Dernière mise à jour : 03/06/2017 à 18h34
urpmi openvpn
Copie du répertoire easy-rsa
export EASY_RSA="`pwd`"
Pour avoir
export KEY_SIZE=1024
Pour avoir
export KEY_SIZE=2048
Génération des clés serveurs : : serveurmga.csr, serveurmga.key, serveurmga.crt
Generating a 2048 bit RSA private key .......................................+++ ................................................................+++ writing new private key to 'serveurmga.key' ----- You are about to be asked to enter information that will be incorporated into your certificate request. What you are about to enter is what is called a Distinguished Name or a DN. There are quite a few fields but you can leave some blank For some fields there will be a default value, If you enter '.', the field will be left blank. ----- Country Name (2 letter code) [US]:FR State or Province Name (full name) [CA]:FRANCE Locality Name (eg, city) [SanFrancisco]:Bordeaux Organization Name (eg, company) [Fort-Funston]:vouf.fr Organizational Unit Name (eg, section) [changeme]: Common Name (eg, your name or your server's hostname) [serveurmga]:serveurmga Name [changeme]:vouf Email Address [mail@host.domain]: Please enter the following 'extra' attributes to be sent with your certificate request A challenge password []: On ne saisi pas de mot de passe An optional company name []: Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.0.cnf Check that the request matches the signature Signature ok The Subject's Distinguished Name is as follows countryName :PRINTABLE:'FR' stateOrProvinceName :PRINTABLE:'FRANCE' localityName :PRINTABLE:'Bordeaux' organizationName :PRINTABLE:'vouf.fr' organizationalUnitName:PRINTABLE:'changeme' commonName :PRINTABLE:'serveurmga' name :PRINTABLE:'vouf' emailAddress :IA5STRING:'mail@host.domain' Certificate is to be certified until Jun 1 13:06:57 2027 GMT (3650 days) Sign the certificate? [y/n]:y 1 out of 1 certificate requests certified, commit? [y/n]y Write out database with 1 new entries Data Base Updated
Fichier de configuration du serveur openvpn
serveurmga.crt
-rw-r--r-- 1 root root 1074 juin 3 15:06 serveurmga.csr
-rw------- 1 root root 1704 juin 3 15:06 serveurmga.key
nano /etc/sysctl.conf
net.ipv4.ip_forward = 1
Démarrage du serveur openvpn
systemctl start openvpn@server.serviceCréation des certificats des clients et du fichier
[root@localhost easy-rsa]# ./build-key-pass clientmga
[sound]
Generating a 2048 bit RSA private key .........................+++ .......+++ writing new private key to 'clientmga.key' Enter PEM pass phrase: Verifying - Enter PEM pass phrase: ----- You are about to be asked to enter information that will be incorporated into your certificate request. What you are about to enter is what is called a Distinguished Name or a DN. There are quite a few fields but you can leave some blank For some fields there will be a default value, If you enter '.', the field will be left blank. ----- Country Name (2 letter code) [US]:FR State or Province Name (full name) [CA]:FRANCE Locality Name (eg, city) [SanFrancisco]:Bordeaux Organization Name (eg, company) [Fort-Funston]:vouf.fr Organizational Unit Name (eg, section) [changeme]: Common Name (eg, your name or your server's hostname) [clientmga]: Name [changeme]:vouf Email Address [mail@host.domain]: Please enter the following 'extra' attributes to be sent with your certificate request A challenge password []: An optional company name []: Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.0.cnf Check that the request matches the signature Signature ok The Subject's Distinguished Name is as follows countryName :PRINTABLE:'FR' stateOrProvinceName :PRINTABLE:'FRANCE' localityName :PRINTABLE:'Bordeaux' organizationName :PRINTABLE:'vouf.fr' organizationalUnitName:PRINTABLE:'changeme' commonName :PRINTABLE:'clientmga' name :PRINTABLE:'vouf' emailAddress :IA5STRING:'mail@host.domain' Certificate is to be certified until Jun 1 13:10:54 2027 GMT (3650 days) Sign the certificate? [y/n]:y 1 out of 1 certificate requests certified, commit? [y/n]y Write out database with 1 new entries Data Base Updated
cd keysCode BASH :
[root@localhost keys]# openssl rsa -in clientmga.key -des3 -out clientmga.3des.key
Enter pass phrase for clientmga.key:
writing RSA key
Verifying - Enter PEM pass phrase:Code BASH :
[root@localhost keys]# cd /etc/openvpn/easy-rsa
[root@localhost easy-rsa]# ./build-dh
Generating DH parameters, 2048 bit long safe prime, generator 2 This is going to take a long time ................................................................................................................+............................................................................................................................ ....................+........+...............................................................+.............+................................................................................................................................. ........................+....................................................+............................................................+..................................................+........+...................................... ................................................................................................................................................................................................................................+............ .....+...............................................................................+........................................................+.............................................................................................. ...............................................................+..........................................+..............................................................+................................................................... ....................................................................................................................+....................................................+..............++*++*
openvpn --genkey --secret keys/ta.key
cd /etc/openvpn/easy-rsa/keys nano Default.txt
Télécharger MakeOpenVPN.sh et le copier sous /etc/openvpn/easy-rsa/keys
[root@localhost keys]# bash MakeOpenVPN.sh
Entrez le nom d'un client existant :
clientmga
Clé publique trouvée : clientmga
Clé privée trouvée : clientmga.3des.key
Clé publique CA trouvée : ca.crt
Clé privée tls-auth trouvée : ta.key
Terminé ! clientmga.ovpn généré avec succès.Mis à jour par Vouf le 03/06/2017
