Amarok ne se lance pas
loutch Membre non connecté
lors d'un lancement en konsole j'ai ceci et amrok ne se lance pas :
[romuald@localhost ~]$ amarok
Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QDBusObjectPath)
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)
QWidget::insertAction: Attempt to insert null action
QWidget::setMinimumSize: (Media Sources dock/BrowserDock) Negative sizes (200,-1) are not possible
QWidget::setMinimumSize: (Playlist dock/Playlist::Dock) Negative sizes (0,-1) are not possible
X Error: BadMatch (invalid parameter attributes) 8
Major opcode: 7 (X_ReparentWindow)
Resource id: 0x4400121
X Error: RenderBadPicture (invalid Picture parameter) 143
Extension: 140 (RENDER)
Minor opcode: 7 (RenderFreePicture)
Resource id: 0x90
X Error: BadWindow (invalid Window parameter) 3
Major opcode: 10 (X_UnmapWindow)
Resource id: 0x4400094
Major opcode: 20 (X_GetProperty)
Major opcode: 4 (X_DestroyWindow)
Resource id: 0x4400096
Resource id: 0x4400098
Resource id: 0x440009b
Major opcode: 12 (X_ConfigureWindow)
Could not parse stylesheet of widget 0x23718b0
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Extension: 153 (Uknown extension)
Minor opcode: 3 (Unknown request)
Minor opcode: 12 (Unknown request)
Minor opcode: 7 (Unknown request)
Major opcode: 8 (X_MapWindow)
QWidget::setMinimumSize: (Playlist dock/Playlist::Dock) Negative sizes (200,-1) are not possible
KCrash: Application 'amarok' crashing...
KCrash: Attempting to start /usr/lib64/kde4/libexec/drkonqi from kdeinit
sock_file=/home/romuald/.kde4/socket-localhost.localdomain/kdeinit4__0
unnamed app(18586): Communication problem with "amarok" , it probably crashed.
Error message was: "org.freedesktop.DBus.Error.NoReply" : " "Message did not receive a reply (timeout by message bus)" "
Resource id: 0x90
Une idée ?
à+
Essaye ceci :
puis relance amarok
mv ~/.kde4/share/apps/amarok ~/.kde4/share/apps/amarok.old
marche pas même erreur
Sur ma Cauldron issue de la beta1 Amarok fonctionne.
Christian
création d'un nouvel utilisateur et amarok se lance bien ,konsole me donne ceci
[romu@localhost ~]$ amarok
Could not parse stylesheet of widget 0x3910000
** AMAROK WAS STARTED IN NORMAL MODE. IF YOU WANT TO SEE DEBUGGING INFORMATION, PLEASE USE: **
** amarok --debug **
[romu@localhost ~]$ Calling appendChild() on a null node does nothing.
"source protocole http"
Édité par Ami age Le 29/11/2013 à 18h47
Par contre, dans les sources internet, avec Jamendo, dans l'arborescence, je choisi, un genre, un artiste, un album, une piste, mais la musique ne part pas. Pas de message d'erreur.
Ya du mieux. ya peut-être eu des corrections dans les mises à jours récentes ?
