Dernière mise à jour : 09/06/2017 à 15h35
Ce tutoriel a été réalisé par le biais d'un POC comprenant deux machines virtuelles sous mageia 6.
Le serveur openvpn nommé "serveurmga", connecté sur un réseau local avec l'adresse ip : 192.168.1.15
Installation d'openvpn
urpmi openvpn
Copie du répertoire easy-rsa
export EASY_RSA="`pwd`"
Pour avoir
Puis on modifie /etc/openvpn/easy-rsa/vars
export KEY_SIZE=1024
Pour avoir
export KEY_SIZE=2048
On prends en compte la nouvelle configuration
On supprime par sécurité les anciens certificats générés sous /etc/openvpn/easy-rsa/keys
On génère les certificats de l'autorité de certification
Génération des clés serveurs : : serveurmga.csr, serveurmga.key, serveurmga.crt
Generating a 2048 bit RSA private key .......................................+++ ................................................................+++ writing new private key to 'serveurmga.key' ----- You are about to be asked to enter information that will be incorporated into your certificate request. What you are about to enter is what is called a Distinguished Name or a DN. There are quite a few fields but you can leave some blank For some fields there will be a default value, If you enter '.', the field will be left blank. ----- Country Name (2 letter code) [US]:FR State or Province Name (full name) [CA]:FRANCE Locality Name (eg, city) [SanFrancisco]:Bordeaux Organization Name (eg, company) [Fort-Funston]:vouf.fr Organizational Unit Name (eg, section) [changeme]: Common Name (eg, your name or your server's hostname) [serveurmga]:serveurmga Name [changeme]:vouf Email Address [mail@host.domain]: Please enter the following 'extra' attributes to be sent with your certificate request A challenge password []: On ne saisi pas de mot de passe An optional company name []: Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.0.cnf Check that the request matches the signature Signature ok The Subject's Distinguished Name is as follows countryName :PRINTABLE:'FR' stateOrProvinceName :PRINTABLE:'FRANCE' localityName :PRINTABLE:'Bordeaux' organizationName :PRINTABLE:'vouf.fr' organizationalUnitName:PRINTABLE:'changeme' commonName :PRINTABLE:'serveurmga' name :PRINTABLE:'vouf' emailAddress :IA5STRING:'mail@host.domain' Certificate is to be certified until Jun 1 13:06:57 2027 GMT (3650 days) Sign the certificate? [y/n]:y 1 out of 1 certificate requests certified, commit? [y/n]y Write out database with 1 new entries Data Base Updated
Au niveau du challenge password, il est inutile de renseigner un mot de passe.
Création des certificats des clients et du fichier clientmga.3des.key
Génération des certificats pour "un client openvpn"
[root@localhost easy-rsa]# ./build-key-pass clientmga
Un mot de passe est demandé pour la création du certificat "PEM pass phrase" . En revanche, il est inutile de renseigner un challenge password.
Generating a 2048 bit RSA private key .........................+++ .......+++ writing new private key to 'clientmga.key' Enter PEM pass phrase: Verifying - Enter PEM pass phrase: ----- You are about to be asked to enter information that will be incorporated into your certificate request. What you are about to enter is what is called a Distinguished Name or a DN. There are quite a few fields but you can leave some blank For some fields there will be a default value, If you enter '.', the field will be left blank. ----- Country Name (2 letter code) [US]:FR State or Province Name (full name) [CA]:FRANCE Locality Name (eg, city) [SanFrancisco]:Bordeaux Organization Name (eg, company) [Fort-Funston]:vouf.fr Organizational Unit Name (eg, section) [changeme]: Common Name (eg, your name or your server's hostname) [clientmga]: Name [changeme]:vouf Email Address [mail@host.domain]: Please enter the following 'extra' attributes to be sent with your certificate request A challenge password []: An optional company name []: Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.0.cnf Check that the request matches the signature Signature ok The Subject's Distinguished Name is as follows countryName :PRINTABLE:'FR' stateOrProvinceName :PRINTABLE:'FRANCE' localityName :PRINTABLE:'Bordeaux' organizationName :PRINTABLE:'vouf.fr' organizationalUnitName:PRINTABLE:'changeme' commonName :PRINTABLE:'clientmga' name :PRINTABLE:'vouf' emailAddress :IA5STRING:'mail@host.domain' Certificate is to be certified until Jun 1 13:10:54 2027 GMT (3650 days) Sign the certificate? [y/n]:y 1 out of 1 certificate requests certified, commit? [y/n]y Write out database with 1 new entries Data Base Updated
cd keysOn encrypte la clé du client avec l’algorithme 3DES
[root@localhost keys]# openssl rsa -in clientmga.key -des3 -out clientmga.3des.key
Un mot de passe est demandé...
Enter pass phrase for clientmga.key:
writing RSA key
Verifying - Enter PEM pass phrase:Sécurisation des échanges de clés
[root@localhost keys]# cd /etc/openvpn/easy-rsa
[root@localhost easy-rsa]# ./build-dh
Generating DH parameters, 2048 bit long safe prime, generator 2 This is going to take a long time ................................................................................................................+............................................................................................................................ ....................+........+...............................................................+.............+................................................................................................................................. ........................+....................................................+............................................................+..................................................+........+...................................... ................................................................................................................................................................................................................................+............ .....+...............................................................................+........................................................+.............................................................................................. ...............................................................+..........................................+..............................................................+................................................................... ....................................................................................................................+....................................................+..............++*++*
openvpn --genkey --secret keys/ta.key
On créé le fichier de configuration du client /etc/openvpn/easy-rsa/keys/Default.txt
cd /etc/openvpn/easy-rsa/keys nano Default.txt
Dans le fichier Default.txt
client dev tun proto udp # Protocol udp remote serveurmga 1194 # on peut mettre l'ip du serveur vpn, ou le nom de domaine. On retrouve le port 1194 resolv-retry infinite nobind persist-key persist-tun mute-replay-warnings ns-cert-type server key-direction 1 cipher AES-128-CBC comp-lzo verb 1 mute 20script-security 2 up /etc/openvpn/update-resolv-conf down /etc/openvpn/update-resolv-conf
On génère un fichier clientmga.ovpn qui aura à l'avantage de regrouper la configuration du client, l'autorité de certification et la clé
Télécharger MakeOpenVPN.sh et le copier sous /etc/openvpn/easy-rsa/keys
[root@localhost keys]# bash MakeOpenVPN.sh
Entrez le nom d'un client existant :
clientmga
Clé publique trouvée : clientmga
Clé privée trouvée : clientmga.3des.key
Clé publique CA trouvée : ca.crt
Clé privée tls-auth trouvée : ta.key
Terminé ! clientmga.ovpn généré avec succès.Fichier de configuration du serveur openvpn
nano /etc/sysctl.conf
net.ipv4.ip_forward = 1
Prise en compte de la configuration
sysctl -pCommande à jouer à chaque redémarrage du serveur. Voir comment l’exécuter automatiquement à chaque reboot.
Démarrage du serveur openvpn
systemctl start openvpn@server.serviceCode BASH :
[root@localhost log]# cat /var/log/openvpn-status.log OpenVPN CLIENT LIST Updated,Sat Jun 3 18:42:26 2017 Common Name,Real Address,Bytes Received,Bytes Sent,Connected Since ROUTING TABLE Virtual Address,Common Name,Real Address,Last Ref GLOBAL STATS Max bcast/mcast queue length,0 END
[root@localhost log]# cat /var/log/openvpn.log Sat Jun 3 18:41:39 2017 OpenVPN 2.4.0 x86_64-mageia-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 14 2017 Sat Jun 3 18:41:39 2017 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.09 Sat Jun 3 18:41:39 2017 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet. Sat Jun 3 18:41:39 2017 Diffie-Hellman initialized with 2048 bit key Sat Jun 3 18:41:39 2017 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Jun 3 18:41:39 2017 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication Sat Jun 3 18:41:39 2017 ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=enp0s3 HWADDR=08:00:27:00:b3:46 Sat Jun 3 18:41:39 2017 TUN/TAP device tun0 opened Sat Jun 3 18:41:39 2017 TUN/TAP TX queue length set to 100 Sat Jun 3 18:41:39 2017 do_ifconfig, tt->did_ifconfig_ipv6_setup=0 Sat Jun 3 18:41:39 2017 /usr/sbin/ifconfig tun0 10.8.0.1 pointopoint 10.8.0.2 mtu 1500 Sat Jun 3 18:41:39 2017 /usr/sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2 Sat Jun 3 18:41:39 2017 Could not determine IPv4/IPv6 protocol. Using AF_INET Sat Jun 3 18:41:39 2017 Socket Buffers: R=[212992->212992] S=[212992->212992] Sat Jun 3 18:41:39 2017 UDPv4 link local (bound): [AF_INET]192.168.1.15:1194 Sat Jun 3 18:41:39 2017 UDPv4 link remote: [AF_UNSPEC] Sat Jun 3 18:41:39 2017 GID set to nogroup Sat Jun 3 18:41:39 2017 UID set to nobody Sat Jun 3 18:41:39 2017 MULTI: multi_init called, r=256 v=256 Sat Jun 3 18:41:39 2017 IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0 Sat Jun 3 18:41:39 2017 Initialization Sequence Completed
Sur le poste client en mode commande
On se connecter root
On installe openvpn
urpmi openvpn
On copie le fichier clientmga.ovpn sous /etc/openvpn/
On créé un fichier /etc/openvpn/update-resolv-conf qui contiendra :
#!/usr/bin/env bash # # Parses DHCP options from openvpn to update resolv.conf # To use set as 'up' and 'down' script in your openvpn *.conf: # up /etc/openvpn/update-resolv-conf # down /etc/openvpn/update-resolv-conf # # Used snippets of resolvconf script by Thomas Hood <jdthood@yahoo.co.uk> # and Chris Hanson # Licensed under the GNU GPL. See /usr/share/common-licenses/GPL. # 07/2013 colin@daedrum.net Fixed intet name # 05/2006 chlauber@bnc.ch # 09/2017 Adapté par vouf pour Mageia # # Example envs set from openvpn: # foreign_option_1='dhcp-option DNS 193.43.27.132' # foreign_option_2='dhcp-option DNS 193.43.27.133' # foreign_option_3='dhcp-option DOMAIN be.bnc.ch' # foreign_option_4='dhcp-option DOMAIN-SEARCH bnc.local' ## The 'type' builtins will look for file in $PATH variable, so we set the ## PATH below. You might need to directly set the path to 'resolvconf' ## manually if it still doesn't work, i.e. ## RESOLVCONF=/usr/sbin/resolvconf ## export PATH=$PATH:/sbin:/usr/sbin:/bin:/usr/bin RESOLVCONF=$(type -p resolvconf) case $script_type in up) for optionname in ${!foreign_option_*} ; do option="${!optionname}" echo $option part1=$(echo "$option" | cut -d " " -f 1) if [ "$part1" == "dhcp-option" ] ; then part2=$(echo "$option" | cut -d " " -f 2) part3=$(echo "$option" | cut -d " " -f 3) if [ "$part2" == "DNS" ] ; then IF_DNS_NAMESERVERS="$IF_DNS_NAMESERVERS $part3" fi if [[ "$part2" == "DOMAIN" || "$part2" == "DOMAIN-SEARCH" ]] ; then IF_DNS_SEARCH="$IF_DNS_SEARCH $part3" fi fi done R="" if [ "$IF_DNS_SEARCH" ]; then R="search " for DS in $IF_DNS_SEARCH ; do R="${R} $DS" done R="${R} " fi for NS in $IF_DNS_NAMESERVERS ; do R="${R}nameserver $NS " done echo -n "$R" | $RESOLVCONF -a "${dev}" ;; down) $RESOLVCONF -d "${dev}" ;; esac # Workaround / jm@epiclabs.io # force exit with no errors. Due to an apparent conflict with the Network Manager # $RESOLVCONF sometimes exits with error code 6 even though it has performed the # action correctly and OpenVPN shuts down. exit 0
On donne les droits d'execution au fichier /etc/openvpn/update-resolv-conf
chmod+x /etc/openvpn/update-resolv-conf
On lance le client vpn
[root@localhost vouf]# openvpn --config clientmga.ovpn Sat Jun 3 18:44:37 2017 OpenVPN 2.4.0 x86_64-mageia-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 14 2017 Sat Jun 3 18:44:37 2017 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.09 Enter Private Key Password: ********* Sat Jun 3 18:44:40 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Sat Jun 3 18:44:40 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]192.168.1.15:1194 Sat Jun 3 18:44:40 2017 UDP link local: (not bound) Sat Jun 3 18:44:40 2017 UDP link remote: [AF_INET]192.168.1.15:1194 Sat Jun 3 18:44:40 2017 [serveurmga] Peer Connection Initiated with [AF_INET]192.168.1.15:1194 Sat Jun 3 18:44:42 2017 TUN/TAP device tun0 opened Sat Jun 3 18:44:42 2017 do_ifconfig, tt->did_ifconfig_ipv6_setup=0 Sat Jun 3 18:44:42 2017 /usr/sbin/ifconfig tun0 10.8.0.6 pointopoint 10.8.0.5 mtu 1500 Sat Jun 3 18:44:42 2017 Initialization Sequence Completed
Sur le serveur, on voit la connexion s'établir :
Sat Jun 3 18:44:42 2017 192.168.1.16:55809 TLS: Initial packet from [AF_INET]192.168.1.16:55809, sid=d03d78cc 43d44f6f Sat Jun 3 18:44:42 2017 192.168.1.16:55809 VERIFY OK: depth=1, C=FR, ST=FRANCE, L=Bordeaux, O=vouf.fr, OU=changeme, CN=serveurmga, name=vouf, emailAddress=mail@host.domain Sat Jun 3 18:44:42 2017 192.168.1.16:55809 VERIFY OK: depth=0, C=FR, ST=FRANCE, L=Bordeaux, O=vouf.fr, OU=changeme, CN=clientmga, name=vouf, emailAddress=mail@host.domain Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_VER=2.4.0 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_PLAT=linux Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_PROTO=2 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_NCP=2 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_LZ4=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_LZ4v2=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_LZO=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_COMP_STUB=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_COMP_STUBv2=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 peer info: IV_TCPNL=1 Sat Jun 3 18:44:42 2017 192.168.1.16:55809 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA Sat Jun 3 18:44:42 2017 192.168.1.16:55809 [clientmga] Peer Connection Initiated with [AF_INET]192.168.1.16:55809 Sat Jun 3 18:44:42 2017 clientmga/192.168.1.16:55809 MULTI_sva: pool returned IPv4=10.8.0.6, IPv6=(Not enabled) Sat Jun 3 18:44:42 2017 clientmga/192.168.1.16:55809 MULTI: Learn: 10.8.0.6 -> clientmga/192.168.1.16:55809 Sat Jun 3 18:44:42 2017 clientmga/192.168.1.16:55809 MULTI: primary virtual IP for clientmga/192.168.1.16:55809: 10.8.0.6 Sat Jun 3 18:44:43 2017 clientmga/192.168.1.16:55809 PUSH: Received control message: 'PUSH_REQUEST' Sat Jun 3 18:44:43 2017 clientmga/192.168.1.16:55809 SENT CONTROL [clientmga]: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 208.67.222.222,dhcp-option DNS 208.67.220.220,route 10.8.0.0 255.255.255.0,topology net30,ping 10,ping-restart 120,ifconfig 10.8.0.6 10.8.0.5,peer-id 0,cipher AES-256-GCM' (status=1) Sat Jun 3 18:44:43 2017 clientmga/192.168.1.16:55809 Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key Sat Jun 3 18:44:43 2017 clientmga/192.168.1.16:55809 Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
[Tuto] Monter son VPN perso avec OpenVPN . Un grand merci pour son travail, sans lui ce tutoriel n'aurait pas pu voir le jour !
