Utiliser Mageia
Conky-conkyrc-scripts-partie 3
Dernière mise à jour : 20/01/2018 à 10h00
Position du soleil et de la lune
conkyrc
background no
use_xft yes
xftalpha 1
update_interval 1
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
double_buffer yes
minimum_size 380 310
maximum_width 380
text_buffer_size 2048
draw_shades no
draw_outline no
draw_borders no
border_width 1
draw_graph_borders no
default_outline_color cacaca
alignment top_right
gap_x 5
gap_y 100
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
color1                ffff00
lua_load ~/.conky/v11/conky/soleil.lua
lua_draw_hook_pre draw_fig
default_color 8b8b8b
lua_load ~/.conky/lua/image.lua
TEXT
${lua fDrawImage /home/loutch/.conky/v11/conky/terre.png 170 170 60 64 0}
soleil.lua
--sun position lua script by mrpeachy 2010 version 2 includes moon position
--input latitude
--for northern hemisphere enter positive
--for southern hemisphere enter negative
latitude=-49.1
longitude=7.06
--input hemisphere
--for northern enter 1
--for southern enter 2
hemisphere=2
--daylight saving? 1=yes, 0=no
dst=0
--position - this is the point where the N-S line crosses the horizon line
--the .5 helps make lines look sharper
across=200.5
down=200.5
require 'cairo'
function cos(x)
a=math.cos(math.rad(x))
return a
end
function sin(x)
a=math.sin(math.rad(x))
return a
end
function tan(x)
a=math.tan(math.rad(x))
return a
end
function addzero10(num)
if tonumber(num) < 10 then
return "0" .. num
else
return num
end
end
function round(val, decimal)
  if (decimal) then
    return math.floor( (val * 10^decimal) + 0.5) / (10^decimal)
  else
    return math.floor(val+0.5)
  end
end
local result = { }
local from  = 1
local delim_from, delim_to = string.find( self, delimiter, from  )
while delim_from do
from  = delim_to + 1
end
table.insert( result, string.sub( self, from  ) )
return result
end
function datan2(y, x)
    if x == 0 and y == 0 then
        return 0
        else a = math.atan(math.rad(y / x))
    end
    if (x < 0) then
    a = a + 180
        else if y < 0 and x > 0 then
        a = a + 360
        end
    end
return math.rad(a)
end
function ipart(x)
if (x> 0) then
a = math.floor(x)
else a = math.ceil(x);
end
return a
end
function range(x)
    b = x / 360;
    a = 360 * (b - ipart(b));
    if a  < 0 then
        a = a + 360
end
    return a
end
function ranget(x)
    b = x / 24;
    a = 24 * (b - ipart(b));
    if a  < 0 then
        a = a + 24
end
    return a
end
function rangei(x)
    b = x / 1440;
    a = 1440 * (b - ipart(b));
    if a  < 0 then
        a = a + 1440
end
    return a
end
--###########   MAIN FUNCTION   ########################################################################################################
function conky_draw_fig()
cr = cairo_create(cs)
--###########   START FUNCTION   ########################################################################################################
if updates > 5 then
--###########   SET HEMISPHERE   ########################################################################################################
if hemisphere==1 then
start=0
else
start=180
end
--################ sets daylignt saving #####################################3
if dst==1 then ds=-1 else ds=0 end
--###########  calculate julian time   ########################################################################################################
M=os.date("%m") --month
K=os.date("%G") --4 digit year
I=(os.date("%d"))--day of month
H=ranget((os.date("%H"))+ds) --hours
Min=os.date("%M")
Mi=(os.date("%M"))/60 --minutes expressed as hours
--current Julian time-----------------------------------------------------------------
JD=round((367*K)-((7*(K+((M+9)/12)))/4)+((275*M)/9)+I+1721013.5,0)+0.5+((H+Mi)/24)
days=(JD)-2451545.0 --correct
T=days/36525 --correct
--Julian time at preceeding midnight
JD0=round((367*K)-((7*(K+((M+9)/12)))/4)+((275*M)/9)+I+1721013.5,0)+0.5
D0=JD0-2451545.0
--###########  calculate sidereal time   ########################################################################################################
--current sidereal time
CST=6.697374558+(0.06570982441908*D0)+(1.00273790935*(H+Mi))
GMST = 6.697374558 + (0.06570982441908*D0) + (1.00273790935*(H+Mi)) + (0.000026*(T^2))
ADJ=longitude/15
GMST24=ranget(GMST)
GMST24S=string.split(GMST24, "%p")
GMST24H=GMST24S[1]
GMST24M=string.len(GMST24S[2])
GMST24M=GMST24S[2]/(10^(GMST24M))*60
GMST24M=string.split(GMST24M,"%p")
GMST24M=GMST24M[1]
sgtime=(GMST24H*60)+GMST24M
day=os.date("%j")
B=(360/365)*(day-81)
eot=(9.87*math.sin(2*B))-(7.53*math.cos(B))-(1.5*math.sin(B))
LSTM=15*10
TC=(4*(LSTM-longitude))+eot
LT=((H)*60)+Min
LST=LT+(TC/60)
LST24=ranget(LST/60)
LST24S=string.split(LST24, "%p")
LST24H=LST24S[1]
LST24M=string.len(LST24S[2])
LST24M=(LST24S[2]/(10^(LST24M)))*60
LST24M=string.split(LST24M,"%p")
LST24M=LST24M[1]
--below is current solar time
stime=(LST24H*60)+LST24M
--#############  END TIME CALCS ###########################################################################################################
--#############  SUN CACULATIONS AND DISPLAY ###########################################################################################################
--    Sun formulas
--    L1    - Mean longitude
--    M1    - Mean anomaly
--    C1    - Equation of centre
--    V1    - True anomaly
--    Ec1    - Eccentricity
--    R1    - Sun distance
--    Th1    - Theta (true longitude)
--    Om1    - Long Asc Node (Omega)
--    Lam1- Lambda (apparent longitude)
--    Obl    - Obliquity of ecliptic
--    Ra1    - Right Ascension
--    Dec1- Declination
t=T
L1 = range(280.466 + 36000.8 * t)
M1 = range(357.529+35999*t - 0.0001536* t*t + t*t*t/24490000)
sinm1=math.sin(math.rad(M1))
C1 = (1.915 - 0.004817* t - 0.000014* t * t)* sinm1;
C1 = C1 + (0.01999 - 0.000101 * t)* sinm1;
C1 = C1 + 0.00029 * sinm1;
V1 = M1 + C1;
cosv1=math.cos(math.rad(V1))
Ec1 = 0.01671 - 0.00004204 * t - 0.0000001236 * t*t;
R1 = 0.99972 / (1 + Ec1 * cosv1);--correct
Th1 = L1 + C1
Om1 = range(125.04 - 1934.1 * t)
om1sin=math.sin(math.rad(Om1))
Lam1 = Th1 - 0.00569 - 0.00478 * math.deg(om1sin);
Obl = (84381.448 - 46.815 * t)/3600; --correct
th1sin=math.sin(math.rad(Th1))
th1cos=math.cos(math.rad(Th1))
th1tan=math.tan(math.rad(Th1))
oblsin=math.sin(math.rad(Obl))
oblcos=math.cos(math.rad(Obl))
obltan=math.tan(math.rad(Obl))
zsin=math.sin(math.rad(0))
zcos=math.cos(math.rad(0))
ztan=math.tan(math.rad(0))
Ra1 = datan2((th1sin * oblcos - ztan* zsin),th1cos)--close ish
Dec1 = math.asin(zsin* oblcos + zcos*oblsin*th1sin)--very close
--SUN CALCULATIONS---------------------------------------------------------------
delta=math.deg(Dec1)
sdec=delta
--calculate hangle in relation to altitude in relation to time
althrtab={}
shartab={}
total=1440
for i=1,total do
sha=180+(i*(360/total))
cossha=math.cos(math.rad(sha))
cossundec=math.cos(math.rad(sdec))
coslat=math.cos(math.rad(latitude))
cosmath=cossha*cossundec*coslat
sinsundec=math.sin(math.rad(sdec))
sinlat=math.sin(math.rad(latitude))
sinmath=sinsundec*sinlat
sinelevation=cosmath+sinmath
elevation=math.deg(math.asin(sinelevation))
curaltlong=elevation
curalt=round(curaltlong,2)
althrtab[i]=curalt
shartab[i]=sha-360
end
--calculate sunrise and sunset
for i=1,(total-1) do
if althrtab[i]<0 and althrtab[i+1]>0 then
rise=i
end
if althrtab[i]>0 and althrtab[i+1]<0 then
set=i
end
end
rise=rise/60
rises=string.split(rise,"%p")
sriseh=rises[1]
riseml=string.len(rises[2])
risem=(rises[2]/(10^riseml))*60
risems=string.split(risem,"%p")
srisem=risems[1]
set=set/60
sets=string.split(set,"%p")
sseth=sets[1]
setml=string.len(sets[2])
setm=(sets[2]/(10^setml))*60
setms=string.split(setm,"%p")
ssetm=setms[1]
--calculate azimuth for all above points
azitab={}
for i=1,total do
azmath1=(math.cos(math.rad(shartab[i]))*cossundec*sinlat)-(sinsundec*coslat)
azmath2=math.cos(math.rad(althrtab[i]))
cosaz=azmath1/azmath2
azi1=math.deg(math.acos(cosaz))
aziplot=azi1
if shartab[i]<0 then
azitab[i]=(aziplot-180)*-1
else
azitab[i]=aziplot+180
end
end
end--if hemishpere
if hemisphere==2 then
azitab={}
for i=1,total do
aziplot=azi1
azitab[i]=(aziplot-360)*-1
else
azitab[i]=aziplot--+180
end
end
end--if hemishpere
--diplay sun plot
for i = 1,total do
circrad=0.25
circx=across-180+azitab[i]
circy=down-althrtab[i]
cairo_arc(cr,circx,circy,circrad,0,2*math.pi)
cairo_close_path(cr)
cairo_set_source_rgba(cr,0.4,0.4,0.4,1)
cairo_fill (cr)
end
--plot current sun position
circrad=7
circx=across-180+azitab[stime]
circy=down-althrtab[stime]
cairo_set_source_rgba(cr,1,1,0,1)
cairo_fill (cr)
--curerent sun alt and azi
sunalt=althrtab[stime]
sunazi=azitab[stime]
--draw vertical N-S line
cairo_set_line_width (cr, 1)
cairo_set_source_rgba(cr,0.5,0.5,0.5,1)
cairo_move_to (cr, across, down+100)
cairo_line_to (cr, across, down-100)
cairo_stroke (cr)
--draw horizon
cairo_move_to (cr, across-180, down)
cairo_line_to (cr, across+180, down)
cairo_stroke (cr)
cairo_move_to (cr, across-4, down-102)
cairo_show_text (cr, "S")
cairo_move_to (cr, across-4, down+109)
cairo_show_text (cr, "N")
else
cairo_stroke (cr)
end
--#############  MOON CACULATIONS AND DISPLAY ###########################################################################################################
--calculate moon data----------------------------------------------------------------
--moon stuff
F = range(93.2721 + 483202 * t - 0.003403 * t* t - t * t * t/3526000);
L2 = range(218.316 + 481268 * t);
Om2 = range(125.045 - 1934.14 * t + 0.002071 * t * t + t * t * t/450000);
M2 = range(134.963 + 477199 * t + 0.008997 * t * t + t * t * t/69700);
cosm2=math.cos(math.rad(M2))
D = range(297.85 + 445267 * t - 0.00163 * t * t + t * t * t/545900);
D2 = 2*D;
cosd2m2=math.cos(math.rad(D2-M2))
cosd2=math.cos(math.rad(D2))
R2 = 1 + (-20954 * cosm2 - 3699 * cosd2m2 - 2956 * cosd2 / 385000);
R3 = (R2 / R1) / 379.168831168831;
sinf=math.sin(math.rad(F))
sinm2f=math.sin(math.rad(M2-F))
sind2f=math.sin(math.rad(D2-F))
Bm = 5.128 * sinf + 0.2806 * sinm2f;
Bm = Bm + 0.2777 * sinm2f + 0.1732 * sind2f;
sinm2=math.sin(math.rad(M2))
sind2m2=math.sin(math.rad(D2-M2))
sind2=math.sin(math.rad(D2))
Lm = 6.289 * sinm2 + 1.274 * sind2m2 + 0.6583 * sind2;
sin2m2=math.sin(math.rad(2*M2))
sin2f=math.sin(math.rad(2*F))
Lm = Lm + 0.2136 * sin2m2 - 0.1851 * sinm1 - 0.1143 * sin2f;
sind22m2=math.sin(math.rad(D2-(2*M2)))
Lm = Lm +0.0588 * sind22m2
sind2m1m2=math.sin(math.rad(D2-M1-M2))
sind2m22=math.sin(math.rad(D2+M2))
Lm = Lm + 0.0572* sind2m1m2 + 0.0533* sind2m22;
Lm = Lm + L2;
tanbm=math.tan(math.rad(Bm))
sinbm=math.sin(math.rad(Bm))
cosbm=math.cos(math.rad(Bm))
sinlm=math.sin(math.rad(Lm))
coslm=math.cos(math.rad(Lm))
Ra2 = math.atan((sinlm * oblcos - tanbm* oblsin));
Dec2 = math.asin(sinbm* oblcos + cosbm*oblsin*sinlm);
sinlam1lm=math.sin(math.rad(Lam1-Lm))
HLm = range(Lam1 + 180 + (180/math.pi) * R3 * cosbm * sinlam1lm);
HBm = R3 * Bm;
--obliquity of ecliptic:
eps = 23.0 + 26.0/60.0 + 21.448/3600.0 - (46.8150*T+ 0.00059*T*T- 0.001813*T*T*T)/3600;
X = cos(Bm)*cos(Lm)
Y = cos(eps)*cos(Bm)*sin(Lm) - sin(eps)*sin(Bm)
Z = sin(eps)*cos(Bm)*sin(Lm) - cos(eps)*sin(Bm)
R = math.sqrt(1.0-Z*Z);
delta = (180/math.pi)*math.atan(Z/R); -- in degrees-- declination
RA = (24/math.pi)*math.atan(Y/(X+R)); -- in hours
delta=math.deg(Dec2)
sdec=delta
althrtab={}
shartab={}
total=1440
for i=0,total do
althrtab[i]=curalt
shartab[i]=sha-360
end
--calculate moonrise and moonset
rise=i
end
set=i
end
end
rise=rise/60
mriseh=rises[1]
mrisem=risems[1]
set=set/60
mseth=sets[1]
msetm=setms[1]
azitab={}
for i=1,total do
aziplot=azi1
else
end
end
end--if hemishpere
azitab={}
for i=1,total do
aziplot=azi1
else
azitab[i]=aziplot
end
end
end--if hemishpere
--diplay moon plot
for i = 1,total do
circrad=0.25
cairo_set_source_rgba(cr,0.7,0.7,0.7,1)
cairo_fill (cr)
end
--plot current moon position
madj=tostring(rangei(sgtime+360))
mtime=madj
circrad=5
circx=across-180+(azitab[tonumber(mtime)])
circy=down-(althrtab[tonumber(mtime)])
cairo_set_source_rgba(cr,1,1,1,1)
cairo_fill (cr)
--curerent moon alt and azi
moonalt=althrtab[tonumber(mtime)]
moonazi=azitab[tonumber(mtime)]
--#############  TEXT DISPLAYS ###########################################################################################################
--draws text label
font="Mono"
fontsize=10
cairo_set_font_size (cr, fontsize);
cairo_set_source_rgba (cr, 0.1, 0.1, 0.1, 0.5);
--top left - sun moon alt and azi
tlx=20
tly=20
adj=10
cairo_move_to (cr, tlx, tly)
cairo_show_text (cr, "Positions")
gap=10
add=fontsize+((fontsize/100)*adj)+gap
cairo_move_to (cr, tlx, tly+add)
cairo_show_text (cr, "Soleil")
add=fontsize+((fontsize/100)*adj)+add
cairo_show_text (cr, "Azimut " .. round(sunazi,2) .. "°")
cairo_show_text (cr, "Altitude " .. sunalt .. "°")
gap=10
add=fontsize+((fontsize/100)*adj)+add+gap
cairo_show_text (cr, "Lune")
cairo_show_text (cr, "Azimut " .. round(moonazi,2) .. "°")
cairo_show_text (cr, "Altitude " .. moonalt .. "°")
tlx=180
tly=20
adj=10
cairo_show_text (cr, "Heure")
gap=10
cairo_show_text (cr, "Heure  Locale: " .. H .. ":" .. Min)
cairo_show_text (cr, "Heure Sidérale: " .. GMST24H .. ":" .. GMST24M )
cairo_show_text (cr, "Heure Solaire : " .. LST24H .. ":" .. LST24M)
cairo_stroke (cr)
end-- end if updates =
end--end main function
Audacious cliquable
Un autre conky cliquable pour audacious tirer d'un skin covergloobus sur deviantart
le conkyrc
# -- Conky settings -- #
background no
update_interval 0.5
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
no_buffers yes
text_buffer_size 1024
imlib_cache_size 15000
max_specials 10000
max_user_text 15000
diskio_avg_samples 2
format_human_readable yes
border_inner_margin 0
border_outer_margin 0
# -- Window specifications -- #
own_window yes
own_window_transparent no
own_window_argb_value 0
own_window_hints undecorate,skip_taskbar,skip_pager,below
own_window_title media
minimum_size 412 176
maximum_width 412
alignment top_right
gap_x 40
gap_y 820
# -- Graphics settings -- #
draw_shades no
draw_outline no
draw_borders yes
border_width 0
default_bar_size 210 4
default_color 000000
# -- Text settings -- #
use_xft yes
xftfont GE Inspira:size=8
color1 92deee
color2 668c95
color3 d0fefb
color4 2f3d40
color5 ff6c4a
lua_load ~/.conky/audacious/scripts/button_script.lua
lua_draw_hook_pre get_mouse {"media","/tmp/xdo"}
lua_startup_hook start_xdo /tmp/xdo
#lua_shutdown_hook stop_xdo
lua_load ~/.conky/audacious/scripts/lua_functions.lua
template1 ${lua rc_button {btype=3,bname="button1",blx_off=278,bly_off=75,bw_off=22,bh_off=12}}
template2 ${lua rc_button {btype=3,bname="button2",blx_off=216,bly_off=75,bw_off=22,bh_off=12}}
template3 ${lua rc_button {btype=3,bname="button3",blx_off=185,bly_off=75,bw_off=22,bh_off=12}}
template4 ${lua rc_button {btype=3,bname="button4",blx_off=247,bly_off=75,bw_off=22,bh_off=12}}
template5 ${lua rc_button {btype=3,bname="button5",blx_off=309,bly_off=75,bw_off=22,bh_off=12}}
TEXT
${execi 3 ~/.conky/audacious/scripts/cover.sh}
${lua fDrawImage ~/.conky/audacious/casee.png 0 0 410 138}${lua fDrawImage ~/.conky/audacious/audacious.png 40 32 70 70}${lua fDrawImage ~/.conky/audacious/album.png 28 20 93 92}${voffset -30}${font GE Inspira :size=14}
${alignc -50}${execi 3 audtool current-song-tuple-data artist}${font}
${alignc -50}${execi 3 audtool current-song-tuple-data title}
${alignc -50}${execi 3 audtool current-song-tuple-data album}
${goto 160}${execi 1 audtool current-song-output-length}  ${goto 348}${execi 1 audtool current-song-length}
${voffset 10}${goto 160}${color 000000}${execbar expr 100 \* $(audtool --current-song-output-length-seconds) \/ $(audtool --current-song-length-seconds)}$color\
${goto 160}${color ffffff}${execbar echo 0}
${if_match ${template1}==0}
${else}${lua fDrawImage ~/.conky/audacious/images/Orange.png 360 5 35 35}${exec audacious --pause}
${endif}
${if_match ${template2}==0}
${else}${lua fDrawImage ~/.conky/audacious/images/Orange.png 360 5 35 35}${exec audacious --stop}
${endif}
${if_match ${template3}==0}
${else}${lua fDrawImage ~/.conky/audacious/images/Orange.png 360 5 35 35}${exec audacious --rew}
${endif}
${if_match ${template4}==0}
${else}${lua fDrawImage ~/.conky/audacious/images/Orange.png 360 5 35 35}${exec audacious --play}
${endif}
${if_match ${template5}==0}
${else}${lua fDrawImage ~/.conky/audacious/images/Orange.png 360 5 35 35}${exec audacious --fwd}
${endif}
${lua fDrawImage ~/.conky/audacious/ppause.png 278 65 30 15}
${lua fDrawImage ~/.conky/audacious/pstop.png 216 65 30 15}
${lua fDrawImage ~/.conky/audacious/pprev.png 185 65 30 15}
${lua fDrawImage ~/.conky/audacious/pplay.png 247 65 30 15}
${lua fDrawImage ~/.conky/audacious/pnext.png 309 65 30 15}
${voffset -350}
Conky olgmen
le conkyrc
background no
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 100 640
maximum_width 100
draw_shades no
draw_outline no
draw_borders no
border_width 1
default_color ffffff
alignment top_left
gap_x 0
gap_y 100
no_buffers yes
uppercase no
cpu_avg_samples 2
color1                ffff00
color2                6495ee
color3                ffffff
color4                ffffff
color5                6495ee
color6                red
 #cornflowerblue
# — Lua Load — #
lua_load ~/.conky/olgmen/scripts/data_comp.lua
lua_draw_hook_pre conky_widgets
TEXT
le lua principal
--[[data_comp.lua par olgmen le 25/12/2011
Francisation par loutch
fonction affiche des données sur le fonctionnement du processeur, de la mémoire, de l'Internet
pour exécuter cette fonction, il est nécessaire dans conkyrc, au-dessus du mot TEXT ajouter les lignes suivantes
# - Lua Load - #
lua_load ~ / scripts / data_comp.lua
Toutes les données sont calculées pour une utilisation dans la fenêtre conky avec la taille de 1260x675 (dans tout mon écran)
require "cairo"
-- définir la section d'accueil, pour la capacité de travailler à partir de n'importe quel ordinateur
usrhome = os.getenv("HOME")
-- les scripts nécessaires sont dans le dossier des scripts
--dofile (usrhome .."/scripts/backgraund.lua")    -- arrière-plan de sortie de script, cadres
dofile (usrhome .."/.conky/olgmen/scripts/text1.lua")            -- script sorties textes
dofile (usrhome .."/.conky/olgmen/scripts/scale1.lua")            -- sorties de script échelles
text_color = {{0, 0xffffff, 1},{0.5, 0xffffff, 1},{1, 0xffffff, 1}}
-- fonction qui démarre tout affiché dans la fenêtre conky. Toutes les données sont calculées pour une utilisation dans la fenêtre conky avec la taille de 1260x675 (dans tout mon écran)
function conky_widgets()
    text_settings = {
    text ="Processeurs" ,
    x = 20,
    y = 10,
    font_size = 12,
    bold = false,
    h_align = "l",
    v_align = "m",
    colour = text_color,
    orientation="nn",
    text ="CPU1" .. "                   " .. "°C",
    x = 15,
    y = 25,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="CPU2" .. "                   " .. "°C",
    x = 15,
    y = 100,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Mémoire" ,
    x = 30,
    y = 175,
    font_size = 12,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Ram" .."                   ".."Swap" ,
    x = 15,
    y = 190,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Disques" ,
    x = 36,
    y = 275,
    font_size = 12,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="/" .."                     ".."/Home" ,
    x = 25,
    y = 290,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Températures" ,
    x = 16,
    y = 375,
    font_size = 12,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Sda" .."                     ".."Carte" ,
    x = 15,
    y = 390,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Internet" ,
    x = 36,
    y = 475,
    font_size = 12,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = "Entrant" .. "             " .. "Sortant",
    x = 15,
    y = 490,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${totaldown wlp2s0}"),
    x = 10,
    y = 565,
    font_size = 8,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${totalup wlp2s0}"),
    x = 70,
    y = 565,
    font_size = 8,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text ="Processus" .. "    " .. "Mém" .. "    " .. "Cpu",
    x = 10,
    y = 585,
    font_size = 9,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top name 1}"),
    x = 5,
    y = 600,
    font_size = 7,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top mem 1)}%"),
    x = 65,
    y = 600,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    colour = text_color ,--{{0, 0x550000, 1},{0.5, 0xff0000, 1},{1, 0x550000, 1}},
    orientation="nn",
    text = conky_parse("${top cpu 1}%"),
    x = 95,
    y = 600,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top name 2}"),
    x = 5,
    y = 610,
    font_size = 7,
    bold = false,
    h_align = "l",
    v_align = "m",
    colour = text_color , --{{0, 0x550000, 1},{0.5, 0xcf5500, 1},{1, 0x550000, 1}},
    orientation="nn",
    text = conky_parse("${top mem 2)}%"),
    x = 65,
    y = 610,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    colour = text_color ,--{{0, 0x550000, 1},{0.5, 0xcf5500, 1},{1, 0x550000, 1}},
    orientation="nn",
    text = conky_parse("${top cpu 2}%"),
    x = 95,
    y = 610,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top name 3}"),
    x = 5,
    y = 620,
    font_size = 7,
    bold = false,
    h_align = "l",
    v_align = "m",
    colour = text_color , --{{0, 0x550000, 1},{0.5, 0xcfa500, 1},{1, 0x550000, 1}},
    orientation="nn",
    text = conky_parse("${top mem 3)}%"),
    x = 65,
    y = 620,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    colour = text_color ,--{{0, 0x550000, 1},{0.5, 0xcfa500, 1},{1, 0x550000, 1}},
    orientation="nn",
    text = conky_parse("${top cpu 3}%"),
    x = 95,
    y = 620,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top name 4}"),
    x = 5,
    y = 630,
    font_size = 7,
    bold = false,
    h_align = "l",
    v_align = "m",
    colour = text_color ,--{{0, 0x555500, 1},{0.5, 0xcfcf00, 1},{1, 0x555500, 1}},
    orientation="nn",
    text = conky_parse("${top mem 4)}%"),
    x = 65,
    y = 630,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top cpu 4}%"),
    x = 95,
    y = 630,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top name 5}"),
    x = 5,
    y = 640,
    font_size = 7,
    bold = false,
    h_align = "l",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top mem 5)}%"),
    x = 65,
    y = 640,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
    text = conky_parse("${top cpu 5}%"),
    x = 95,
    y = 640,
    font_size = 7,
    bold = false,
    h_align = "c",
    v_align = "m",
    orientation="nn",
-- dériver des échelles
    scale_settings = {
    name = "cpu",
    arg = "cpu0",
    x = 10,
    y = 30,
    width = 35,
    height = 60,
    scale = 16,
    colour_scale = {{0, 0xffffff, 1},{0.5, 0xffffff, 1},{1, 0xffffff, 1}},
    font_size = 9,
    name = "exec",
    arg = "expr `cat /sys/class/hwmon/hwmon2/temp1_input` / 1000",
    x = 70,
    y = 30,
    width = 35,
    height =60,
    scale = 16,
    colour_scale = {{0, 0xff0000, 1},{0.5, 0xffffff, 1},{1, 0x0000ff, 1}},
    font_size = 9,
    name = "cpu",
    arg = "cpu1",
    x = 10,
    y = 105,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "exec",
    arg = "expr `cat /sys/class/hwmon/hwmon2/temp2_input` / 1000",
    x = 70,
    y = 105,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "memperc",
    arg = "",
    x = 10,
    y = 200,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "swapperc",
    arg = "",
    x = 70,
    y = 200,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "fs_used_perc",
    arg = "/",
    x = 10,
    y = 300,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    arg = "/home",
    x = 70,
    y = 300,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "execi",
    arg = "120 hddtemp -n /dev/sda",
    x = 10,
    y = 400,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "hwmon",
    arg = "1 temp 1",
    x = 70,
    y = 400,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "",
    arg = math.ceil(conky_parse("${downspeedf wlp2s0}")),
    x = 10,
    y = 500,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
    name = "",
    arg = math.ceil(conky_parse("${upspeedf wlp2s0}")),
    x = 70,
    y = 500,
    width = 35,
    height = 60,
    scale = 16,
    font_size = 9,
--[[ Ici, l'entrée de toutes les données se termine ]]
--[[ ÉCHELLES ]]
    for i,v in pairs(scale_settings) do
        cr = cairo_create (cs)
        dialgraph(v)
        cairo_destroy(cr)
    end
-- sortie de texte
    for i,v in pairs(text_settings) do
        display_text(v)
        cairo_destroy(cr)
    end
end    -- fonction de fermeture
text.lua
--[[TEXT WIDGET v1.42 par Wlourf le 07 février 2011
Ce widget peut dessiner des textes dans la table "text_settings" avec quelques paramètres
http://u-scripts.blogspot.com/2010/06/text-widget.html
Pour appeler le script dans un conky, utilisez, avant TEXT
lua_load /path/to/the/script/graph.lua
lua_draw_hook_pre main_graph
et ajoutez une ligne (vide ou non) après TEXT
Les paramètres (tous les optionnels) sont:
texte - texte à afficher, défaut = "Conky est bon pour vous"
              il peut être utilisé avec des variables conky, c'est-à-dire text = "mon cpu1 est $ {cpu cpu1}%")
            - les coordonnées ci-dessous sont relatives au coin supérieur gauche de la fenêtre conique
x - x coordonnée de la première lettre (en bas à gauche), par défaut = centre de la fenêtre conky
y - y coordonnée de la première lettre (en bas à gauche), par défaut = centre de la fenêtre conky
h_align - alignement horizontal du texte par rapport au point (x, y), défaut = "l"
les valeurs disponibles sont "l": gauche, "c": centre, "r": droite
v_align - alignement vertical du texte par rapport au point (x, y), défaut = "b"
valeurs disponibles "t": haut, "m": milieu, "b": bas
font_name - nom de la police à utiliser, default = Free Sans
font_size - taille de la police à utiliser, par défaut = 14
italique - affiche le texte en italique (vrai / faux), défaut = faux
oblique - affiche le texte en oblique (vrai / faux), défaut = faux (je ne vois pas la différence avec italique!)
bold - affiche le texte en gras (vrai / faux), défaut = faux
angle - rotation du texte en degrés, par défaut = 0 (horizontal)
couleur - table de couleurs pour le texte, par défaut = blanc uni {{1,0xFFFFFF, 1}}
cette table contient une ou plusieurs tables au format {P, C, A}
              P = position du dégradé (0 = début du texte, 1 = fin du texte)
              C = couleur hexadécimale
              A = alpha (opacité) de la couleur (0 = invisible, 1 = opacité 100%)
              Exemples :
              pour une couleur unie {{1,0x00FF00,0.5}}
              pour un dégradé avec deux couleurs {{0,0x00FF00,0.5}, {1,0x000033,1}}
              ou {{0.5,0x00FF00,1}, {1,0x000033,1}} - avec celui-ci, le dégradé commencera au milieu du texte
              pour un dégradé avec trois couleurs {{0,0x00FF00,0.5}, {0.5,0x000033,1}, {1,0x440033,1}}
etc ...
orientation - en cas de gradient, "orientation" définit le point de départ du dégradé, défaut = "ww"
il y a 8 points de départ disponibles: "nw", "nn", "ne", "ee", "se", "ss", "sw", "ww"
(n pour le nord, w pour l'ouest ...)
thèses 8 points sont les 4 coins + les 4 milieux du contour du texte
donc un gradient "nn" passera de "nn" à "ss" (de haut en bas, parallélisé au texte)
un gradient "nw" passera de "nw" à "se" (coin supérieur gauche à coin inférieur droit)
radial - définit un gradient radial (si présent en même temps que "orientation", "orientation" n'aura aucun effet)
ce paramètre est une table avec 6 nombres: {xa, ya, ra, xb, yb, rb}
ils définissent deux cercles pour le dégradé:
xa, ya, xb et yb sont relatifs aux valeurs x et y ci-dessus
reflection_alpha - ajoute un effet de réflexion (valeurs de 0 à 1) défaut = 0 = pas de réflexion
                      autres valeurs = début de l'opacité
reflection_scale - échelle de la réflexion (par défaut = 1 = hauteur du texte)
reflection_length - longueur de la réflexion, définir où l'opacité sera mise à zéro
calues ​​de 0 à 1, défaut = 1
skew_x, skew_y - incline le texte autour de l'axe x ou y
draw_me - si défini sur false, le texte n'est pas dessiné (par défaut = true ou 1)
              il peut être utilisé avec une chaîne conky, si la chaîne renvoie 1, le texte est dessiné:
              exemple: "$ {if_empty $ {sans fil wlan0}} $ {else} 1 $ endif",
v1.0 07/06/2010, Version originale
v1.1 10/06/2010 Ajouter un paramètre "orientation"
v1.2 15/06/2010 Ajout des paramètres "h_align", "v_align" et "radial"
v1.3 25/06/2010 Ajouter "reflection_alpha", "reflection_length", "reflection_scale",
                    "skew_x" et "skew_y"
v1.4 07/01/2011 Ajout du paramètre draw_me et correction des fuites de mémoire grâce à "Creamy Goodness"
                    le texte est analysé à l'intérieur de la fonction, pas dans le tableau de paramètres
v1.41 26/01/2011 Correction d'un bug pour h_align = "c"
v1.42 09/02/2011 Corriger bug pour l'orientation = "ee"
- Ce programme est un logiciel libre; vous pouvez le redistribuer et / ou modifier
- sous les termes de la Licence Publique Générale GNU telle que publiée par
- la Free Software Foundation version 3 (GPLv3)
- Ce programme est distribué dans l'espoir qu'il sera utile,
- mais SANS AUCUNE GARANTIE; sans même la garantie implicite de
- QUALITÉ MARCHANDE ou ADAPTATION À UN USAGE PARTICULIER. Voir le
- Licence publique générale GNU pour plus de détails.
- Vous devriez avoir reçu une copie de la Licence Publique Générale GNU
- avec ce programme; sinon, écrivez au logiciel libre
- Foundation, Inc., 51 rue Franklin, cinquième étage, Boston,
- MA 02110-1301, États-Unis.
Suggérer une modification
require 'cairo'
function conky_draw_text()
    local text_settings={
        --BEGIN OF PARAMETERS
        {--display a text at coordinates 20,20
        text="unformatted text",
        x=20,
        y=20,
        {--display a text at coordinates 20,40, with selected font and size, true and bold
        text="bold and italic text",
        x=20,
        y=40,
        font_name="Verdana",
        font_size=18,
        italic=true,
        bold=true,
        draw_me="${if_empty ${wireless_essid wlan0}}${else}1$endif",
        {--display a text at coordinates 20,70, in green with opacity 0.8 and "oblique"
        text="green text",
        x=20,
        y=70,
        font_size=18,
        oblique=true,
        --colour table contains one or more tables with 3 elements, here:
        --1 = starting point for gradient (0= beginning of the text, 1= end of the text)
        --0x00FF00    = colour in hexadecimal
        --0.8         = opacity (0=invisible, 1=opacity 100%)
        colour={{1,0x00FF00,0.8}}
        {--display a text at coordinates 20,100, with a red green blue gradient
        text="text with gradient (ww)", --(default orientation=ww)
        x=20,
        y=100,
        font_name="Clarendon",
        font_size=25,
        colour={{0,0xFF0000,0.9},{0.5,0x00FF00,1},{1,0xFFFF00,0.9}},
        {--display a text at coordinates 20,130, with a red green yellow gradient
        text="text with gradient (nn)",
        x=20,
        y=130,
        font_size=25,
        orientation="nn",
        colour={{0,0xFF0000,1},{0.5,0x00FF00,1},{1,0xFFFF00,1}},
        {--display a text at coordinates 40,290, with a yellow blue yellow gradient
        --with a 30° angle
        text="text at 30 degrees",
        x=400,
        y=190,
        colour={{0,0xFFFF00,1},{0.5,0x0000FF,1},{1,0xFFFF00,1}},
        angle=-30,
        font_size=32
        {--text with 5 colours gradient
        text="vertical text",
        x=50,
        y=450,
        colour={{0         ,0xFF0000,1},
                {0.25    ,0xFFFF00,1},
                {0.50    ,0x00FF00,1},
                {0.75    ,0x00FFFF,1},
                {1         ,0x0000FF,1}
        angle=-90,
        font_size=40,
        orientation="nw"
        {--vertical text with 3 colours gradient
        text="\"bumped\" effect",
        x=250,
        y=270,
        colour={{0         ,0xDDDDDD,0.15},
                {0.50    ,0xFFFFFF,1},
                {1         ,0xDDDDDD,0.15}
        font_size=35,
        orientation="nn"
--radial gradient
        text="radial gradient",
        x=400,
        y=350,
        font_size="48",
        colour={
                {0.8,0xF0FFF0,1},
                {1.00,0xF0F0FF,0.1},
           h_align="c",
           radial={0,300,0,0,300,370}
        text="another radial gradient",
        x=400,
        y=400,
        font_size="48",
        colour={
                {0.98,    0xFFFF00,1},
                {0.99,    0xFF0000,1},
                {1.00,    0xFF00FF,1},
           h_align="c",
           v_align="m",
        radial={0,-1000,0,0,-1000,1020}
         {--display a text with some conly variables
        --use two dots to concatenate texts
        text="text with some conky, cpu= ${cpu} %",
        x=20,
        y=660,
        colour={{0,0xFFFF00,1},{0.5,0xFF0000,1},{1,0xFFFF00,1}},
        font_name="Purisa",
        bold=true,
        font_size=38
--text with shadow:
        text=conky_parse("${uptime}"),
        x=50,
        y=100,
        font_size=24,
           orientation="ww",
        text='text with shadow #1',
        x=298,
        y=498,
        font_size=50,
        colour={{0,0xFFFF00,1}},
            orientation="ww",
 --blur effect
        text='blur effect',
        x=300,
        y=550,
        font_size=50,
        colour={{0.00,0x00FF00,0.35},
        text='blur effect',
        x=299,
        y=549,
        font_size=50,
        text='blur effect',
        x=301,
        y=551,
        font_size=50,
--focus effect
        text='focus effect #1',
        x=300,
        y=600,
        font_size=50,
        colour={{0.00,0x00FFFF,0},
                {0.50,0x00FFFF,1},
                {1.00,0x00FFFF,0},
           orientation="ww",
        x=300,
        y=599,
        font_size=50,
        colour={{0.00,0x00FFFF,0.5},
                {0.50,0x00FFFF,0},
                {1.00,0x00FFFF,0.5},
           orientation="ww",
        x=300,
        y=601,
        font_size=50,
                {0.50,0x00FFFF,0},
           orientation="ww",
--focus effect 2
        text='focus effect #2',
        x=300,
        y=720,
        font_size=50,
        colour={{0.00,0x00FFFF,1},
                {1,0x00FFFF,0},
        x=299,
        y=719,
        font_size=50,
                {1,0x00FFFF,0.25},
        x=301,
        y=721,
        font_size=50,
                {1,0x00FFFF,0.25},
--text with reflection
        text="${time %H:%M:%S}",
        y=730,
        x=50,
        font_name="Ubuntu-title",
        font_size=50,
        colour={{0,0xFF0000,1},{1,0xCCCCCC,1}},
        orientation="nn",
        reflection_alpha=0.8,
        reflection_length=0.9
--skew x
        text="skew x",
        font_size=24,
        colour={{0,0x00FF00,1},{1,0x00FFFF,1}},
        x=30,
        y=500,
        skew_x=-10
--skew y
        text="skew y",
        font_size=24,
        x=150,
        y=500,
        skew_y=10
--skew x + skew y
        text="skew x-y",
        font_size=24,
        x=30,
        y=550,
        skew_y=10,
        skew_x=10
--skew x + skew y
        text="skew x-y",
        font_size=24,
        x=150,
        y=550,
        skew_y=10,
        skew_x=10,
        reflection_scale=2,
        reflection_length=1.5
--------------END OF PARAMETERS----------------
    if tonumber(conky_parse("$updates"))<3 then return end
        display_text(v)
        cairo_destroy(cr)
        cr = nil
    end
    cairo_surface_destroy(cs)
end
function rgb_to_r_g_b2(tcolour)
    local colour,alpha=tcolour[2],tcolour[3]
    return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
end
function display_text(t)
    if t.draw_me==true then t.draw_me = nil end
    if t.draw_me~=nil and conky_parse(tostring(t.draw_me)) ~= "1" then return end
    local function set_pattern(te)
        --this function set the pattern
        if #t.colour==1 then
            cairo_set_source_rgba(cr,rgb_to_r_g_b2(t.colour[1]))
        else
            local pat
            if t.radial==nil then
                local pts=linear_orientation(t,te)
                pat = cairo_pattern_create_linear (pts[1],pts[2],pts[3],pts[4])
            else
                pat = cairo_pattern_create_radial (t.radial[1],t.radial[2],t.radial[3],t.radial[4],t.radial[5],t.radial[6])
            end
            for i=1, #t.colour do
                cairo_pattern_add_color_stop_rgba (pat, t.colour[i][1], rgb_to_r_g_b2(t.colour[i]))
            end
            cairo_set_source (cr, pat)
            cairo_pattern_destroy(pat)
        end
    end
    --set default values if needed
    if t.text==nil then t.text="Conky is good for you !" end
    if t.x==nil then t.x = conky_window.width/2 end
    if t.y==nil then t.y = conky_window.height/2 end
    if t.colour==nil then t.colour={{1,0xFFFFFF,1}} end
    if t.font_name==nil then t.font_name="Free Sans" end
    if t.font_size==nil then t.font_size=14 end
    if t.angle==nil then t.angle=0 end
    if t.italic==nil then t.italic=false end
    if t.oblique==nil then t.oblique=false end
    if t.bold==nil then t.bold=false end
    if t.radial ~= nil then
        if #t.radial~=6 then
            print ("error in radial table")
            t.radial=nil
        end
    end
    if t.orientation==nil then t.orientation="ww" end
    if t.h_align==nil then t.h_align="l" end
    if t.v_align==nil then t.v_align="b" end
    if t.reflection_alpha == nil then t.reflection_alpha=0 end
    if t.reflection_length == nil then t.reflection_length=1 end
    if t.reflection_scale == nil then t.reflection_scale=1 end
    if t.skew_x==nil then t.skew_x=0 end
    if t.skew_y==nil then t.skew_y=0 end
    cairo_translate(cr,t.x,t.y)
    cairo_rotate(cr,t.angle*math.pi/180)
    cairo_save(cr)
    local slant = CAIRO_FONT_SLANT_NORMAL
    local weight = CAIRO_FONT_WEIGHT_NORMAL
    if t.italic then slant = CAIRO_FONT_SLANT_ITALIC end
    if t.oblique then slant = CAIRO_FONT_SLANT_OBLIQUE end
    if t.bold then weight = CAIRO_FONT_WEIGHT_BOLD end
    cairo_select_font_face(cr, t.font_name, slant,weight)
        if #t.colour[i]~=3 then
            print ("error in color table")
            t.colour[i]={1,0xFFFFFF,1}
        end
    end
    local matrix0 = cairo_matrix_t:create()
    tolua.takeownership(matrix0)
    local skew_x,skew_y=t.skew_x/t.font_size,t.skew_y/t.font_size
    cairo_matrix_init (matrix0, 1,skew_y,skew_x,1,0,0)
    cairo_transform(cr,matrix0)
    cairo_set_font_size(cr,t.font_size)
    local te=cairo_text_extents_t:create()
    tolua.takeownership(te)
    t.text=conky_parse(t.text)
    cairo_text_extents (cr,t.text,te)
    set_pattern(te)
    local mx,my=0,0
    if t.h_align=="c" then
        mx=-te.width/2-te.x_bearing
    elseif t.h_align=="r" then
        mx=-te.width
    end
    if t.v_align=="m" then
        my=-te.height/2-te.y_bearing
    elseif t.v_align=="t" then
        my=-te.y_bearing
    end
    cairo_move_to(cr,mx,my)
    cairo_show_text(cr,t.text)
   if t.reflection_alpha ~= 0 then
        local matrix1 = cairo_matrix_t:create()
        tolua.takeownership(matrix1)
        cairo_matrix_init (matrix1,1,0,0,-1*t.reflection_scale,0,(te.height+te.y_bearing+my)*(1+t.reflection_scale))
        te=nil
        cairo_transform(cr,matrix1)
        set_pattern(te)
        local pat2 = cairo_pattern_create_linear (0,
                                        (te.y_bearing+te.height+my),
                                        0,
                                        te.y_bearing+my)
        cairo_pattern_add_color_stop_rgba (pat2, 0,1,0,0,1-t.reflection_alpha)
        cairo_pattern_add_color_stop_rgba (pat2, t.reflection_length,0,0,0,1)
        --line is not drawn but with a size of zero, the mask won't be nice
        cairo_set_line_width(cr,1)
        local dy=te.x_bearing
        if dy<0 then dy=dy*(-1) end
        cairo_rectangle(cr,mx+te.x_bearing,te.y_bearing+te.height+my,te.width+dy,-te.height*1.05)
        cairo_clip_preserve(cr)
        --cairo_stroke(cr)
        cairo_mask(cr,pat2)
        cairo_pattern_destroy(pat2)
        te=nil
    end
end
function linear_orientation(t,te)
    local w,h=te.width,te.height
    local xb,yb=te.x_bearing,te.y_bearing
        xb=xb-w/2
        xb=xb-w
       end
        yb=-h/2
        yb=0
       end
    local p=0
    if t.orientation=="nn" then
        p={xb+w/2,yb,xb+w/2,yb+h}
    elseif t.orientation=="ne" then
        p={xb+w,yb,xb,yb+h}
    elseif t.orientation=="ww" then
        p={xb,h/2,xb+w,h/2}
    elseif vorientation=="se" then
        p={xb+w,yb+h,xb,yb}
    elseif t.orientation=="ss" then
        p={xb+w/2,yb+h,xb+w/2,yb}
    elseif t.orientation=="ee" then
        p={xb+w,h/2,xb,h/2}
    elseif t.orientation=="sw" then
        p={xb,yb+h,xb+w,yb}
    elseif t.orientation=="nw" then
        p={xb,yb,xb+w,yb+h}
    end
    return p
end
scale.lua
--[[cadrans mrpeachy mai 2011
créé par olgmen 11/12/2011
pour le travail il faut ajouter conkyrc au-dessus du mot TEXT
lua_load / chemin d'accès au fichier / scale.lua - modifier pour n'importe quoi et où vous avez enregistré le fichier
lua_draw_hook_pre draw_fig - doit être inchangé
x - coordonnées du coin supérieur gauche de l'échelle horizontalement
y - les coordonnées du coin supérieur droit de l'échelle verticalement
largeur - largeur de l'échelle
hauteur - hauteur de l'échelle
échelle - le nombre total de divisions affichées
couleur - la couleur des divisions et des chiffres affichés
color_middle - couleur des lignes centrales
alpha - saturation des couleurs
nom_fonte - nom de la police
font_size - Taille de la police
dernière mise à jour 02.01.2012
require 'cairo'
scale_settings = {
name = "",
arg = math.ceil(conky_parse("${time %S}")),
x = 100,
y = 50.5,
width = 60,
height = 200,
scale = 40,                --combien de divisions peuvent être vus dans le cadran
font = "Ubuntu",
font_size = 12,        --number font and font size
            dialgraph(v)
            cairo_destroy(cr)
    end
end
-- функция перекодировки цвета
function rgb_to_r_g_b(colour,alpha)
end
function dialgraph (t)
--    local function rgb_to_r_g_b2(tcolour)
--        colour, alpha = tcolour[2], tcolour[3]
--        return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
--    end
    local function rgb_to_r_g_b(colour,alpha)
    end
-- vérifier les données et ajouter les données par défaut
    if t.x                == nil then t.x = conky_window.width/2 end
    if t.y                == nil then t.y = conky_window.height/2 end
    if t.width             == nil then t.width = 50 end
    if t.height            == nil then t.height = 100 end
    if t.scale            == nil then t.scale = 20 end
    if t.alpha            == nil then t.alpha = 1 end
    if t.colour_middle    == nil then t.colour_middle = 0xff5500 end
    if t.font_name        == nil then t.font_name = "Ubuntu" end
    if t.font_size        == nil then t.font_size = 14 end
    if t.orientation    == nil then t.orientation = "nn" end
    if t.colour_scale     == nil then
        t.colour_scale = {{0, 0x333333, 0.75},{0.5, 0xffffff, 1},{1, 0x333333, 0.75}}
    end
    if t.draw_me == true then t.draw_me = nil end
    if t.draw_me ~= nil and conky_parse(tostring(t.draw_me)) ~= "1" then return end
    local value = 0
    if t.name ~= "" then
        value = tonumber(conky_parse(string.format('${%s %s}', t.name, t.arg)))
    else
        value = tonumber(t.arg)
    end
    if value == nil then value = 0 end
--valuegraph
    local adj = (value % 5)
    local lines = tonumber(t.scale)
    local gap = t.height/lines
--    cairo_set_source_rgba(cr, rgb_to_r_g_b(t.colour, t.alpha))
    cairo_select_font_face (cr, t.font_name, CAIRO_FONT_SLANT_NORMAL, CAIRO_FONT_WEIGHT_NORMAL)
    cairo_set_font_size (cr, t.font_size)
    if #t.colour_scale == 1 then
        cairo_set_source_rgba(cr,rgb_to_r_g_b2(t.colour_scale[1]))
    else
        local pat
        local pts=linear_orientation_bg(t)
        pat = cairo_pattern_create_linear (pts[1], pts[2], pts[3], pts[4])
        for i=1, #t.colour_scale do
            cairo_pattern_add_color_stop_rgba (pat, t.colour_scale[i][1], rgb_to_r_g_b2(t.colour_scale[i]))
        end
    end
--calculate line and number positions
    for i = 2,lines do
        n = i
        for i = 1, lines, 5 do
--print (i)
            if n == (lines/2)+(5-adj)+i or n == (lines/2)+(5-adj)+(-i-3) then
                len = -2*(t.width/5)
            else
                len = -1*(t.width/5)
            end
            if n == (lines/2)+(5-adj)+i then
                num = value - adj + (i + 4)
                elseif n == (lines/2)+(5-adj)+(-i-3) then
                    num = value - adj-(i-1)
                else
                    num = ""
            end
--print lines
            cairo_move_to (cr, t.x+(t.width/2), t.y+t.height-(gap*(n-1)))
            cairo_rel_line_to (cr, len, 0)
--            cairo_stroke (cr)
--print numbers
            cairo_move_to (cr, t.x+(t.width/2)+2, t.y+t.height-(gap*(n-1))+(t.font_size/3))
            cairo_show_text (cr, num)
            cairo_stroke (cr)
        end--for
    end--for
--middle lines
    cairo_set_source_rgba(cr, rgb_to_r_g_b(t.colour_middle, t.alpha))
    cairo_move_to (cr, t.x + t.width, t.y + (t.height/2)+2)
    cairo_rel_line_to (cr, -t.width, 0)
    cairo_stroke (cr)
    cairo_move_to (cr, t.x + t.width, t.y + (t.height/2)-2)
    cairo_stroke (cr)
    cairo_pattern_destroy (pat)
--[[    local function linear_orientation_bg(t)
        if t.orientation    == "nn" then
            p = {t.x + t.width/2, t.y, t.x + t.width/2, t.y + t.height}
        elseif t.orientation    == "ne" then
            p = {t.x + t.width, t.y, t.x, t.y + t.height}
        elseif t.orientation    == "ee" then
            p = {t.x + t.width, t.y + t.height/2, t.x, t.y + t.height/2}
        elseif t.orientation    == "se" then
            p = {t.x +t.width, t.y + t.height, t.x, t.y}
        elseif t.orientation    == "ss" then
            p = {t.x + t.width/2, t.y + t.height, t.x + t.width/2, t.y}
        elseif t.orientation    == "sw" then
            p = {t.x, t.y + t.height, t.x + t.width, t.y}
        elseif t.orientation    == "ww" then
            p = {t.x, t.y + t.height/2, t.x + t.width, t.y + t.height/2}
        else
            p = {t.x, t.y, t.x + t.width, t.y + t.height}
        end
        return p
    end
end
end
    else
    end
    return p
end
