Problème avec NFS
Blocage au démarrage
chalandp Membre non connecté
- Voir le profil du membre chalandp
"J'ai chargé Mageia3 avec le DVD 32 bits.
Lors du boot sur mon portable tout est parfait.
Lors du boot sur mon PC j'ai les erreurs suivantes:
[root@sonypierre ~]# systemctl status ct_sync.service
ct_sync.service - LSB: Connection tracking state replication
Loaded: loaded (/etc/rc.d/init.d/ct_sync)
Active: failed (Result: exit-code) since Tue, 2013-05-21 13:42:28 CEST; 2h 39min ago
Process: 1568 ExecStart=/etc/rc.d/init.d/ct_sync start (code=exited, status=1/FAILURE)
CGroup: name=systemd:/system/ct_sync.service
May 21 13:42:28 sonypierre ct_sync[1568]: [33B blob data]
May 21 13:42:28 sonypierre systemd[1]: Failed to start LSB: Connection tracking stat...on.
May 21 13:42:28 sonypierre systemd[1]: Unit ct_sync.service entered failed state
[root@sonypierre ~]# systemctl status shorewall6.service
shorewall6.service - Shorewall IPv6 firewall
Loaded: loaded (/usr/lib/systemd/system/shorewall6.service; enabled)
Active: failed (Result: exit-code) since Tue, 2013-05-21 13:42:29 CEST; 2h 39min ago
Process: 1625 ExecStart=/usr/sbin/shorewall6 $OPTIONS start (code=exited, status=3)
CGroup: name=systemd:/system/shorewall6.service
May 21 13:42:28 sonypierre shorewall6[1625]: Compiling...
May 21 13:42:28 sonypierre shorewall6[1625]: Processing /etc/shorewall6/params ...
May 21 13:42:28 sonypierre shorewall6[1625]: Processing /etc/shorewall6/shorewall6.conf...
May 21 13:42:28 sonypierre shorewall6[1625]: Loading Modules...
May 21 13:42:29 sonypierre shorewall6[1625]: ERROR: Your kernel/iptables do not inclu...em
May 21 13:42:29 sonypierre systemd[1]: shorewall6.service: main process exited, code...TED
May 21 13:42:29 sonypierre systemd[1]: Failed to start Shorewall IPv6 firewall.
May 21 13:42:29 sonypierre systemd[1]: Unit shorewall6.service entered failed state
Ensuite le chargement se bloque 1 à 2 minutes sur Started LSB:ProFTPD FTP server."
Si j'enlève le mount sur fstab tout revient en ordre et je reboote en 55 secondes.
Je ne peux utiliser NFS quelqu'un pourrait-il m'aider?
pc
xuo Membre non connecté
Est-ce que le service nfs-serveur est bien démarré côté serveur et que tous les services nfs le sont bien aussi côté client ?
MCC => Système => Gérer les services système ...
Le montage après le redémarrage se fait-il correctement à la main ?
mount -t nfs 192.168.1.114:/home/solange /mnt/solange
Xuo.
Le montage ne s'effectue pas à la main.
Bonsoir et merci
pc
Et côté pare-feu ? Pour déboguer, il faut peut-être le désinstaller pour être sûr que ce n'est pas lui qui pose le problème.
Xuo.
pc
Je ne comprends pas.
Avec le pare-feu, tout se passe bien.
Sans le pare-feu, le montage ne se fait pas.
C'est cela qui se passe ?
Xuo.
pc
Il y a un message d'erreur lors du montage à la main ?
Le serveur exporte bien la partition à monter ?
Les 2 pcs (portable et fixe) sont tous les 2 sous Mageia 3 ?
Xuo.
J'ai fait un ping dans les deux sens et il n'y a pas de communication.
Le portable est en wifi sur un routeur adresse 192.168.1.1.(adresse fixe 192.168.1.114)
Le fixe est sur etho à travers le même routeur.(adresse fixe 192.168.1.154)
Que faut-il faire pour que les deux ordinateurs communiquent?
pc
paiiou Membre non connecté
Je viens de faire des essais avec NFS et mga3.
Également impossible de trouver le serveur.
J'ai essayé en configurant le pare-feu du serveur (Mageia3), en cochant le service NFS.
=> # showmount -e 192.168.0.6 ne trouve rien
Autre essai avec pare-feu du serveur désactivé => idem
J'ai alors remarqué que la configuration du pare-feu du serveur n'est pas enregistée.
Le ping n'aboutit pas non plus : ping 192.168.0.6 => 0 received
Je soupçonne un problème de configuration du pare-feu avec Mga3
http://www.mageialinux-online.org/forum/topic-15294+impossible-de-desactiver-le-firewall.php
à essayer
Édit :
en supprimant le paquetage,
puis en désactivant le pare-feu, qui me demande d'installer le paquetage
je valide
=> le ping fonctionne
=> shwomount -e trouve le répertoire exporté
Mais alors il n'y a plus de pare-feu
Édité par paiiou Le 27/05/2013 à 20h43
- il est possible de trouver le serveur et le répertoire exporté,
- il est possible de définir un point de montage
- il est possible de monter le répertoire distant
Il faut donc suivre l'évolution de la bogue 9723
[root@sonypierre ~]# mount -t nfs 192.168.1.114:/home/solange /mnt/solange
mount.nfs: requested NFS version or transport protocol is not supported.
Les NFS sont activés
pc
Et en supprimant carrément le pare-feu ?
Xuo.
Par contre sur l'ordinateur fixe en etho le mount ne se réalise toujours pas. J'ai adopté la même procédure que pour le portable.
pc
