Thermal monitor ne fonctionne pas [Réglé]
Antoniop Membre non connecté
- Voir le profil du membre Antoniop
La liste de sources est vide.
Je précise que j'ai un CPU intel et carte graphique AMD, mais c'est plus la partie CPU qui m'intéresse.
J'ai bien installé lm-sensors et lancé la détection, d'ailleurs sensors retourne des valeurs :
$ sensors nct6779-isa-0290 Adapter: ISA adapter Vcore: 928.00 mV (min = +0.00 V, max = +1.74 V) in1: 1.01 V (min = +0.00 V, max = +0.00 V) ALARM AVCC: 3.34 V (min = +2.98 V, max = +3.63 V) +3.3V: 3.34 V (min = +2.98 V, max = +3.63 V) in4: 1.01 V (min = +0.00 V, max = +0.00 V) ALARM in5: 2.04 V (min = +0.00 V, max = +0.00 V) ALARM in6: 288.00 mV (min = +0.00 V, max = +0.00 V) ALARM 3VSB: 3.39 V (min = +2.98 V, max = +3.63 V) Vbat: 3.33 V (min = +2.70 V, max = +3.63 V) in9: 1.06 V (min = +0.00 V, max = +0.00 V) ALARM in10: 224.00 mV (min = +0.00 V, max = +0.00 V) ALARM in11: 192.00 mV (min = +0.00 V, max = +0.00 V) ALARM in12: 192.00 mV (min = +0.00 V, max = +0.00 V) ALARM in13: 192.00 mV (min = +0.00 V, max = +0.00 V) ALARM in14: 200.00 mV (min = +0.00 V, max = +0.00 V) ALARM fan1: 889 RPM (min = 0 RPM) fan2: 0 RPM (min = 0 RPM) fan3: 0 RPM (min = 0 RPM) fan4: 1558 RPM (min = 0 RPM) fan5: 0 RPM (min = 0 RPM) SYSTIN: +42.0°C (high = +0.0°C, hyst = +0.0°C) ALARM sensor = thermistor CPUTIN: +42.0°C (high = +80.0°C, hyst = +75.0°C) sensor = thermistor AUXTIN0: +95.5°C sensor = thermistor AUXTIN1: +94.0°C sensor = thermistor AUXTIN2: +94.0°C sensor = thermistor AUXTIN3: -13.0°C sensor = thermal diode PECI Agent 0: +37.5°C PCH_CHIP_CPU_MAX_TEMP: +0.0°C PCH_CHIP_TEMP: +0.0°C PCH_CPU_TEMP: +0.0°C intrusion0: ALARM intrusion1: ALARM beep_enable: disabled acpitz-acpi-0 Adapter: ACPI interface temp1: +27.8°C (crit = +106.0°C) temp2: +29.8°C (crit = +106.0°C) coretemp-isa-0000 Adapter: ISA adapter Package id 0: +46.0°C (high = +85.0°C, crit = +105.0°C) Core 0: +46.0°C (high = +85.0°C, crit = +105.0°C) Core 1: +44.0°C (high = +85.0°C, crit = +105.0°C) Core 2: +39.0°C (high = +85.0°C, crit = +105.0°C) Core 3: +42.0°C (high = +85.0°C, crit = +105.0°C) amdgpu-pci-0100 Adapter: PCI adapter vddgfx: 875.00 mV fan1: 652 RPM (min = 0 RPM, max = 2900 RPM) edge: +56.0°C (crit = +94.0°C, hyst = -273.1°C) PPT: 10.22 W (cap = 180.00 W)
J'ai trouvé cette page https://askubuntu.com/questions/1409715/kubuntu-22-04-thermal-monitor-broken-cannot-see-cpu-and-sdd-temperatures
, qui parle d'un problème identique quoique ancien, mais avant de me lancer dans le patch indiqué, je préfère voir si je suis le seul ou pas à avoir ce problème...
Après l' installation du paquet plasma-applet-thermal-monitor ( je suppose que c' est celui ci ?), dans ma liste de sources, je vois quelque chose relative à la carte video, les disques ( y compris lecteur de DVD et lecteur de carte SD ( il y a des capteurs de température là dessus ?). Mais je vois rien relatif à la température CPU.
gorfou Membre non connecté
- Voir le profil du membre gorfou
Dans le plasmoid "Utilisation de chaque coeur" on peut le configurer pour ajouter les températures CPU
"Détails du senseur" -> click sur Senseurs -> Sélection "[Groupe] Processeur" puis "[Groupe] Température (°C)"
gorfou :Bonjour,
ça marche !
J'ai pu également choisir la sonde de la carte mère.
Merci !
Je m'explique, quand je clique sur le choix des senseurs matériels, je vois deux interfaces proposées, comme dans l'image ci-dessous.
Or les sondes CPU ne sont pas sur ces interfaces, comme il apparait quand je tape la commande "sensors" (j'ai lancé un encodage vidéo pour voir si les températures bougent), les températures CPU apparraissent dans la catégorie coretemp-isa-0000 :
$ sensors nct6779-isa-0290 Adapter: ISA adapter Vcore: 1.08 V (min = +0.00 V, max = +1.74 V) in1: 1.01 V (min = +0.00 V, max = +0.00 V) ALARM AVCC: 3.34 V (min = +2.98 V, max = +3.63 V) +3.3V: 3.34 V (min = +2.98 V, max = +3.63 V) in4: 1.01 V (min = +0.00 V, max = +0.00 V) ALARM in5: 2.04 V (min = +0.00 V, max = +0.00 V) ALARM in6: 288.00 mV (min = +0.00 V, max = +0.00 V) ALARM 3VSB: 3.39 V (min = +2.98 V, max = +3.63 V) Vbat: 3.33 V (min = +2.70 V, max = +3.63 V) in9: 1.05 V (min = +0.00 V, max = +0.00 V) ALARM in10: 224.00 mV (min = +0.00 V, max = +0.00 V) ALARM in11: 184.00 mV (min = +0.00 V, max = +0.00 V) ALARM in12: 192.00 mV (min = +0.00 V, max = +0.00 V) ALARM in13: 184.00 mV (min = +0.00 V, max = +0.00 V) ALARM in14: 192.00 mV (min = +0.00 V, max = +0.00 V) ALARM fan1: 1133 RPM (min = 0 RPM) fan2: 0 RPM (min = 0 RPM) fan3: 0 RPM (min = 0 RPM) fan4: 2064 RPM (min = 0 RPM) fan5: 0 RPM (min = 0 RPM) SYSTIN: +41.0°C (high = +0.0°C, hyst = +0.0°C) ALARM sensor = thermistor CPUTIN: +55.5°C (high = +80.0°C, hyst = +75.0°C) sensor = thermistor AUXTIN0: +98.0°C sensor = thermistor AUXTIN1: +96.0°C sensor = thermistor AUXTIN2: +96.0°C sensor = thermistor AUXTIN3: -8.0°C sensor = thermal diode PECI Agent 0: +64.5°C PCH_CHIP_CPU_MAX_TEMP: +0.0°C PCH_CHIP_TEMP: +0.0°C PCH_CPU_TEMP: +0.0°C intrusion0: ALARM intrusion1: ALARM beep_enable: disabled acpitz-acpi-0 Adapter: ACPI interface temp1: +27.8°C (crit = +106.0°C) temp2: +29.8°C (crit = +106.0°C) coretemp-isa-0000 Adapter: ISA adapter Package id 0: +72.0°C (high = +85.0°C, crit = +105.0°C) Core 0: +71.0°C (high = +85.0°C, crit = +105.0°C) Core 1: +72.0°C (high = +85.0°C, crit = +105.0°C) Core 2: +72.0°C (high = +85.0°C, crit = +105.0°C) Core 3: +69.0°C (high = +85.0°C, crit = +105.0°C) amdgpu-pci-0100 Adapter: PCI adapter vddgfx: 875.00 mV fan1: 847 RPM (min = 0 RPM, max = 2900 RPM) edge: +54.0°C (crit = +94.0°C, hyst = -273.1°C) PPT: 10.09 W (cap = 180.00 W)
En fait il faut aller dans "Processeurs" puis
"Cœur 1" -> "Cœur 1 Température actuelle (°C)"
Et faire de même pour les autres cœurs
gorfou :Je vois dans ta capture d'écran que tu fais une recherche dans "Senseurs matériels", ce n'est pas le bon endroit.
Oui, ça marche !
Merci beaucoup!
