Mageia8 problème avec pdfmod
Plantage au lancement de pdfmod
[robert@localhost ~]$ pdfmod
[1 Debug 12:23:17.535] Starting PdfMod 0.9.1
[1 Debug 12:23:17.550] Initializing i18n catalog from /usr/share/locale/
[1 Debug 12:23:17.573] Loaded custom AccelMap from /home/robert/.config/pdfmod/gtk_accel_map
[1 Debug 12:23:17.591] Cache directory set to /home/robert/.cache/pdfmod
[1 Debug 12:23:26.843] Loaded /home/robert/Documents/robot-tondeuse-husqvarna/20230907-entretien-tests/20230901-tests-0002.pdf
Exception in Gtk# callback delegate
Note: Applications can use GLib.ExceptionManager.UnhandledException to handle the exception.
System.NullReferenceException: Object reference not set to an instance of an object
at Gtk.Entry.TextInsertedSignalCallback (System.IntPtr arg0, System.IntPtr arg1, System.Int32 arg2, System.Int32& arg3, System.IntPtr gch) [0x00082] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at GLib.ExceptionManager.RaiseUnhandledException (System.Exception e, System.Boolean is_terminal) [0x00000] in <ed39f21b9e9343dcbd442a17ad356a9f>:0
at Gtk.Entry.TextInsertedSignalCallback (System.IntPtr arg0, System.IntPtr arg1, System.Int32 arg2, System.Int32& arg3, System.IntPtr gch) [0x00000] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at Gtk.Entry.gtk_entry_set_text (System.IntPtr , System.IntPtr ) [0x00000] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at Gtk.Entry.set_Text (System.String value) [0x00000] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at PdfMod.Gui.MetadataEditorBox+TextProperty.SetDefault (System.String default_value) [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at PdfMod.Gui.MetadataEditorBox.HandleDocumentLoaded (System.Object o, System.EventArgs e) [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at PdfMod.Core.Client.OnDocumentLoaded () [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at PdfMod.Gui.Client+<LoadPath>c__AnonStorey0.<>m__1 () [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at Hyena.ThreadAssist+<BlockingProxyToMain>c__AnonStorey1.<>m__0 () [0x00000] in <bea5f8dc246647e19ee46c3c4d128568>:0
at PdfMod.Gui.Client+<RunIdle>c__AnonStorey4.<>m__0 () [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at GLib.Idle+IdleProxy.Invoke (System.IntPtr data) [0x00000] in <ed39f21b9e9343dcbd442a17ad356a9f>:0
at GLib.SourceProxy.HandlerInternal (System.IntPtr data) [0x00000] in <ed39f21b9e9343dcbd442a17ad356a9f>:0
at Gtk.Application.gtk_main () [0x00000] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at Gtk.Application.Run () [0x00000] in <7aab76e87bce48a4b45cf7fa613cb70c>:0
at PdfMod.Gui.Client..ctor (System.Boolean loadFiles) [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
at PdfMod.PdfMod.Main (System.String[] args) [0x00000] in <e481263b622447bcbb576ff3358715dd>:0
Faut-il faire une déclaration de bug ?
A priori, oui.
As-tu testé avec d'autres fichiers ? L'avais-tu déjà ouvert avec une version antérieure ?
J'ai toujours dù, a chaque usage en faites, supprimer dans le cache et le config, avant d'utiliser pdfview, pdfmod,...
sinon, ils plantais systématiquement....
A priori, oui.
A priori, oui.
pour ta réponse Papoteur, que veux-tu dire par tester avec d'autres fichiers ?! mais j'avais ouvert pdfmod avec la version qui était installée qui était une version de Mga8. Quand je m'en suis aperçu, j'ai désinstallé la version Mga8 et installé la Mga9. Ensuite j'ai supprimé le fichier /home/user/.config/pdfmod mais ça n'a rien changé.steven :
également steven pour ta réponse. Comme je le dis au dessus à Papoteur, j'ai supprimé le fichier /home/user/.config/pdfmod mais que veux-tu dire par "supprimer dans le cache et le config" ?!!
à tous.Édité par zatox Le 11/09/2023 à 23h33
Je pense qu'il faut faire le rapport de bug.
Yuusha :
Ah ! je n'ai jamais fait ça mais je vais essayer ....
Sur la page du wiki "Comment signaler un bogue correctement" déjà je vois qu'il faut faire ça en anglais !! ce n'est pas le genre de chose faite pour m'arranger ... bon je vais voir.
Édité par zatox Le 12/09/2023 à 10h09
zatox :
Une traduction avec Deepl est suffisante pour que l'on comprenne le problème : https://www.deepl.com/translator.
Yuusha :
Oui ça je sais, étant très mauvais en anglais je connais par contre très bien le site deepl.com que je sollicite fréquemment, et pour cause ... .
je viens d'essayer de rentrer dans bugs-mageia avec mon identfiant/mot de passe MLO mais déjà il ne me connait pas.
Donc il va sans doute falloir dans un premier temps que je crée un compte ...
Yuusha :
Mageia et MLO sont deux entités entièrement distinctes. Il te faut un compte Mageia pour accéder au bugzilla.
Oui, ça y est, c'est fait, j'ai ouvert un bug dont le numéro est: 32278.
J'espère avoir fait ça dans les normes.
pour votre aide.
Je pense que pdfmod doit être viré des dépôts car il n'est plus du tout maintenu depuis 2011 environ. Il va être difficile de le faire fonctionner.
ASUS K73S (portable) :
.Venez nous rejoindre sur le salon IRC de MLOzatox Membre non connecté
david.david :
Ah bon ! perso je m'en servais souvent mais bon, j'essaierai de trouver une autre application équivalente.
david.david :
A quoi bon garder une application qui n'est plus maintenu depuis maintenant 12 ans et qui plus est ne fonctionne plus !
Euh !!!... que l'application ne soit plus maintenue depuis 12 ans ceci est possible mais qu'elle ne fonctionne plus !!! personnellement je l'ai toujours utilisée jusqu'à Mageia 8 et elle fonctionnait très bien. Ceci dit, j'utilisais principalement pdfmod soit pour concaténer plusieurs fichiers .pdf soit pour faire l'opération inverse c'est à dire extraire des pages d'un fichier .pdf.
Donc pour faire ces opérations là, la ligne de commande avec pdftk va très bien.
Donc je ne sais plus ce que je dois faire vu que j'ai ouvert un bug concernant pdfmod, est-ce que je dois l'annuler et si oui comment ?
Édité par zatox Le 13/09/2023 à 17h17
Édité par Papoteur Le 13/09/2023 à 18h30
