Dernière mise à jour : 20/07/2019 à 09h50
Chronographe
conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'hooge 05_53:size=6',
xftalpha = 1,
update_interval = 1.0,
total_run_times = 0,
net_avg_samples = 2,
own_window = true,
--own_window_color 000000
own_window_type = 'normal',
double_buffer = true,
maximum_width = 320,
text_buffer_size = 2048,
draw_shades = false,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
default_color = 'white',
alignment = 'top_right',
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
cpu_avg_samples = 2,
override_utf8_locale = true,
imlib_cache_size = 10000,
stippled_borders = 5,
-- Couleurs
default_color = '#ffffff', --ffd579
default_shade_color = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600 sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600 sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600 sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600 sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600 sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600 sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600 sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '18p' $HOME/1_accuweather/first_days}°C
]];conkyrc1 (pour le deuxième lua)
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
]];cups.lua
-- Cups and Saucers
-- Lua conky script
-- author : Abu Yahya
-- license : Distributed under the terms of GNU GPL v3
-- 30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
name='time', arg='%I', max_value=12,
x=170, y=170,
cup_radius=35,
cup_wall_thickness=90,
cup_bg_clr=0xffffff, cup_bg_alpha=0.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0,
handle_length=70, handle_circ=5,
handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0
graduation_radius=124,
graduation_thickness=8, graduation_mark_circ=1.5,
graduation_mark_angle=30,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5,
saucer_thickness=6, thick_saucer_circ=11/12,
saucer_radius=135, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0,
inner_saucer=true,
txt_weight=0, txt_size=8.0,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0,
caption='', caption2='',
name='time', arg='%H', max_value=12,
x=170, y=170,
cup_radius=2.5,
cup_wall_thickness=3,
cup_bg_clr=0xffffff, cup_bg_alpha=1.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=1.0,
handle_length=40, handle_circ=4,
graduation_radius=127,
graduation_thickness=1, graduation_mark_circ=0.5,
graduation_mark_angle=3,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.0,
inner_saucer=true,
name='time', arg='%M', max_value=60,
x=170, y=170,
cup_radius=55,
cup_wall_thickness=120,
graduation_radius=123,
graduation_thickness=10, graduation_mark_circ=2.5,
graduation_mark_angle=90,
handle_length=110, handle_circ=3,
saucer_radius=155, thin_saucer_circ=11/12,
name='time', arg='%S', max_value=60,
x=170, y=170,
cup_radius=59,
handle_length=118, handle_circ=1,
graduation_radius=125,
graduation_thickness=6, graduation_mark_circ=0.5,
graduation_mark_angle=6,
saucer_thickness=5, thick_saucer_circ=1,
saucer_radius=145, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.4,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.4,
name='cpu', arg='cpu0', max_value=100,
x=170, y=100,
cup_radius=20,
cup_wall_thickness=40,
cup_start_angle=0,
cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=1,
caption=' CPU ', caption2=' %',
graduation_radius=25,
graduation_thickness=3, graduation_mark_circ=2,
graduation_mark_angle=36,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6,
saucer_thickness=3, thick_saucer_circ=0.85,
saucer_radius=30, thin_saucer_circ=0.85,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5,
inner_saucer=true,
name='freq_g', arg='/', max_value=5,
x=170, y=100,
cup_radius=12,
cup_wall_thickness=23,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='', caption2=' GHz',
graduation_thickness=4, graduation_mark_circ=4,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0,
saucer_thickness=3, thick_saucer_circ=0.75,
saucer_radius=35, thin_saucer_circ=0.75,
---------------1/2
name='downspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
caption='E. ', caption2='',
inner_saucer=true,
name='upspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_wall_thickness=27,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='S ', caption2='',
saucer_radius=35, thin_saucer_circ=0.85,
------------------2/3
name='fs_used_perc', arg='/home', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption=' FS /: ', caption2=' %',
inner_saucer=true,
name='fs_used_perc', arg='/', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.8,
caption=' FS H: ', caption2=' %',
end
-- displays cups and saucers
max_value = data['max_value']
x, y = data['x'], data['y']
caption = data['caption']
caption2 = data['caption2']
if xtxt ==nil then xtxt=0 end
if ytxt ==nil then ytxt=0 end
if total_angle < 0 then
else
end
end
--cup centre background
if cup_bg_alpha >0 then
else
end
cairo_stroke(display)
end
--cup wall fg
if cup_fg_alpha > 0 then
else
end
end
-- cup handle
if handle_fg_alpha>0 then
local stop_handle = (cup_sector_angle * value) + (handle_circ*0.5)
else
end
end
--saucers
---thick saucer
then
if value < (max_value/2)
end
else
end
--thin saucer
if inner_saucer == true
end
else
end
end
--saucer mark
else
end
end
--graduation mark
local start_arc_grad = 0
local stop_arc_grad = 0
local i = 0
else
end
i = i + 1
end
end
-- text
if txt_fg_alpha>0 then
cairo_stroke (display)
end
end
local str, value = '', 0
str = conky_parse(str)
else
value = tonumber(str)
end
end
end
end
function conky_main()
if conky_window == nil then
return
end
if update_num > 5 then
end
cairo_surface_destroy(cs)
cairo_destroy(display)
end
clocks_rings.lua
lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
name='time',
arg='%I',
max=12,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=133,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%M',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=140,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%S',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=147,
thickness=4,
start_angle=0,
end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
-- Draw background ring
cairo_stroke(cr)
-- Draw indicator ring
cairo_stroke(cr)
end
local xh,yh,xm,ym,xs,ys
secs=os.date("%S")
mins=os.date("%M")
hours=os.date("%I")
secs_arc=(2*math.pi/60)*secs
-- Draw hour hand
cairo_move_to(cr,xc,yc)
cairo_line_to(cr,xh,yh)
cairo_set_line_width(cr,5)
cairo_stroke(cr)
-- Draw minute hand
cairo_line_to(cr,xm,ym)
cairo_set_line_width(cr,3)
cairo_stroke(cr)
-- Draw seconds hand
if show_seconds then
cairo_line_to(cr,xs,ys)
cairo_stroke(cr)
end
end
function conky_clock_rings()
local str=''
local value=0
str=conky_parse(str)
value=tonumber(str)
pct=value/pt['max']
draw_ring(cr,pct,pt)
end
local cr=cairo_create(cs)
update_num=tonumber(updates)
if update_num>5 then
end
end
end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
conky lune
le pack @ prendre ici
http://bit.ly/4_24-5-17
Le conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'Monofur:bold:size=7',
own_window = true,
own_window_hints = 'undecorated,skip_taskbar,skip_pager,below',
draw_graph_borders = true,
stippled_borders = 8,
border_inner_margin = 4,
alignment = 'top_left',
minimum_width = 500,
minimum_height = 500,
gap_x = 130,
gap_y = 230,
no_buffers = false,
uppercase = false,
use_spacer = right,
text_buffer_size = 8192,
imlib_cache_size = 16384,
default_outline_color = '000000',
color1 = '000000',
color2 = '000000',
color3 = '828200',
color4 = '323200',
lua_load = '~/.conky/lua/image.lua',
conky.text = [[
${font Monofur:bold:size=12}${color5}${voffset -9}Phases de la lune ${color}${texeci 9500 bash $HOME/4_Moon/moon_MoonGiant}
${alignc 40}${color5}${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3}'`}${color}${font}
${lua fDrawImage $HOME/4_Moon/-2.png 10 65 60 60}
${lua fDrawImage $HOME/4_Moon/-1.png 80 65 60 60}
${lua fDrawImage $HOME/4_Moon/0.png 157 35 90 90}
${lua fDrawImage $HOME/4_Moon/1.png 265 65 60 60}
${lua fDrawImage $HOME/4_Moon/2.png 340 65 60 60}
${voffset 40}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${alignc 60}${execpi 600 sed -n '7p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${alignc 60}${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}
${voffset -42}${color5}${goto 15}${color5}${execi 3600 echo `date --date="-2 day" | awk '{print $2" "$3}'`}\
${goto 87}${execi 3600 echo `date --date="-1 day" | awk '{print $2" "$3}'`}\
${goto 347}${execi 3600 echo `date --date="+2 day" | awk '{print $2" "$3}'`}\
${goto 272}${execi 3600 echo `date --date="+1 day" | awk '{print $2" "$3}'`}${color}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $1}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $1}'}
${goto 15}${execpi 600 sed -n '19p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 87}${execpi 600 sed -n '27p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 272}${execpi 600 sed -n '35p' $HOME/4_Moon/raw-fr | awk '{print $2}'}\
${goto 347}${execpi 600 sed -n '43p' $HOME/4_Moon/raw-fr | awk '{print $2}'}
${goto 15}${execpi 600 sed -n '13p' $HOME/4_Moon/raw-fr}\
${goto 87}${execpi 600 sed -n '21p' $HOME/4_Moon/raw-fr}\
${goto 272}${execpi 600 sed -n '29p' $HOME/4_Moon/raw-fr}\
${goto 347}${execpi 600 sed -n '37p' $HOME/4_Moon/raw-fr}
${alignc 40}${color5}Details pour ${execi 3600 echo `date --date="0 day" | awk '{print $1" "$2" "$3" "$6}'`}${color}
Visibilité: ${execpi 600 sed -n '1p' $HOME/4_Moon/raw-fr}${goto 250}Age: ${execpi 600 sed -n '5p' $HOME/4_Moon/raw} J
Angle du Soleil: ${execpi 600 sed -n '2p' $HOME/4_Moon/raw} ° ${goto 250}Angle de Lune: ${execpi 600 sed -n '6p' $HOME/4_Moon/raw} °
Distance du Soleil: ${execpi 600 sed -n '3p' $HOME/4_Moon/raw} kms${goto 250}Distance de la Lune: ${execpi 600 sed -n '4p' $HOME/4_Moon/raw} kms
${alignc 50}${color5}Position de la Lune${color}\
${lua fDrawImage $HOME/4_Moon/rise.png 0 294 400 130}\
${lua fDrawImage $HOME/4_Moon/0.png 45 370 30 30}\
${lua fDrawImage $HOME/4_Moon/0.png 325 370 30 30}\
${Lua fDrawImage $HOME/4_Moon/0.png 185 296 30 30}
#!/bin/bash
#function: moonrise_set
moonrise_set () {
case "$1" in
"FirstQuarter")
echo "Noon/Midnight"
cp $HOME/4_Moon/riseicons/rise_FirstQuarter.png $HOME/4_Moon/rise.png
"FullMoon")
echo "6PM/6AM"
cp $HOME/4_Moon/riseicons/rise_FullMoon.png $HOME/4_Moon/rise.png
"LastQuarter")
echo "Midnight/Noon"
cp $HOME/4_Moon/riseicons/rise_LastQuarter.png $HOME/4_Moon/rise.png
"NewMoon")
echo "6AM/6PM"
cp $HOME/4_Moon/riseicons/rise_NewMoon.png $HOME/4_Moon/rise.png
"WaningCrescent")
echo "3AM/3PM"
cp $HOME/4_Moon/riseicons/rise_WaningCrescent.png $HOME/4_Moon/rise.png
"WaningGibbous")
echo "9PM/9AM"
cp $HOME/4_Moon/riseicons/rise_WaningGibbous.png $HOME/4_Moon/rise.png
"WaxingCrescent")
echo "9AM/9PM"
cp $HOME/4_Moon/riseicons/rise_WaxingCrescent.png $HOME/4_Moon/rise.png
"WaxingGibbous")
echo "3PM/3AM"
cp $HOME/4_Moon/riseicons/rise_WaxingGibbous.png $HOME/4_Moon/rise.png
echo "Unavailable"
esac
kill -STOP $(pidof conky)
#put your hemisphere here: north or south
hemisphere=north
wget -O $HOME/4_Moon/raw "http://www.moongiant.com/phase/today"
rm $HOME/4_Moon/*.png
sed -i -e '/^ *$/d' -e 's/^ *//g' $HOME/4_Moon/raw
sed -i '/var jArray=\|"todayMoonContainer"\|"moonNotToday"/!d' $HOME/4_Moon/raw
sed -i -e '/var jArray/s/","/\n/g' -e 's/<span>\|<b>\|<\\\/span>\|<\\\/b>\|\\n//g' /$HOME/4_Moon/raw
sed -i -e '/var jArray/d' -e 's/^.*\:\[\"//g' /$HOME/4_Moon/raw
sed -i -e 's/"\]};//g' -e 's/^.*today_phase\///g' -e 's/\.jpg.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/^small\///g' -e 's/\.png.*$//g' /$HOME/4_Moon/raw
sed -i -e 's/Illumination: \|Sun Angle: \|Sun Distance: \|Moon Distance: \|Moon Age: \|Moon Angle: //g' -e '43d' /$HOME/4_Moon/raw
#September 30-October 1 fix
for (( i=11; i<=35; i+=8 ))
do
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "September 30" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/Waning Crescent/" /$HOME/4_Moon/raw
fi
if [[ $(sed -n ${i}p /$HOME/4_Moon/raw) == "October 1" ]]; then
line=$((i+7))
sed -i "${line}s/^.*$/New Moon/" /$HOME/4_Moon/raw
fi
done
today_phase=$(sed -n 8p /$HOME/4_Moon/raw| awk -F "," '{print $2}'| sed 's/ //')
if [[ $today_phase == "September 30" ]]; then
sed -i '7s/^.*$/Waning Crescent/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: Waning Crescent/' /$HOME/4_Moon/raw
fi
if [[ $today_phase == "October 1" ]]; then
sed -i '7s/^.*$/New Moon/' /$HOME/4_Moon/raw
sed -i '10s/^.*$/Phase: New Moon/' /$HOME/4_Moon/raw
fi
phase=$(sed -n 7p $HOME/4_Moon/raw|sed 's/ //')
mrise_mset=$(moonrise_set $phase)
sed -i 7a$(moonrise_set $phase) /$HOME/4_Moon/raw
#Day before Yesterday
img_in=$(sed -n 44p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-2.png
#Yesterday
img_in=$(sed -n 45p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/-1.png
#Today
img_in=$(sed -n 46p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/0.png
#Tomorrow
img_in=$(sed -n 47p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/1.png
#Day after Tomorrow
img_in=$(sed -n 48p $HOME/4_Moon/raw)
cp $HOME/4_Moon/moongiant_icons_$hemisphere/$img_in.png $HOME/4_Moon/2.png
## English to French
cp $HOME/4_Moon/raw $HOME/4_Moon/raw-fr
if [[ -s $HOME/4_Moon/raw-fr ]]; then
sed -i -e 's/Full Moon/Pleine Lune/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Gibbous/Gibeuse décroissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Gibbous/Gibeuse croissante/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waxing Crescent/Lune Montante/' $HOME/4_Moon/raw-fr
sed -i -e 's/First Quarter/Premier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Last Quarter/Dernier Quartier/' $HOME/4_Moon/raw-fr
sed -i -e 's/Waning Crescent/Lune Déscendante/' /$HOME/4_Moon/raw-fr
fi
kill -CONT $(pidof conky)
