Toujours un problème de connexion wifi [Réglé]
Problème connexion wifi suite à mise à jour
jeanjo Membre non connecté
- Voir le profil du membre jeanjo
J'ai un soucis depuis une mise à jours dans le courant du mois d'aout.
Depuis je ne peux plus me connecté alors que je vois trés bien tous les réseaux.
Voici le message que je reçois dans /var/log/syslog quand je lance un connexion wifi
Sep 13 12:30:44 localhost draknetcenter[11172]: modified file /etc/sysconfig/network-scripts/ifcfg-wlan0 Sep 13 12:30:44 localhost draknetcenter[11172]: modified file /etc/sysconfig/network-scripts/ifcfg-wlan0 Sep 13 12:30:44 localhost draknetcenter[11172]: changed mode of /etc/sysconfig/network-scripts/ifcfg-wlan0 to 700 Sep 13 12:30:44 localhost draknetcenter[11172]: written wlan0 interface configuration in /etc/sysconfig/network-scripts/ifcfg-wlan0 Sep 13 12:30:44 localhost draknetcenter[11172]: created file /etc/wpa_supplicant.conf Sep 13 12:30:44 localhost draknetcenter[11172]: running: /usr/sbin/wpa_cli reconfigure Sep 13 12:30:44 localhost draknetcenter[11172]: running: /sbin/ifdown wlan0 daemon Sep 13 12:30:44 localhost draknetcenter[11172]: running: /sbin/ifup wlan0 daemon Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: parsing /etc/sysconfig/network-scripts/ifcfg-wlan0 ... Sep 13 12:30:45 localhost NetworkManager[2140]: <warn> failed to allocate link cache: (-10) Operation not supported Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: error: Missing SSID Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: removed /etc/sysconfig/network-scripts/ifcfg-wlan0. Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: parsing /etc/sysconfig/network-scripts/ifcfg-wlan0 ... Sep 13 12:30:45 localhost NetworkManager[2140]: <warn> failed to allocate link cache: (-10) Operation not supported Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: error: Missing SSID Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: parsing /etc/sysconfig/network-scripts/ifcfg-wlan0 ... Sep 13 12:30:45 localhost NetworkManager[2140]: <warn> failed to allocate link cache: (-10) Operation not supported Sep 13 12:30:45 localhost NetworkManager[2140]: ifcfg-rh: error: Missing SSID
Il est aussi possible que j'ai le problème avec les 2 application de gestion de réseaux net_applet et networkmanager ???
J'avoue ne pas trop savoir quoi faire pour que ma connexion wifi refonctionne.
Driver de la carte réseau : iwl4965.
Je rappelle qu'avant la mauvaise mise à jour mon réseau wifi était fonctionnelle.
Mais celui-ci est à priori bien renseigné, voici ce que j'ai dans : /etc/sysconfig/network-scripts/ifcfg-wlan0
DEVICE=wlan0 BOOTPROTO=dhcp ONBOOT=yes METRIC=35 MII_NOT_SUPPORTED=no USERCTL=yes RESOLV_MODS=no WIRELESS_MODE=Managed WIRELESS_ESSID=wlanjjt WIRELESS_ENC_KEY=XXXXXXXXXXXXXX WIRELESS_ENC_MODE=open WIRELESS_WPA_DRIVER=wext WIRELESS_WPA_REASSOCIATE=no IPV6INIT=no IPV6TO4INIT=no ACCOUNTING=yes NM_CONTROLLED=yes DHCP_CLIENT=dhclient NEEDHOSTNAME=no PEERDNS=yes PEERYP=yes PEERNTPD=no
C'est pourquoi je pense sur le problème connu que je ne sais pas résoudre entre le net_appet et la networkmanager ... qui visiblement rentrerait en conflit ...
Pour essais peut être as tu aussi des hotspots: free_wifi ou sfr_wifi_public . Si oui essaie de te connecter dessus.
Pour ce qui concerne les autres connexion comme free_wifi ou autres aucune ne marche.
Je suis persuader que cela correspond à la problématique de net_applet et networmanager.
Mais je ne sais pas comment résoudre le problème : qu'elles sont les packages à supprimer pour ne pas avoir de conflits entre les 2 applications ?
Yopman Membre non connecté
Tu vas dans le ccm et tu vas supprimer le paquet NetworkManager
Ensuite cela devrait le faire
Tiens nous au courant
Comme tu m'as dit j'ai supprimé le package networkmanager et il m'a ajouter knetworkmanager.
Depuis tout est ok.
Peut-être serait-il utile (je ne sais pas si cela est possible) de vérifier les dépendances du package pour ne pas se retrouver dans ma situation lors d'une mise à jour ?
Merci pour votre aide.
Édité par thierryR Le 14/09/2012 à 13h51
