Utiliser Mageia
Conky-conkyrc-scripts-partie 4 - conky 1.10 et +
Dernière mise à jour : 10/06/2019 à 09h55
Cronographe
conkyrc
conky.config = {
    background = true,
    use_xft = true,
    font = 'hooge 05_53:size=6',
    xftalpha = 1,
    update_interval = 1.0,
    total_run_times = 0,
        net_avg_samples = 2,
    own_window = true,
--own_window_color 000000
    own_window_type = 'normal',
    double_buffer = true,
        maximum_width = 320,
    text_buffer_size = 2048,
    draw_shades = false,
    draw_outline = false,
    draw_borders = false,
    draw_graph_borders = false,
    default_color = 'white',
    alignment = 'top_right',
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
    cpu_avg_samples = 2,
    override_utf8_locale = true,
    imlib_cache_size = 10000,
    stippled_borders = 5,
-- Couleurs
    default_color         = '#ffffff',      --ffd579
    default_shade_color   = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600  sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600  sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600  sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600  sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600  sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600  sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600  sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600  sed -n '18p' $HOME/1_accuweather/first_days}°C
conkyrc1 (pour le deuxième lua)
conky.config = {
    background = true,
    use_xft = true,
    xftalpha = 1,
    own_window = true,
    gap_x = 120,
    gap_y = 70,
    no_buffers = true,
    uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
cups.lua
--                  Cups and Saucers
--                               Lua conky script
--  author  : Abu Yahya
--  license : Distributed under the terms of GNU GPL v3
--  30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
    name='time',                   arg='%I',                    max_value=12,
    x=170,                         y=170,
    cup_radius=35,
    cup_wall_thickness=90,
    cup_bg_clr=0xffffff,           cup_bg_alpha=0.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=0.0,
    handle_length=70,              handle_circ=5,
    handle_fg_clr=0xFFFFFF,        handle_fg_alpha=0.0, --1.0
    graduation_radius=124,
    graduation_thickness=8,        graduation_mark_circ=1.5,
    graduation_mark_angle=30,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.5,
    saucer_thickness=6,            thick_saucer_circ=11/12,
    saucer_radius=135,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.0,
    inner_saucer=true,
    txt_weight=0,                  txt_size=8.0,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.0,
    caption='',                    caption2='',
    name='time',                   arg='%H',                    max_value=12,
    x=170,                         y=170,
    cup_radius=2.5,
    cup_wall_thickness=3,
    cup_bg_clr=0xffffff,           cup_bg_alpha=1.0,
    cup_fg_clr=0xFFFFFF,           cup_fg_alpha=1.0,
    handle_length=40,              handle_circ=4,
    graduation_radius=127,
    graduation_thickness=1,        graduation_mark_circ=0.5,
    graduation_mark_angle=3,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.0,
    inner_saucer=true,
    name='time',                   arg='%M',                    max_value=60,
    x=170,                         y=170,
    cup_radius=55,
    cup_wall_thickness=120,
    graduation_radius=123,
    graduation_thickness=10,       graduation_mark_circ=2.5,
    graduation_mark_angle=90,
    handle_length=110,              handle_circ=3,
    saucer_radius=155,             thin_saucer_circ=11/12,
    name='time',                   arg='%S',                    max_value=60,
    x=170,                         y=170,
    cup_radius=59,
    handle_length=118,              handle_circ=1,
    graduation_radius=125,
    graduation_thickness=6,        graduation_mark_circ=0.5,
    graduation_mark_angle=6,
    saucer_thickness=5,           thick_saucer_circ=1,
    saucer_radius=145,             thin_saucer_circ=11/12,
    saucer_fg_clr=0xFFFFFF,        saucer_fg_alpha=0.4,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.4,
    name='cpu',                    arg='cpu0',                  max_value=100,
    x=170,                         y=100,
    cup_radius=20,
    cup_wall_thickness=40,
    cup_start_angle=0,
    cup_bg_clr=0xFFFFFF,           cup_bg_alpha=0.0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=1,
    caption=' CPU ',               caption2=' %',
    graduation_radius=25,
    graduation_thickness=3,        graduation_mark_circ=2,
    graduation_mark_angle=36,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.6,
    saucer_thickness=3,            thick_saucer_circ=0.85,
    saucer_radius=30,              thin_saucer_circ=0.85,
    saucer_fg_clr=0xFFFFFF,       saucer_fg_alpha= 0.3,
    saucer_mark_fg_clr=0xFFFFFF,   saucer_mark_fg_alpha=0.5,
    inner_saucer=true,
    name='freq_g',                 arg='/',                  max_value=5,
    x=170,                         y=100,
    cup_radius=12,
    cup_wall_thickness=23,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='',           caption2=' GHz',
    graduation_thickness=4,        graduation_mark_circ=4,
    graduation_fg_clr=0xFFFFFF,    graduation_fg_alpha=0.0,
    saucer_thickness=3,            thick_saucer_circ=0.75,
    saucer_radius=35,              thin_saucer_circ=0.75,
---------------1/2
    name='downspeedf',                arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    caption='E. ',             caption2='',
    inner_saucer=true,
    name='upspeedf',               arg='wlo1',                      max_value=100,
    x=100,                         y=170,
    cup_radius=12,
    cup_wall_thickness=27,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption='S ',             caption2='',
    saucer_radius=35,              thin_saucer_circ=0.85,
------------------2/3
    name='fs_used_perc',           arg='/home',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= 10,
    caption=' FS /: ',             caption2=' %',
    inner_saucer=true,
    name='fs_used_perc',           arg='/',                      max_value=100,
    x=170,                         y=240,
    cup_radius=12,
    cup_start_angle=0,
    xtxt=-20,               ytxt= -5,
    txt_fg_clr=0xFFFFFF,           txt_fg_alpha=0.8,
    caption=' FS H: ',             caption2=' %',
end
-- displays cups and saucers
     max_value = data['max_value']
     x, y = data['x'], data['y']
     caption = data['caption']
     caption2 = data['caption2']
     if xtxt ==nil then xtxt=0 end
     if ytxt ==nil then ytxt=0 end
      if total_angle < 0 then
      else
      end
    end
--cup centre background
  if cup_bg_alpha >0   then
    else
    end
    cairo_stroke(display)
  end
--cup wall fg
  if cup_fg_alpha > 0 then
    else
    end
  end
-- cup handle
  if handle_fg_alpha>0 then
    local stop_handle = (cup_sector_angle * value) +  (handle_circ*0.5)
    else
    end
  end
--saucers
---thick saucer
      then
    if value < (max_value/2)
    end
    else
    end
    --thin saucer
      if inner_saucer == true
      end
    else
    end
   end
--saucer mark
    else
    end
    end
--graduation mark
        local start_arc_grad = 0
        local stop_arc_grad = 0
    local i = 0
        else
        end
            i = i + 1
        end
    end
-- text
  if txt_fg_alpha>0 then
    cairo_stroke (display)
  end
end
        local str, value = '', 0
            str = conky_parse(str)
    else
            value = tonumber(str)
        end
    end
    end
end
function conky_main()
    if conky_window == nil then
        return
    end
    if update_num > 5 then
    end
    cairo_surface_destroy(cs)
    cairo_destroy(display)
end
clocks_rings.lua
    lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
        name='time',
        arg='%I',
        max=12,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=133,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%M',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=140,
        thickness=4,
        start_angle=0,
        end_angle=360
        name='time',
        arg='%S',
        max=60,
        bg_colour=0xFFFFFF,
        bg_alpha=0.0,
        fg_colour=0xFFFFFF,
        fg_alpha=0.0,
        x=150, y=150,
        radius=147,
        thickness=4,
        start_angle=0,
        end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
    -- Draw background ring
    cairo_stroke(cr)
    -- Draw indicator ring
    cairo_stroke(cr)
end
    local xh,yh,xm,ym,xs,ys
    secs=os.date("%S")
    mins=os.date("%M")
    hours=os.date("%I")
    secs_arc=(2*math.pi/60)*secs
    -- Draw hour hand
    cairo_move_to(cr,xc,yc)
    cairo_line_to(cr,xh,yh)
    cairo_set_line_width(cr,5)
    cairo_stroke(cr)
    -- Draw minute hand
    cairo_line_to(cr,xm,ym)
    cairo_set_line_width(cr,3)
    cairo_stroke(cr)
    -- Draw seconds hand
    if show_seconds then
        cairo_line_to(cr,xs,ys)
        cairo_stroke(cr)
    end
end
function conky_clock_rings()
        local str=''
        local value=0
        str=conky_parse(str)
        value=tonumber(str)
        pct=value/pt['max']
        draw_ring(cr,pct,pt)
    end
    local cr=cairo_create(cs)
    update_num=tonumber(updates)
    if update_num>5 then
        end
    end
end
blinkingLED
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else  echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
capture_deecran_2019_06_08_09_26
