Dernière mise à jour : 08/09/2017 à 18h50
Position du soleil et de la lune
conkyrc
background no
use_xft yes
xftalpha 1
update_interval 1
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
double_buffer yes
minimum_size 380 310
maximum_width 380
text_buffer_size 2048
draw_shades no
draw_outline no
draw_borders no
border_width 1
draw_graph_borders no
default_outline_color cacaca
alignment top_right
gap_x 5
gap_y 100
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
color1 ffff00
lua_load ~/.conky/v11/conky/soleil.lua
lua_draw_hook_pre draw_fig
default_color 8b8b8b
lua_load ~/.conky/lua/image.lua
TEXT
${lua fDrawImage /home/loutch/.conky/v11/conky/terre.png 170 170 60 64 0}
soleil.lua
--sun position lua script by mrpeachy 2010 version 2 includes moon position
--input latitude
--for northern hemisphere enter positive
--for southern hemisphere enter negative
latitude=-49.1
longitude=7.06
--input hemisphere
--for northern enter 1
--for southern enter 2
hemisphere=2
--daylight saving? 1=yes, 0=no
dst=0
--position - this is the point where the N-S line crosses the horizon line
--the .5 helps make lines look sharper
across=200.5
down=200.5
require 'cairo'
function cos(x)
a=math.cos(math.rad(x))
return a
end
function sin(x)
a=math.sin(math.rad(x))
return a
end
function tan(x)
a=math.tan(math.rad(x))
return a
end
function addzero10(num)
if tonumber(num) < 10 then
return "0" .. num
else
return num
end
end
function round(val, decimal)
if (decimal) then
return math.floor( (val * 10^decimal) + 0.5) / (10^decimal)
else
return math.floor(val+0.5)
end
end
local result = { }
local from = 1
while delim_from do
from = delim_to + 1
end
return result
end
function datan2(y, x)
if x == 0 and y == 0 then
return 0
else a = math.atan(math.rad(y / x))
end
if (x < 0) then
a = a + 180
else if y < 0 and x > 0 then
a = a + 360
end
end
return math.rad(a)
end
function ipart(x)
if (x> 0) then
a = math.floor(x)
else a = math.ceil(x);
end
return a
end
function range(x)
b = x / 360;
a = 360 * (b - ipart(b));
if a < 0 then
a = a + 360
end
return a
end
function ranget(x)
b = x / 24;
a = 24 * (b - ipart(b));
if a < 0 then
a = a + 24
end
return a
end
function rangei(x)
b = x / 1440;
a = 1440 * (b - ipart(b));
if a < 0 then
a = a + 1440
end
return a
end
--########### MAIN FUNCTION ########################################################################################################
function conky_draw_fig()
cr = cairo_create(cs)
--########### START FUNCTION ########################################################################################################
if updates > 5 then
--########### SET HEMISPHERE ########################################################################################################
if hemisphere==1 then
start=0
else
start=180
end
--################ sets daylignt saving #####################################3
if dst==1 then ds=-1 else ds=0 end
--########### calculate julian time ########################################################################################################
M=os.date("%m") --month
K=os.date("%G") --4 digit year
I=(os.date("%d"))--day of month
H=ranget((os.date("%H"))+ds) --hours
Min=os.date("%M")
Mi=(os.date("%M"))/60 --minutes expressed as hours
--current Julian time-----------------------------------------------------------------
JD=round((367*K)-((7*(K+((M+9)/12)))/4)+((275*M)/9)+I+1721013.5,0)+0.5+((H+Mi)/24)
days=(JD)-2451545.0 --correct
T=days/36525 --correct
--Julian time at preceeding midnight
JD0=round((367*K)-((7*(K+((M+9)/12)))/4)+((275*M)/9)+I+1721013.5,0)+0.5
D0=JD0-2451545.0
--########### calculate sidereal time ########################################################################################################
--current sidereal time
CST=6.697374558+(0.06570982441908*D0)+(1.00273790935*(H+Mi))
GMST = 6.697374558 + (0.06570982441908*D0) + (1.00273790935*(H+Mi)) + (0.000026*(T^2))
ADJ=longitude/15
GMST24=ranget(GMST)
GMST24S=string.split(GMST24, "%p")
GMST24H=GMST24S[1]
GMST24M=string.len(GMST24S[2])
GMST24M=GMST24S[2]/(10^(GMST24M))*60
GMST24M=string.split(GMST24M,"%p")
GMST24M=GMST24M[1]
sgtime=(GMST24H*60)+GMST24M
day=os.date("%j")
B=(360/365)*(day-81)
eot=(9.87*math.sin(2*B))-(7.53*math.cos(B))-(1.5*math.sin(B))
LSTM=15*10
TC=(4*(LSTM-longitude))+eot
LT=((H)*60)+Min
LST=LT+(TC/60)
LST24=ranget(LST/60)
LST24S=string.split(LST24, "%p")
LST24H=LST24S[1]
LST24M=string.len(LST24S[2])
LST24M=(LST24S[2]/(10^(LST24M)))*60
LST24M=string.split(LST24M,"%p")
LST24M=LST24M[1]
--below is current solar time
stime=(LST24H*60)+LST24M
--############# END TIME CALCS ###########################################################################################################
--############# SUN CACULATIONS AND DISPLAY ###########################################################################################################
-- Sun formulas
-- L1 - Mean longitude
-- M1 - Mean anomaly
-- C1 - Equation of centre
-- V1 - True anomaly
-- Ec1 - Eccentricity
-- R1 - Sun distance
-- Th1 - Theta (true longitude)
-- Om1 - Long Asc Node (Omega)
-- Lam1- Lambda (apparent longitude)
-- Obl - Obliquity of ecliptic
-- Ra1 - Right Ascension
-- Dec1- Declination
t=T
L1 = range(280.466 + 36000.8 * t)
M1 = range(357.529+35999*t - 0.0001536* t*t + t*t*t/24490000)
sinm1=math.sin(math.rad(M1))
C1 = (1.915 - 0.004817* t - 0.000014* t * t)* sinm1;
C1 = C1 + (0.01999 - 0.000101 * t)* sinm1;
C1 = C1 + 0.00029 * sinm1;
V1 = M1 + C1;
cosv1=math.cos(math.rad(V1))
Ec1 = 0.01671 - 0.00004204 * t - 0.0000001236 * t*t;
R1 = 0.99972 / (1 + Ec1 * cosv1);--correct
Th1 = L1 + C1
Om1 = range(125.04 - 1934.1 * t)
om1sin=math.sin(math.rad(Om1))
Lam1 = Th1 - 0.00569 - 0.00478 * math.deg(om1sin);
Obl = (84381.448 - 46.815 * t)/3600; --correct
th1sin=math.sin(math.rad(Th1))
th1cos=math.cos(math.rad(Th1))
th1tan=math.tan(math.rad(Th1))
oblsin=math.sin(math.rad(Obl))
oblcos=math.cos(math.rad(Obl))
obltan=math.tan(math.rad(Obl))
zsin=math.sin(math.rad(0))
zcos=math.cos(math.rad(0))
ztan=math.tan(math.rad(0))
Ra1 = datan2((th1sin * oblcos - ztan* zsin),th1cos)--close ish
Dec1 = math.asin(zsin* oblcos + zcos*oblsin*th1sin)--very close
--SUN CALCULATIONS---------------------------------------------------------------
delta=math.deg(Dec1)
sdec=delta
--calculate hangle in relation to altitude in relation to time
althrtab={}
shartab={}
total=1440
for i=1,total do
sha=180+(i*(360/total))
cossha=math.cos(math.rad(sha))
cossundec=math.cos(math.rad(sdec))
coslat=math.cos(math.rad(latitude))
cosmath=cossha*cossundec*coslat
sinsundec=math.sin(math.rad(sdec))
sinlat=math.sin(math.rad(latitude))
sinmath=sinsundec*sinlat
sinelevation=cosmath+sinmath
elevation=math.deg(math.asin(sinelevation))
curaltlong=elevation
curalt=round(curaltlong,2)
althrtab[i]=curalt
shartab[i]=sha-360
end
--calculate sunrise and sunset
for i=1,(total-1) do
if althrtab[i]<0 and althrtab[i+1]>0 then
rise=i
end
if althrtab[i]>0 and althrtab[i+1]<0 then
set=i
end
end
rise=rise/60
rises=string.split(rise,"%p")
sriseh=rises[1]
riseml=string.len(rises[2])
risem=(rises[2]/(10^riseml))*60
risems=string.split(risem,"%p")
srisem=risems[1]
set=set/60
sets=string.split(set,"%p")
sseth=sets[1]
setml=string.len(sets[2])
setm=(sets[2]/(10^setml))*60
setms=string.split(setm,"%p")
ssetm=setms[1]
--calculate azimuth for all above points
azitab={}
for i=1,total do
azmath1=(math.cos(math.rad(shartab[i]))*cossundec*sinlat)-(sinsundec*coslat)
azmath2=math.cos(math.rad(althrtab[i]))
cosaz=azmath1/azmath2
azi1=math.deg(math.acos(cosaz))
aziplot=azi1
if shartab[i]<0 then
azitab[i]=(aziplot-180)*-1
else
azitab[i]=aziplot+180
end
end
end--if hemishpere
if hemisphere==2 then
azitab={}
for i=1,total do
aziplot=azi1
azitab[i]=(aziplot-360)*-1
else
azitab[i]=aziplot--+180
end
end
end--if hemishpere
--diplay sun plot
for i = 1,total do
circrad=0.25
circx=across-180+azitab[i]
circy=down-althrtab[i]
cairo_arc(cr,circx,circy,circrad,0,2*math.pi)
cairo_close_path(cr)
cairo_set_source_rgba(cr,0.4,0.4,0.4,1)
cairo_fill (cr)
end
--plot current sun position
circrad=7
circx=across-180+azitab[stime]
circy=down-althrtab[stime]
cairo_set_source_rgba(cr,1,1,0,1)
cairo_fill (cr)
--curerent sun alt and azi
sunalt=althrtab[stime]
sunazi=azitab[stime]
--draw vertical N-S line
cairo_set_line_width (cr, 1)
cairo_set_source_rgba(cr,0.5,0.5,0.5,1)
cairo_move_to (cr, across, down+100)
cairo_line_to (cr, across, down-100)
cairo_stroke (cr)
--draw horizon
cairo_move_to (cr, across-180, down)
cairo_line_to (cr, across+180, down)
cairo_stroke (cr)
cairo_move_to (cr, across-4, down-102)
cairo_show_text (cr, "S")
cairo_move_to (cr, across-4, down+109)
cairo_show_text (cr, "N")
else
cairo_stroke (cr)
end
--############# MOON CACULATIONS AND DISPLAY ###########################################################################################################
--calculate moon data----------------------------------------------------------------
--moon stuff
F = range(93.2721 + 483202 * t - 0.003403 * t* t - t * t * t/3526000);
L2 = range(218.316 + 481268 * t);
Om2 = range(125.045 - 1934.14 * t + 0.002071 * t * t + t * t * t/450000);
M2 = range(134.963 + 477199 * t + 0.008997 * t * t + t * t * t/69700);
cosm2=math.cos(math.rad(M2))
D = range(297.85 + 445267 * t - 0.00163 * t * t + t * t * t/545900);
D2 = 2*D;
cosd2m2=math.cos(math.rad(D2-M2))
cosd2=math.cos(math.rad(D2))
R2 = 1 + (-20954 * cosm2 - 3699 * cosd2m2 - 2956 * cosd2 / 385000);
R3 = (R2 / R1) / 379.168831168831;
sinf=math.sin(math.rad(F))
sinm2f=math.sin(math.rad(M2-F))
sind2f=math.sin(math.rad(D2-F))
Bm = 5.128 * sinf + 0.2806 * sinm2f;
Bm = Bm + 0.2777 * sinm2f + 0.1732 * sind2f;
sinm2=math.sin(math.rad(M2))
sind2m2=math.sin(math.rad(D2-M2))
sind2=math.sin(math.rad(D2))
Lm = 6.289 * sinm2 + 1.274 * sind2m2 + 0.6583 * sind2;
sin2m2=math.sin(math.rad(2*M2))
sin2f=math.sin(math.rad(2*F))
Lm = Lm + 0.2136 * sin2m2 - 0.1851 * sinm1 - 0.1143 * sin2f;
sind22m2=math.sin(math.rad(D2-(2*M2)))
Lm = Lm +0.0588 * sind22m2
sind2m1m2=math.sin(math.rad(D2-M1-M2))
sind2m22=math.sin(math.rad(D2+M2))
Lm = Lm + 0.0572* sind2m1m2 + 0.0533* sind2m22;
Lm = Lm + L2;
tanbm=math.tan(math.rad(Bm))
sinbm=math.sin(math.rad(Bm))
cosbm=math.cos(math.rad(Bm))
sinlm=math.sin(math.rad(Lm))
coslm=math.cos(math.rad(Lm))
Ra2 = math.atan((sinlm * oblcos - tanbm* oblsin));
Dec2 = math.asin(sinbm* oblcos + cosbm*oblsin*sinlm);
sinlam1lm=math.sin(math.rad(Lam1-Lm))
HLm = range(Lam1 + 180 + (180/math.pi) * R3 * cosbm * sinlam1lm);
HBm = R3 * Bm;
--obliquity of ecliptic:
eps = 23.0 + 26.0/60.0 + 21.448/3600.0 - (46.8150*T+ 0.00059*T*T- 0.001813*T*T*T)/3600;
X = cos(Bm)*cos(Lm)
Y = cos(eps)*cos(Bm)*sin(Lm) - sin(eps)*sin(Bm)
Z = sin(eps)*cos(Bm)*sin(Lm) - cos(eps)*sin(Bm)
R = math.sqrt(1.0-Z*Z);
delta = (180/math.pi)*math.atan(Z/R); -- in degrees-- declination
RA = (24/math.pi)*math.atan(Y/(X+R)); -- in hours
delta=math.deg(Dec2)
sdec=delta
althrtab={}
shartab={}
total=1440
for i=0,total do
althrtab[i]=curalt
shartab[i]=sha-360
end
--calculate moonrise and moonset
rise=i
end
set=i
end
end
rise=rise/60
mriseh=rises[1]
mrisem=risems[1]
set=set/60
mseth=sets[1]
msetm=setms[1]
azitab={}
for i=1,total do
aziplot=azi1
else
end
end
end--if hemishpere
azitab={}
for i=1,total do
aziplot=azi1
else
azitab[i]=aziplot
end
end
end--if hemishpere
--diplay moon plot
for i = 1,total do
circrad=0.25
cairo_set_source_rgba(cr,0.7,0.7,0.7,1)
cairo_fill (cr)
end
--plot current moon position
madj=tostring(rangei(sgtime+360))
mtime=madj
circrad=5
circx=across-180+(azitab[tonumber(mtime)])
circy=down-(althrtab[tonumber(mtime)])
cairo_set_source_rgba(cr,1,1,1,1)
cairo_fill (cr)
--curerent moon alt and azi
moonalt=althrtab[tonumber(mtime)]
moonazi=azitab[tonumber(mtime)]
--############# TEXT DISPLAYS ###########################################################################################################
--draws text label
font="Mono"
fontsize=10
cairo_set_font_size (cr, fontsize);
cairo_set_source_rgba (cr, 0.1, 0.1, 0.1, 0.5);
--top left - sun moon alt and azi
tlx=20
tly=20
adj=10
cairo_move_to (cr, tlx, tly)
cairo_show_text (cr, "Positions")
gap=10
add=fontsize+((fontsize/100)*adj)+gap
cairo_move_to (cr, tlx, tly+add)
cairo_show_text (cr, "Soleil")
add=fontsize+((fontsize/100)*adj)+add
cairo_show_text (cr, "Azimut " .. round(sunazi,2) .. "°")
cairo_show_text (cr, "Altitude " .. sunalt .. "°")
gap=10
add=fontsize+((fontsize/100)*adj)+add+gap
cairo_show_text (cr, "Lune")
cairo_show_text (cr, "Azimut " .. round(moonazi,2) .. "°")
cairo_show_text (cr, "Altitude " .. moonalt .. "°")
tlx=180
tly=20
adj=10
cairo_show_text (cr, "Heure")
gap=10
cairo_show_text (cr, "Heure Locale: " .. H .. ":" .. Min)
cairo_show_text (cr, "Heure Sidérale: " .. GMST24H .. ":" .. GMST24M )
cairo_show_text (cr, "Heure Solaire : " .. LST24H .. ":" .. LST24M)
cairo_stroke (cr)
end-- end if updates =
end--end main function
