
             ${alignc -20}${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL"}            ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl.png 222 32 50 50}         ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Hotmixradio 80"} ${lua fDrawImage ~/.conky/radiotrayng/logos/hotmix80.png 228 28 35 35}    ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "Maxi 80"}        ${lua fDrawImage ~/.conky/radiotrayng/logos/maxi80.png 230 29 35 35}      ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "RTL2"}           ${lua fDrawImage ~/.conky/radiotrayng/logos/rtl2.png 222 32 45 45}        ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "MAGNUM LA RADIO"}${lua fDrawImage ~/.conky/radiotrayng/logos/magnumradio.png 184 26 120 40}${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "radio swiss pop"}${lua fDrawImage ~/.conky/radiotrayng/logos/rspop.png 244 30 35 35}       ${else}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.station'}" == "rfm"}            ${lua fDrawImage ~/.conky/radiotrayng/logos/rfm.png 224 35 45 45}         ${endif}
${endif}${endif}${endif}${endif}${endif}${endif}
${if_match "${execi 4 qdbus com.github.radiotray_ng /com/github/radiotray_ng com.github.radiotray_ng.get_player_state | jq -r '.title'}" == ""}${lua fDrawImage ~/.conky/radiotrayng/logos/radio.png 30 10 78 78}
${else}
${lua fDrawImage ~/.conky/diamond/pochette.png 40 14 68 70}${endif}
${else}
${endif}
