Pour info : Steam et le pilote libre radeon
En standard, jouer avec le pilote radeon ne fonctionne pas. On obtient un message d'erreur du type :
[vouf@localhost ~]$ steam Running Steam on mageia 5 64-bit STEAM_RUNTIME is enabled automatically Installing breakpad exception handler for appid(steam)/version(1439401440) libGL error: unable to load driver: radeonsi_dri.so libGL error: driver pointer missing libGL error: failed to load driver: radeonsi libGL error: unable to load driver: swrast_dri.so libGL error: failed to load driver: swrast Installing breakpad exception handler for appid(steam)/version(1439401440) (steam:9742): Gtk-WARNING **: Impossible de trouver le moteur de thème dans module_path : « oxygen-gtk » (steam:9742): Gtk-WARNING **: Impossible de trouver le moteur de thème dans module_path : « oxygen-gtk » Installing breakpad exception handler for appid(steam)/version(1439401440) Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number libGL error: unable to load driver: radeonsi_dri.so libGL error: driver pointer missing libGL error: failed to load driver: radeonsi libGL error: unable to load driver: swrast_dri.so libGL error: failed to load driver: swrast [0816/145232:ERROR:browser_main_loop.cc(173)] Running without the SUID sandbox! See https://code.google.com/p/chromium/wiki/LinuxSUIDSandboxDevelopment for more information on developing with the sandbox on. Error: OpenGL GLX context is not using direct rendering, which may cause performance problems.
Pour contourner le problème, il faut exécuter les commandes suivantes :
find ~/.steam/root/ ( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" ) -print -delete find ~/.local/share/Steam/ ( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" ) -print -delete
Il y a en effet des conflits entre les librairies apportées par le package steam et celles de mageia, ce qui empêche la bonne détection de la 3D.
NB: Le wiki a été mis à jour.
Eh bien, sous Mageia 6 dev 1, le driver libre radeon offre de très très bonnes performances avec steam et les jeux Valve. Bref, le driver propriétaire est désormais inutile pour jouer à CS:GO !!
C'est rigolo car avec nouveau on nous dit qu'on n'a pas d'accélération matérielle
Sous mageia 6, la commande évolue. Il faut désormais également supprimer les librairies "libgpg-error.so*"
Nouvelles commandes :
find ~/.steam/root/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "libxcb.so*" -o -name "libgpg-error.so*" \) -print -delete
Je mets à jour le tuto en conséquence.
