Dernière mise à jour : 28/09/2013 à 23h15
Requis
Avoir Conky d'installé sur sa Mageia
Afficher les fichiers cachés pour son /home
du simple:
au compliquer avec plusieurs:
ou avec du lua:
Installer conky
conky ,on installe
Créer son conkyrc
Chez moi : /home/romuald/
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
double_buffer yes
text_buffer_size 256
draw_shades no
draw_outline no
draw_borders yes
draw_graph_borders no
default_color white
default_outline_color white
gap_y 690 position verticale
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
color1 white
color2 cacaca
color3 cornflowerblue
color4 626262
color5 929292
color6 828282
#cornflowerblue
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
draw_shades no
draw_outline no
draw_borders yes
default_color white
no_buffers yes
uppercase no
cpu_avg_samples 2
color1 white
color2 cacaca
color4 626262
color5 929292
color6 828282
#cornflowerblue
Sauter une ligne
ajouter
TEXT
sauter une ligne
${color3}KDE: ${color2}4.8.5
${color3}${hr}
${alignc}CPU
${color3}${hr}
${alignc}CPU
Cela donnera ceci:
ALT F2 killall conky
ALT F2 conky
Multi conky
.conky
full
conkyrc 1
conkyrc 2
conkyrc3
.bin
dans ce dossier
killall conky
sleep 10
exit
Le lua
background yes
use_xft yes
xftfont Sans:size=10
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
own_window_transparent no
own_window_color 000000
own_window_argb_value 0
double_buffer yes
minimum_size 1000
maximum_width 1000
text_buffer_size 1024
draw_shades no
draw_outline no
draw_borders no
default_color white
alignment top_left
gap_x 330
gap_y 10
no_buffers yes
uppercase no
cpu_avg_samples 2
color1 white
color2 orange
color3 6495ee
color4 green
#cornflowerblue
color5 red
color6 yellow
# Lua Load
#lua_draw_hook_pre draw_bg
#lua_draw_hook_pre main
TEXT
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 1000
maximum_width 1000
draw_shades no
draw_outline no
draw_borders no
default_color white
alignment top_left
gap_x 330
gap_y 10
no_buffers yes
uppercase no
cpu_avg_samples 2
color1 white
color2 orange
color3 6495ee
color4 green
#cornflowerblue
color5 red
color6 yellow
# Lua Load
TEXT
lua_draw_hook_pre ring_stats
Changelog:
require 'cairo'
function conky_main_rings()
if (os.date("%l"))=='12' then
heure=(os.date("%M")/60)
else
end
-- START PARAMETERS HERE
local rings_settings={
name="cpu",
arg="cpu0",
max=100,
xc=80,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="exec",
max=100,
xc=80,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
name="cpu",
arg="cpu1",
max=100,
xc=200,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="exec",
max=100,
xc=200,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
name="memperc",
arg="",
max=100,
xc=320,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="swapperc",
arg="",
max=100,
xc=320,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
name="fs_used_perc",
arg="/",
max=100,
xc=440,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
arg="/home",
max=100,
xc=560,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="downspeedf",
arg="eth0",
max=500,
xc=680,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="upspeedf",
arg="eth0",
max=100,
xc=800,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="",
arg=heure,
max=11.99,
xc=920,
yc=80,
radius=57,
thickness=5,
gap_sectors=5,
sectors=12,
name="",
max=59.99,
xc=920,
yc=80,
radius=50,
thickness=5,
start_angle=0,
end_angle=360,
gap_sectors=1,
sectors=60,
fill_sector=false,
name="time",
arg="%S",
max=60,
xc=920,
yc=80,
radius=43,
thickness=5,
start_angle=0,
end_angle=360,
sectors=60,
fill_sector=false,
--END OF PARAMETERS HERE
--main function
conky_window.drawable,
local cr=cairo_create(cs)
end
end
cairo_destroy(cr)
end
function draw_ring(cr, t)
end
for x = 1, #tcol1 do
tcol1[x].dA = 0
tcol1[x].dP = 0
tcol1[x].dR = 0
tcol1[x].dG = 0
tcol1[x].dB = 0
end
end
return tcol1
end
--check values
local function setup(t)
return
end
if t.max==nil then
print ("for name=" .. t.name)
print ("with arg=" .. t.arg)
return
end
if t.bg_colour1==nil then
end
if t.fg_colour1==nil then
end
if t.bd_colour1==nil then
end
--some checks
--check colors tables
for i=1, #t.bg_colour1 do
end
for i=1, #t.fg_colour1 do
end
for i=1, #t.bd_colour1 do
end
if t.bg_colour2~=nil then
for i=1, #t.bg_colour2 do
end
end
if t.fg_colour2~=nil then
for i=1, #t.fg_colour2 do
end
end
if t.bd_colour2~=nil then
for i=1, #t.bd_colour2 do
end
end
local tmp_angle=t.end_angle
t.end_angle= t.start_angle
t.start_angle = tmp_angle
-- print ("inversed angles")
t.end_angle=360+t.start_angle
print ("reduce angles")
end
end
if t.int_radius>t.radius then
local tmp_radius=t.radius
t.radius=t.int_radius
t.int_radius=tmp_radius
print ("inversed radius")
end
t.int_radius=0
print ("int radius set to 0")
end
end
end
--initialize table
setup(t)
--initialize cairo context
cairo_save(cr)
cairo_translate(cr,t.xc,t.yc)
--get value
local value = 0
if t.name ~="" then
else
value = tonumber(t.arg)
end
--initialize sectors
--angle of a sector :
--value of a sector :
--first angle of a sector :
local tcolor
if valpc==1 then return end
tcolor=t.bg_colour1
if valpc==0 then return end
tcolor=t.fg_colour1
tcolor=t.bd_colour1
end
--angles of arcs
if #tcolor==1 then
--plain color
vG+tcolor[1].dG*idx,
vB+tcolor[1].dB*idx,
vA+tcolor[1].dA*idx )
else
--radient color
for i=1, #tcolor do
vP+tcolor[i].dP*idx,
vR+tcolor[i].dR*idx,
vG+tcolor[i].dG*idx,
vB+tcolor[i].dB*idx,
vA+tcolor[i].dA*idx )
end
cairo_set_source (cr, pat)
cairo_pattern_destroy(pat)
end
--start drawing
cairo_save(cr)
--point A
local angle_a
if t.cap == "p" then
angle_a = int_delta
end
angle_a = int_delta+int_angle
end
else --t.cap=="r"
angle_a = ext_delta
end
angle_a = ext_delta+ext_angle
end
end
--point B
local angle_b = ext_delta
end
angle_b = ext_delta+ext_angle
end
else
end
end
end
-- EXTERNAL ARC B --> C
local b0,b1
if t.inverse_arc then
else
end
else
else
end
end
---POINT D
local angle_c, angle_d
angle_d = angle-int_delta
end
angle_d=int_delta+int_angle
end
else
angle_d = angle-ext_delta
end
angle_d = ext_angle+ext_delta
end
end
-- INTERNAL ARC D --> A
local d0,d1
if t.cap=="p" then
else
end
else
else
end
end
else
else
end
else
else
end
end
end
--draw sector
cairo_move_to(cr,ax,ay)
cairo_line_to(cr,bx,by)
cairo_arc(cr,0,0,re,b0,b1)
cairo_line_to(cr,dx,dy)
cairo_close_path (cr);
--stroke or fill sector
cairo_stroke(cr)
else
cairo_fill(cr)
end
cairo_restore(cr)
end
--draw sectors
local index = 0
for i = n0,n1,n2 do
index = index +1
local valueZ=1
local cstA, cstB = (i-1),i
if not t.fill_sector then
end
else
end
if t.foreground ~= false then
end
if t.background ~= false then
end
end
cairo_restore(cr)
end
Changelog:
require 'cairo'
else
end
name="cpu",
arg="cpu0",
max=100,
xc=80,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="exec",
max=100,
xc=80,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
name="cpu",
arg="cpu1",
max=100,
xc=200,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="exec",
max=100,
xc=200,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
name="memperc",
arg="",
max=100,
xc=320,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="swapperc",
arg="",
max=100,
xc=320,
yc=80,
radius=53,
thickness=5,
gap_sectors=2,
sectors=10,
arg="/",
max=100,
xc=440,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
arg="/home",
max=100,
xc=560,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="downspeedf",
arg="eth0",
max=500,
xc=680,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="upspeedf",
arg="eth0",
max=100,
xc=800,
yc=80,
radius=57,
thickness=5,
gap_sectors=2,
sectors=10,
name="",
arg=heure,
max=11.99,
xc=920,
yc=80,
radius=57,
thickness=5,
gap_sectors=5,
sectors=12,
name="",
max=59.99,
xc=920,
yc=80,
radius=50,
thickness=5,
start_angle=0,
end_angle=360,
gap_sectors=1,
sectors=60,
fill_sector=false,
name="time",
arg="%S",
max=60,
xc=920,
yc=80,
radius=43,
thickness=5,
start_angle=0,
end_angle=360,
sectors=60,
fill_sector=false,
--main function
end
end
cairo_destroy(cr)
end
end
tcol1[x].dA = 0
tcol1[x].dP = 0
tcol1[x].dR = 0
tcol1[x].dG = 0
tcol1[x].dB = 0
end
end
return tcol1
end
--check values
return
end
if t.max==nil then
return
end
end
end
end
--some checks
end
end
end
end
end
end
end
end
end
end
end
end
t.int_radius=0
end
end
end
--initialize table
setup(t)
cairo_save(cr)
--get value
local value = 0
if t.name ~="" then
else
end
local tcolor
tcolor=t.bg_colour1
tcolor=t.fg_colour1
tcolor=t.bd_colour1
end
--angles of arcs
if #tcolor==1 then
--plain color
else
--radient color
for i=1, #tcolor do
end
end
--start drawing
cairo_save(cr)
--point A
local angle_a
angle_a = int_delta
end
end
else --t.cap=="r"
angle_a = ext_delta
end
end
end
--point B
end
end
else
end
end
end
local b0,b1
else
end
else
else
end
end
---POINT D
end
end
else
end
end
end
local d0,d1
if t.cap=="p" then
else
end
else
else
end
end
else
else
end
else
else
end
end
end
--draw sector
cairo_stroke(cr)
else
cairo_fill(cr)
end
cairo_restore(cr)
end
--draw sectors
local index = 0
for i = n0,n1,n2 do
index = index +1
local valueZ=1
end
else
end
end
end
end
cairo_restore(cr)
end
conky -c ~/.conky/tous/tous
Quelques adresses utiles
http://conky.sourceforge.net/
Ils y en pleins d'autres.
