Problème de démarrage kalarm
MG4-KDE
Tromb Membre non connecté
- Voir le profil du membre Tromb
Je n'arrive pas à démarrer kalarm.
Le rapport des tests réalisés après tentative de démarrage comprend les erreurs suivantes (les tests "success" ne sont pas cités) :
Code RAPPORT :
Akonadi Server Self-Test Report
Test 5: ERROR
MySQL server log contains errors.
Details: The MySQL server error log file '<a href='/home/admin/.local/share/akonadi/db_data/mysql.err'>/home/admin/.local/share
/akonadi/db_data/mysql.err</a>' contains errors.
File content of '/home/admin/.local/share/akonadi/db_data/mysql.err':
141116 12:12:32 InnoDB: The InnoDB memory heap is disabled
141116 12:12:32 InnoDB: Mutexes and rw_locks use GCC atomic builtins
141116 12:12:32 InnoDB: Compressed tables use zlib 1.2.8
141116 12:12:32 InnoDB: Using Linux native AIO
141116 12:12:32 InnoDB: Initializing buffer pool, size = 80.0M
141116 12:12:32 InnoDB: Completed initialization of buffer pool
InnoDB: Error: auto-extending data file ./ibdata1 is of a different size
InnoDB: 128 pages (rounded down to MB) than specified in the .cnf file:
InnoDB: initial 640 pages, max 0 (relevant if non-zero) pages!
141116 12:12:32 InnoDB: Could not open or create data files.
141116 12:12:32 InnoDB: If you tried to add new data files, and it failed here,
141116 12:12:32 InnoDB: you should now edit innodb_data_file_path in my.cnf back
141116 12:12:32 InnoDB: to what it was, and remove the new ibdata files InnoDB created
141116 12:12:32 InnoDB: in this failed attempt. InnoDB only wrote those files full of
141116 12:12:32 InnoDB: zeros, but did not yet use them in any way. But be careful: do not
141116 12:12:32 InnoDB: remove old data files which contain your precious data!
141116 12:12:32 [ERROR] Plugin 'InnoDB' init function returned error.
141116 12:12:32 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
141116 12:12:32 [ERROR] Unknown/unsupported storage engine: innodb
141116 12:12:32 [ERROR] Aborting
141116 12:12:32 [Note] /usr/sbin/mysqld: Shutdown complete
Test 7: SKIP
MySQL server custom configuration not available.
Details: The custom configuration for the MySQL server was not found but is optional.
Test 10: ERROR
Akonadi control process not registered at D-Bus.
Details: The Akonadi control process is not registered at D-Bus which typically means it was not started or encountered a fatal
error during startup.
Test 11: ERROR
Akonadi server process not registered at D-Bus.
Details: The Akonadi server process is not registered at D-Bus which typically means it was not started or encountered a fatal
Test 14: SKIP
Protocol version check not possible.
Details: Without a connection to the server it is not possible to check if the protocol version meets the requirements.
Test 15: ERROR
No resource agents found.
Details: No resource agents have been found, Akonadi is not usable without at least one. This usually means that no resource agents
are installed or that there is a setup problem. The following paths have been searched: '/usr/share/akonadi/agents'.
The XDG_DATA_DIRS environment variable is set to '/usr/share:/usr/share:/usr/local/share'; make sure this includes all paths
where Akonadi agents are installed.
Directory listing of '/usr/share/akonadi/agents':
akonadinepomukfeederagent.desktop
akonotesresource.desktop
archivemailagent.desktop
birthdaysresource.desktop
contactsresource.desktop
davgroupwareresource.desktop
facebookresource.desktop
folderarchiveagent.desktop
googlecalendarresource.desktop
googlecontactsresource.desktop
icaldirresource.desktop
icalresource.desktop
imapresource.desktop
invitationsagent.desktop
kabcresource.desktop
kalarmdirresource.desktop
kalarmresource.desktop
kcalresource.desktop
kdeaccountsresource.desktop
knutresource.desktop
kolabproxyresource.desktop
localbookmarksresource.desktop
maildirresource.desktop
maildispatcheragent.desktop
mailfilteragent.desktop
mboxresource.desktop
microblog.desktop
migrationagent.desktop
mixedmaildirresource.desktop
mtdummyresource.desktop
nepomuktagresource.desktop
newmailnotifieragent.desktop
nntpresource.desktop
openxchangeresource.desktop
pop3resource.desktop
sendlateragent.desktop
skroogeakonadiresource.desktop
vcarddirresource.desktop
vcardresource.desktop
Environment variable XDG_DATA_DIRS is set to '/usr/share:/usr/share:/usr/local/share'
Test 16: ERROR
Current Akonadi server error log found.
Details: The Akonadi server reported errors during its current startup. The log can be found in <a href='/home/admin/.local/share/
akonadi/akonadiserver.error'>/home/admin/.local/share/akonadi/akonadiserver.error</a>.
File content of '/home/admin/.local/share/akonadi/akonadiserver.error':
Database process exited unexpectedly during initial connection!
executable: "/usr/sbin/mysqld"
arguments: ("--defaults-file=/home/admin/.local/share/akonadi/mysql.conf", "--datadir=/home/admin/.local/share/akonadi/db_data/
", "--socket=/tmp/akonadi-admin.wNU929/mysql.socket")
stdout: ""
stderr: ""
exit code: 1
process error: "Unknown error"
0: akonadiserver(_Z11akBacktracev+0x35) [0x8090f15]
1: akonadiserver() [0x80911a1]
2: linux-gate.so.1(__kernel_sigreturn+0) [0xb7785400]
3: linux-gate.so.1(__kernel_vsyscall+0x10) [0xb7785424]
4: /lib/i686/libc.so.6(gsignal+0x46) [0xb6e055e6]
5: /lib/i686/libc.so.6(abort+0x143) [0xb6e06f23]
6: /lib/libQtCore.so.4(_Z17qt_message_output9QtMsgTypePKc+0x7d) [0xb74dddcd]
7: akonadiserver(_ZN15FileDebugStream9writeDataEPKcx+0xc4) [0x8093024]
8: /lib/libQtCore.so.4(_ZN9QIODevice5writeEPKcx+0xc8) [0xb75831c8]
9: /lib/libQtCore.so.4(+0x11168e) [0xb759368e]
10: /lib/libQtCore.so.4(_ZN11QTextStreamD1Ev+0x35) [0xb759cd75]
11: akonadiserver(_ZN6QDebugD1Ev+0x3a) [0x808b2ea]
12: akonadiserver(_ZN13DbConfigMysql19startInternalServerEv+0x1f5a) [0x810b7ba]
13: akonadiserver(_ZN7Akonadi13AkonadiServer20startDatabaseProcessEv+0xe9) [0x8093b09]
14: akonadiserver(_ZN7Akonadi13AkonadiServer4initEv+0xa2) [0x80956c2]
15: /lib/libQtCore.so.4(_ZN14QMetaCallEvent13placeMetaCallEP7QObject+0x3a) [0xb760cf8a]
16: /lib/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x20b) [0xb7614e5b]
17: /lib/libQtCore.so.4(_ZN23QCoreApplicationPrivate13notify_helperEP7QObjectP6QEvent+0x60) [0xb75fbdc0]
18: /lib/libQtCore.so.4(_ZN16QCoreApplication6notifyEP7QObjectP6QEvent+0x54) [0xb75fbe24]
19: /lib/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x7a) [0xb75fbbca]
20: /lib/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x1d5) [0xb75fed55]
21: /lib/libQtCore.so.4(_ZN16QCoreApplication16sendPostedEventsEP7QObjecti+0x2c) [0xb75ff27c]
22: /lib/libQtCore.so.4(+0x1a996e) [0xb762b96e]
23: /lib/libglib-2.0.so.0(g_main_context_dispatch+0x13e) [0xb6cdf6ee]
24: /lib/libglib-2.0.so.0(+0x46a98) [0xb6cdfa98]
25: /lib/libglib-2.0.so.0(g_main_context_iteration+0x38) [0xb6cdfb58]
26: /lib/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x5f) [0xb762b14f]
27: /lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x43) [0xb75fa583]
28: /lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x179) [0xb75fa8a9]
29: /lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x8e) [0xb76001ce]
30: akonadiserver(main+0x1e9) [0x808a919]
31: /lib/i686/libc.so.6(__libc_start_main+0xf3) [0xb6df1b33]
32: akonadiserver() [0x808b0b2]
Test 17: ERROR
Previous Akonadi server error log found.
Details: The Akonadi server reported errors during its previous startup. The log can be found in <a href='/home/admin/.local/share/akonadi
/akonadiserver.error.old'>/home/admin/.local/share/akonadi/akonadiserver.error.old</a>.
File content of '/home/admin/.local/share/akonadi/akonadiserver.error.old':
stdout: ""
stderr: ""
exit code: 1
2: linux-gate.so.1(__kernel_sigreturn+0) [0xb772c400]
3: linux-gate.so.1(__kernel_vsyscall+0x10) [0xb772c424]
4: /lib/i686/libc.so.6(gsignal+0x46) [0xb6dac5e6]
5: /lib/i686/libc.so.6(abort+0x143) [0xb6dadf23]
6: /lib/libQtCore.so.4(_Z17qt_message_output9QtMsgTypePKc+0x7d) [0xb7484dcd]
8: /lib/libQtCore.so.4(_ZN9QIODevice5writeEPKcx+0xc8) [0xb752a1c8]
9: /lib/libQtCore.so.4(+0x11168e) [0xb753a68e]
10: /lib/libQtCore.so.4(_ZN11QTextStreamD1Ev+0x35) [0xb7543d75]
15: /lib/libQtCore.so.4(_ZN14QMetaCallEvent13placeMetaCallEP7QObject+0x3a) [0xb75b3f8a]
16: /lib/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x20b) [0xb75bbe5b]
17: /lib/libQtCore.so.4(_ZN23QCoreApplicationPrivate13notify_helperEP7QObjectP6QEvent+0x60) [0xb75a2dc0]
18: /lib/libQtCore.so.4(_ZN16QCoreApplication6notifyEP7QObjectP6QEvent+0x54) [0xb75a2e24]
19: /lib/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x7a) [0xb75a2bca]
20: /lib/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x1d5) [0xb75a5d55]
21: /lib/libQtCore.so.4(_ZN16QCoreApplication16sendPostedEventsEP7QObjecti+0x2c) [0xb75a627c]
22: /lib/libQtCore.so.4(+0x1a996e) [0xb75d296e]
23: /lib/libglib-2.0.so.0(g_main_context_dispatch+0x13e) [0xb6c866ee]
24: /lib/libglib-2.0.so.0(+0x46a98) [0xb6c86a98]
25: /lib/libglib-2.0.so.0(g_main_context_iteration+0x38) [0xb6c86b58]
26: /lib/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x5f) [0xb75d214f]
27: /lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x43) [0xb75a1583]
28: /lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x179) [0xb75a18a9]
29: /lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x8e) [0xb75a71ce]
31: /lib/i686/libc.so.6(__libc_start_main+0xf3) [0xb6d98b33]
Après quelques tentatives de démarrage, j'ai installé tout ce que CCM me présentait lié à akonadi, mais cela ne change rien.
Que puis-je faire ?
***Attention, je suis un novice***
D'avance merci,
Édité par Tromb Le 16/11/2014 à 14h49
Tromb
supernovice
supernovice
Pour information complémentaire :
kalarm marche dans une des deux sessions user ?!
Tromb
supernovice
supernovice
Prends dolphin /home/tromb/ Tu fais un Alt+. ( alt + point) pour afficher les fichiers cachés
Dans .kde4/share.config/ supprime kalarmrc.
Et si tu vois des akonadi.... tu peux les supprimer aussi.
Ces fichiers se régénéreront automatiquement.
Avant de quitter dolphin, refais un alt+. pour cacher les fichiers à cacher.
Je viens de faire la manip et, effectivement, kalarm se reconfigure... mais le résultat final est exactement le même.
Cela peut-il être lié au fait que le user chez qui kalarm fonctionne est celui qui a été créé à l'installation et que le deuxième user chez qui kalarm ne fonctionne pas a été créé via le CCM ?
Tromb
supernovice
supernovice
