Configurer son serveur et ses clients vpn sous mageia
Dernière mise à jour : 03/06/2017 à 18h36
Documentation en cours de rédaction en cours de rédaction !!
urpmi openvpn
Copie du répertoire easy-rsa
cd /etc/openvpn/easy-rsa
nano vars
export EASY_RSA="`pwd`"
Pour avoir
export KEY_SIZE=1024
Pour avoir
export KEY_SIZE=2048
[root@localhost easy-rsa]# source ./vars
NOTE: If you run ./clean-all, I will be doing a rm -rf on /etc/openvpn/easy-rsa/keys
Generating a 2048 bit RSA private key
writing new private key to 'ca.key'
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [US]:FR
State or Province Name (full name) [CA]:FRANCE
Locality Name (eg, city) [SanFrancisco]:Bordeaux
Organization Name (eg, company) [Fort-Funston]:vouf.fr
Organizational Unit Name (eg, section) [changeme]:
Common Name (eg, your name or your server's hostname) [changeme]:serveurmga
Name [changeme]:vouf
Email Address [mail@host.domain]:
Génération des clés serveurs : : serveurmga.csr, serveurmga.key, serveurmga.crt
writing new private key to 'serveurmga.key'
Common Name (eg, your name or your server's hostname) [serveurmga]:serveurmga
Please enter the following 'extra' attributes
to be sent with your certificate request
A challenge password []: On ne saisi pas de mot de passe
An optional company name []:
Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.0.cnf
Check that the request matches the signature
Signature ok
The Subject's Distinguished Name is as follows
countryName           :PRINTABLE:'FR'
stateOrProvinceName   :PRINTABLE:'FRANCE'
localityName          :PRINTABLE:'Bordeaux'
organizationName      :PRINTABLE:'vouf.fr'
organizationalUnitName:PRINTABLE:'changeme'
commonName            :PRINTABLE:'serveurmga'
emailAddress          :IA5STRING:'mail@host.domain'
Certificate is to be certified until Jun  1 13:06:57 2027 GMT (3650 days)
Sign the certificate? [y/n]:y
1 out of 1 certificate requests certified, commit? [y/n]y
Write out database with 1 new entries
Data Base Updated
Fichier de configuration du serveur openvpn
serveurmga.crt
-rw-r--r-- 1 root root 1074 juin   3 15:06 serveurmga.csr
-rw------- 1 root root 1704 juin   3 15:06 serveurmga.key
Création des certificats des clients et du fichier
[root@localhost easy-rsa]# ./build-key-pass clientmga
[sound]
writing new private key to 'clientmga.key'
Enter PEM pass phrase:
Verifying - Enter PEM pass phrase:
Common Name (eg, your name or your server's hostname) [clientmga]:
Signature ok
commonName            :PRINTABLE:'clientmga'
Certificate is to be certified until Jun  1 13:10:54 2027 GMT (3650 days)
Data Base Updated
cd keys
[root@localhost keys]# openssl rsa -in clientmga.key -des3 -out clientmga.3des.key
Enter pass phrase for clientmga.key:
writing RSA key
[root@localhost keys]# cd /etc/openvpn/easy-rsa
[root@localhost easy-rsa]#  ./build-dh
Generating DH parameters, 2048 bit long safe prime, generator 2
This is going to take a long time
openvpn --genkey --secret keys/ta.key
cd /etc/openvpn/easy-rsa/keys
nano Default.txt
client
dev tun
proto udp # Protocol udp
remote serveurmga 1194 # on peut mettre l'ip du serveur vpn, ou le nom de domaine. On retrouve le port 1194
resolv-retry infinite
nobind
persist-key
persist-tun
mute-replay-warnings
ns-cert-type server
key-direction 1
cipher AES-128-CBC
comp-lzo
verb 1
mute 20
Télécharger MakeOpenVPN.sh et le copier sous /etc/openvpn/easy-rsa/keys
[root@localhost keys]# bash MakeOpenVPN.sh
Entrez le nom d'un client existant :
clientmga
Clé publique trouvée : clientmga
Clé privée trouvée : clientmga.3des.key
Clé publique CA trouvée : ca.crt
Clé privée tls-auth trouvée : ta.key
Terminé ! clientmga.ovpn généré avec succès.
local 192.168.1.15 # adresse IP locale de votre serveur
dev tun # type de VPN, tun (tunnel IP) ou tap (tunnel Ethernet/bridge)
proto udp # protocole à utiliser : tcp ou udp, généralement udp
port 1194 # le port par défaut pour OpenVPN, à ajuster au besoin
ca /etc/openvpn/easy-rsa/keys/ca.crt # clé publique de l’autorité de certification
cert /etc/openvpn/easy-rsa/keys/serveurmga.crt # Clé publique du serveur
key /etc/openvpn/easy-rsa/keys/serveurmga.key # Clé privée du serveur
dh /etc/openvpn/easy-rsa/keys/dh2048.pem # si vous êtes restés sur du 2024 bits
server 10.8.0.0 255.255.255.0 #le réseau au sein duquel vous allez attribuer des IP. Les clients auront une ip en 10.8.0x
push "redirect-gateway def1 bypass-dhcp" # Permet au serveur de se comporter comme une passerelle.
#push "dhcp-option DNS 10.8.0.1" # votre serveur DNS primaire (votre routeur, souvent)
push "dhcp-option DNS 208.67.222.222" # votre serveur DNS primaire OpenDNS
push "dhcp-option DNS 208.67.220.220" # votre serveur DNS primaire OpenDNS
# vous pouvez aussi utiliser le DNS Google 8.8.8.8 ou OpenDNS 208.67.222.222
# pour le reste, a priori pas de raisons d'y toucher à moins de savoir ce que vous faites !
client-to-client
duplicate-cn
keepalive 10 120
tls-auth /etc/openvpn/easy-rsa/keys/ta.key 0
cipher AES-128-CBC
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
status /var/log/openvpn-status.log 20
log /var/log/openvpn.log
verb 3
 nano /etc/sysctl.conf
net.ipv4.ip_forward = 1
[root@localhost keys]# ifconfig -a
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.15  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 2a01:cb19:1a2:5200:a00:27ff:fe00:b346  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::a00:27ff:fe00:b346  prefixlen 64  scopeid 0x20<link>
        ether 08:00:27:00:b3:46  txqueuelen 1000  (Ethernet)
        RX packets 194036  bytes 138807516 (132.3 MiB)
        RX errors 0  dropped 2  overruns 0  frame 0
        TX packets 191523  bytes 135687027 (129.4 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Boucle locale)
        RX packets 34  bytes 4214 (4.1 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 34  bytes 4214 (4.1 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.8.0.1  netmask 255.255.255.255  destination 10.8.0.2
        inet6 fe80::3a19:dbb5:604e:afb8  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 100  (UNSPEC)
        RX packets 79307  bytes 22061882 (21.0 MiB)
        TX packets 110498  bytes 105230363 (100.3 MiB)
Created symlink /etc/systemd/system/openvpn.target.wants/openvpn@server.service &#8594; /usr/lib/systemd/system/openvpn@.service.
Démarrage du serveur openvpn
systemctl start openvpn@server.service
