bumblebeed et bumblegum pas glop pas glop [Réglé]
lcb1 Membre non connecté
- Voir le profil du membre lcb1
[bruno@localhost ~]$ optirun glxinfo | grep OpenGL
[ 61.612647] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
[ 61.612670] [ERROR]Could not connect to bumblebee daemon - is it running?
Donc ...
[bruno@localhost ~]$ su root
Mot de passe :
[root@localhost bruno]# optirun glxinfo | grep OpenGL
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 540M/PCIe/SSE2
OpenGL core profile version string: 4.4.0 NVIDIA 346.96
OpenGL core profile shading language version string: 4.40 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5.0 NVIDIA 346.96
OpenGL shading language version string: 4.50 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
[root@localhost bruno]# optirun glxspheres64
Polygons in scene: 62464
Visual ID of window: 0xa7
Context is Direct
OpenGL Renderer: GeForce GT 540M/PCIe/SSE2
62.755706 frames/sec - 64.821624 Mpixels/sec
60.520567 frames/sec - 62.512904 Mpixels/sec
60.504896 frames/sec - 62.496717 Mpixels/sec
60.510963 frames/sec - 62.502984 Mpixels/sec
60.505454 frames/sec - 62.497293 Mpixels/sec
60.488259 frames/sec - 62.479533 Mpixels/sec
60.520259 frames/sec - 62.512586 Mpixels/sec
60.503443 frames/sec - 62.495217 Mpixels/sec
60.502871 frames/sec - 62.494625 Mpixels/sec
et ...
[root@localhost bruno]# optirun vlc
VLC is not supposed to be run as root. Sorry.
If you need to use real-time priorities and/or privileged TCP ports
you can use vlc-wrapper (make sure it is Set-UID root and
cannot be run by non-trusted users first).
[root@localhost bruno]# exit
exit
[bruno@localhost ~]$ optirun vlc
[ 224.709890] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
[ 224.709912] [ERROR]Could not connect to bumblebee daemon - is it running?
[root@localhost bruno]# systemctl status bumblebeed
● bumblebeed.service - Bumblebee C Daemon
Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled)
Active: active (running) since mer. 2016-02-24 19:25:34 CET; 23h left
Main PID: 913 (bumblebeed)
CGroup: /system.slice/bumblebeed.service
└─913 /usr/sbin/bumblebeed
févr. 23 19:26:10 localhost bumblebeed[913]: [ 74.697023] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:26:31 localhost bumblebeed[913]: [ 96.239739] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:26:31 localhost bumblebeed[913]: [ 96.239768] [WARN][XORG] (WW) NVIDIA(0): Unable to get display device for DPI computation.
févr. 23 19:26:31 localhost bumblebeed[913]: [ 96.239785] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:28:27 localhost bumblebeed[913]: [ 211.903834] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:28:27 localhost bumblebeed[913]: [ 211.903864] [WARN][XORG] (WW) NVIDIA(0): Unable to get display device for DPI computation.
févr. 23 19:28:27 localhost bumblebeed[913]: [ 211.903884] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:30:01 localhost bumblebeed[913]: [ 306.114937] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
févr. 23 19:30:01 localhost bumblebeed[913]: [ 306.114962] [WARN][XORG] (WW) NVIDIA(0): Unable to get display device for DPI computation.
févr. 23 19:30:01 localhost bumblebeed[913]: [ 306.114977] [ERROR][XORG] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
Donc ...
Mot de passe :
OpenGL extensions:
Context is Direct
et ...
exit
Donc ça tourne en rond ... Par contre j'ai eu droit à une jolie fleur 3D qui tournait
si vous avez une idée, merci.
Bruno
Édité par lcb1 Le 23/02/2016 à 19h40
Mageia 9
Plasma : 5.27.10-1.mga9
noyau : 6.6.83-1.mga9
Asus Geforce GTX 750 ti Sur SSD
& Asus N73S laptop
& Asus N73S laptop
Aranud Membre non connecté
As-tu suivis le tuto car je n'ai jamais eu de soucis :
http://www.mageialinux-online.org/wiki/installer-bumblebee-pour-les-cartes-optimus
En installant via urpmi au moins il est préciser qu'il faut ajouter user dnas le groupe bumblebeed, c'était le problème de droits. Bon, après la fleur qui tourne, je ne vois guère de différence avec les deux options
C'est ce qu'ils disent ici : You might be surprised to find that your Intel chipset gives a better framerate than the NVIDIA GPU with the glxspheres64 test. This is normal and likely due to the fact that the test is not really demanding hardware-wise, and the Intel chipset has direct access to your monitor, contrarily to the NVIDIA GPU with has to go through a bridge to access the monitor.
Pour moi l'intérêt de tout ça c'est d'avoir déjà une CG qui tourne, au cas ou l'Intel ne fonctionne plus, mais je suis probablement optimiste puisque si je comprends bien nvidia ne tournera jamais par défaut. Et donc on comprend mieux...
Ciao
Mageia 9
& Asus N73S laptop
& Asus N73S laptop
Akien Membre non connecté
Ce que dit le wiki c'est que pour le test "glxspheres64", qui est à peu près aussi gourmand que faire tourner Tetris, utiliser la carte nvidia ne donne pas de meilleure performance. Par contre lance SuperTuxKart avec les graphismes au maximum avec ou sans nvidia, là tu verras la différence
Mageia 9
& Asus N73S laptop
& Asus N73S laptop
