Dernière mise à jour : 08/06/2019 à 09h31
Cronographe
conkyrc
conky.config = {
background = true,
use_xft = true,
font = 'hooge 05_53:size=6',
xftalpha = 1,
update_interval = 1.0,
total_run_times = 0,
net_avg_samples = 2,
own_window = true,
--own_window_color 000000
own_window_type = 'normal',
double_buffer = true,
maximum_width = 320,
text_buffer_size = 2048,
draw_shades = false,
draw_outline = false,
draw_borders = false,
draw_graph_borders = false,
default_color = 'white',
alignment = 'top_right',
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
cpu_avg_samples = 2,
override_utf8_locale = true,
imlib_cache_size = 10000,
stippled_borders = 5,
-- Couleurs
default_color = '#ffffff', --ffd579
default_shade_color = '#333333',
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
lua_draw_hook_post = 'main',
conky.text = [[
${voffset -60}${goto 146}${font conkyweather:size=34}${execi 600 sed -n '22p' $HOME/1_accuweather/curr_cond}${font}
${voffset -3}${font conkyweather:size=20}${goto 230}${execi 600 sed -n '27p' $HOME/1_accuweather/first_days}${font}
${voffset 1}${goto 220}${execi 600 sed -n '9p' $HOME/1_accuweather/first_days}°C - ${execi 600sed -n '8p' $HOME/1_accuweather/first_days}°C
${goto 90}${execi 600 sed -n '28p' $HOME/1_accuweather/first_days}
${voffset -34}${goto 226}${execi 600 sed -n '29p' $HOME/1_accuweather/first_days}${font}
${voffset -1}
${goto 80}${execi 600 sed -n '14p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '13p' $HOME/1_accuweather/first_days}°C\
${goto 215}${execi 600 sed -n '19p' $HOME/1_accuweather/first_days}°C - ${execi 600 sed -n '18p' $HOME/1_accuweather/first_days}°C
]];conkyrc1 (pour le deuxième lua)
conky.config = {
background = true,
use_xft = true,
xftalpha = 1,
own_window = true,
gap_x = 120,
gap_y = 70,
no_buffers = true,
uppercase = false,
-- Couleurs
color0 = 'white',
color1 = 'orange',
color2 = 'green',
color3 = '#000000',
color4 = '#FF0000',
color5 = '#696969',
color6 = '#BDB76B',
color7 = '#00FF01',
color8 = '#cccccc',
conky.text = [[
]];cups.lua
-- Cups and Saucers
-- Lua conky script
-- author : Abu Yahya
-- license : Distributed under the terms of GNU GPL v3
-- 30.05.2012
-- v.1.0.1
require 'cairo'
----Adjustable Settings
coffee_table = {
name='time', arg='%I', max_value=12,
x=170, y=170,
cup_radius=35,
cup_wall_thickness=90,
cup_bg_clr=0xffffff, cup_bg_alpha=0.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=0.0,
handle_length=70, handle_circ=5,
handle_fg_clr=0xFFFFFF, handle_fg_alpha=0.0, --1.0
graduation_radius=124,
graduation_thickness=8, graduation_mark_circ=1.5,
graduation_mark_angle=30,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.5,
saucer_thickness=6, thick_saucer_circ=11/12,
saucer_radius=135, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.0,
inner_saucer=true,
txt_weight=0, txt_size=8.0,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.0,
caption='', caption2='',
name='time', arg='%H', max_value=12,
x=170, y=170,
cup_radius=2.5,
cup_wall_thickness=3,
cup_bg_clr=0xffffff, cup_bg_alpha=1.0,
cup_fg_clr=0xFFFFFF, cup_fg_alpha=1.0,
handle_length=40, handle_circ=4,
graduation_radius=127,
graduation_thickness=1, graduation_mark_circ=0.5,
graduation_mark_angle=3,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.0,
inner_saucer=true,
name='time', arg='%M', max_value=60,
x=170, y=170,
cup_radius=55,
cup_wall_thickness=120,
graduation_radius=123,
graduation_thickness=10, graduation_mark_circ=2.5,
graduation_mark_angle=90,
handle_length=110, handle_circ=3,
saucer_radius=155, thin_saucer_circ=11/12,
name='time', arg='%S', max_value=60,
x=170, y=170,
cup_radius=59,
handle_length=118, handle_circ=1,
graduation_radius=125,
graduation_thickness=6, graduation_mark_circ=0.5,
graduation_mark_angle=6,
saucer_thickness=5, thick_saucer_circ=1,
saucer_radius=145, thin_saucer_circ=11/12,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha=0.4,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.4,
name='cpu', arg='cpu0', max_value=100,
x=170, y=100,
cup_radius=20,
cup_wall_thickness=40,
cup_start_angle=0,
cup_bg_clr=0xFFFFFF, cup_bg_alpha=0.0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=1,
caption=' CPU ', caption2=' %',
graduation_radius=25,
graduation_thickness=3, graduation_mark_circ=2,
graduation_mark_angle=36,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.6,
saucer_thickness=3, thick_saucer_circ=0.85,
saucer_radius=30, thin_saucer_circ=0.85,
saucer_fg_clr=0xFFFFFF, saucer_fg_alpha= 0.3,
saucer_mark_fg_clr=0xFFFFFF, saucer_mark_fg_alpha=0.5,
inner_saucer=true,
name='freq_g', arg='/', max_value=5,
x=170, y=100,
cup_radius=12,
cup_wall_thickness=23,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='', caption2=' GHz',
graduation_thickness=4, graduation_mark_circ=4,
graduation_fg_clr=0xFFFFFF, graduation_fg_alpha=0.0,
saucer_thickness=3, thick_saucer_circ=0.75,
saucer_radius=35, thin_saucer_circ=0.75,
---------------1/2
name='downspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
caption='E. ', caption2='',
inner_saucer=true,
name='upspeedf', arg='wlo1', max_value=100,
x=100, y=170,
cup_radius=12,
cup_wall_thickness=27,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption='S ', caption2='',
saucer_radius=35, thin_saucer_circ=0.85,
------------------2/3
name='fs_used_perc', arg='/home', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= 10,
caption=' FS /: ', caption2=' %',
inner_saucer=true,
name='fs_used_perc', arg='/', max_value=100,
x=170, y=240,
cup_radius=12,
cup_start_angle=0,
xtxt=-20, ytxt= -5,
txt_fg_clr=0xFFFFFF, txt_fg_alpha=0.8,
caption=' FS H: ', caption2=' %',
end
-- displays cups and saucers
max_value = data['max_value']
x, y = data['x'], data['y']
caption = data['caption']
caption2 = data['caption2']
if xtxt ==nil then xtxt=0 end
if ytxt ==nil then ytxt=0 end
if total_angle < 0 then
else
end
end
--cup centre background
if cup_bg_alpha >0 then
else
end
cairo_stroke(display)
end
--cup wall fg
if cup_fg_alpha > 0 then
else
end
end
-- cup handle
if handle_fg_alpha>0 then
local stop_handle = (cup_sector_angle * value) + (handle_circ*0.5)
else
end
end
--saucers
---thick saucer
then
if value < (max_value/2)
end
else
end
--thin saucer
if inner_saucer == true
end
else
end
end
--saucer mark
else
end
end
--graduation mark
local start_arc_grad = 0
local stop_arc_grad = 0
local i = 0
else
end
i = i + 1
end
end
-- text
if txt_fg_alpha>0 then
cairo_stroke (display)
end
end
local str, value = '', 0
str = conky_parse(str)
else
value = tonumber(str)
end
end
end
end
function conky_main()
if conky_window == nil then
return
end
if update_num > 5 then
end
cairo_surface_destroy(cs)
cairo_destroy(display)
end
clocks_rings.lua
lua_draw_hook_pre clock_rings
Changelog:
settings_table = {
name='time',
arg='%I',
max=12,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=133,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%M',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=140,
thickness=4,
start_angle=0,
end_angle=360
name='time',
arg='%S',
max=60,
bg_colour=0xFFFFFF,
bg_alpha=0.0,
fg_colour=0xFFFFFF,
fg_alpha=0.0,
x=150, y=150,
radius=147,
thickness=4,
start_angle=0,
end_angle=360
clock_r=127
clock_x=170
clock_y=170
clock_colour=0xFFFFFF
clock_alpha=1
show_seconds=true
require 'cairo'
end
function draw_ring(cr,t,pt)
-- Draw background ring
cairo_stroke(cr)
-- Draw indicator ring
cairo_stroke(cr)
end
local xh,yh,xm,ym,xs,ys
secs=os.date("%S")
mins=os.date("%M")
hours=os.date("%I")
secs_arc=(2*math.pi/60)*secs
-- Draw hour hand
cairo_move_to(cr,xc,yc)
cairo_line_to(cr,xh,yh)
cairo_set_line_width(cr,5)
cairo_stroke(cr)
-- Draw minute hand
cairo_line_to(cr,xm,ym)
cairo_set_line_width(cr,3)
cairo_stroke(cr)
-- Draw seconds hand
if show_seconds then
cairo_line_to(cr,xs,ys)
cairo_stroke(cr)
end
end
function conky_clock_rings()
local str=''
local value=0
str=conky_parse(str)
value=tonumber(str)
pct=value/pt['max']
draw_ring(cr,pct,pt)
end
local cr=cairo_create(cs)
update_num=tonumber(updates)
if update_num>5 then
end
end
end
blinkedled.sh
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 32 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 32 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 145, 258 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 145, 258 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 33, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 33, 145 -s 40x40}${endif}
${image $HOME/.conky/cronograph/images/Blank.png -p 257, 145 -s 40x40}${if_match ${execi 1 num=$(date +%-S);rem=$(( num % 2 ));if [ $rem -eq 0 ] ; then echo 0 ; else echo 1 ; fi}==0}${image $HOME/.conky/cronograph/images/Blue.png -p 257, 145 -s 40x40}${endif}
