Utiliser Mageia
Dernière mise à jour : 01/06/2014 à 10h35
Table des matières EN COURS D'ELABORATION
Annexe du tuto http://www.mageialinux-online.org/wiki/conky
Voila si vous avez des problèmes venez ici icivous y trouverez de l'aide.
- imagemagick
-python3
-python3-beautifulsoup4
-python-notify
-libnotify4
-curl
( à finir)
Conky principal
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
double_buffer yes
minimum_size 150
maximum_width 140
text_buffer_size 1024
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
default_color 000000
default_outline_color white
alignment top_right
gap_x 0
gap_y 30
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
color 000000
TEXT
CPU 1
${cpu cpu0}% ${freq_g 1} GHz
CPU 2
${cpu cpu1}% ${freq_g 2}GHz
CPU3
${cpu cpu2}% ${freq_g 3}GHz
CPU4
${cpu cpu3}% ${freq_g 4}GHz
RAM
$memperc%
PARTITION
/racine
/home
RESEAU
Down
Up
TEMPERATURES
Carte: ${hwmon 0 temp 1} °C
Allumé depuis :
$uptime
son lua
BARGRAPH WIDGET
v2.1 by wlourf (07 Jan. 2011)
lua_draw_hook_pre main_rings
Parameters are :
3 parameters are mandatory
Optional parameters:
-- MA 02110-1301, USA.
require 'cairo'
function conky_main_bars()
local bars_settings={
{ --[ Graph for CPU1 ]--
name="cpu",
arg="cpu0",
max=100,
alarm=50,
alarm_colour={0xFF0000,0.72},
bg_colour={0xFFFFFF,0.15},
fg_colour={0x48a3fd,0.55},
x=0,y=40,
blocks=50,
space=1,
height=2,width=6,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=60,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU2 ]--
name="cpu",
arg="cpu1",
max=100,
alarm=50,
x=0,y=112,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=132,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU3 ]--
name="cpu",
arg="cpu2",
max=100,
alarm=50,
x=0,y=184,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=204,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU4 ]--
name="cpu",
arg="cpu3",
max=100,
alarm=50,
x=0,y=256,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=274,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for Memory ]--
name="memperc",
arg="",
max=100,
alarm=50,
x=0,y=330,
blocks=49,
space=1,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for Root ]--
name="fs_used_perc",
arg="/",
max=100,
alarm=50,
x=0,y=401,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Home ]--
arg="/home",
max=100,
alarm=50,
x=0,y=455,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Down ]--
name="downspeedf",
arg="wlp2s0",
max=500,
alarm=50,
x=0,y=528,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Up ]--
name="upspeedf",
arg="wlp2s0",
max=500,
alarm=50,
x=0,y=583,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="hwmon",
arg="0 temp 1",
max=100,
alarm=50,
x=0,y=634,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
name="execi",
max=100,
alarm=50,
x=0,y=654,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
cr = cairo_create(cs)
end
end
cairo_destroy(cr)
cairo_surface_destroy(cs)
cr=nil
end
cairo_save(cr)
--check values
return
end
if t.max==nil then
return
end
--set default values
t.angle = t.angle*math.pi/180
--line cap style
local cap="b"
if v==t.cap then cap=v end
end
local delta=0
elseif cap=="r" then
cap = CAIRO_LINE_CAP_ROUND
elseif cap=="b" then
cap = CAIRO_LINE_CAP_BUTT
end
--end line cap style
--colours
if t.mid_colour ~= nil then
for i=1, #t.mid_colour do
if #t.mid_colour[i]~=3 then
end
end
end
if t.led_effect~=nil then
end
if t.skew_x == nil then
t.skew_x=0
else
end
if t.skew_y == nil then
t.skew_y=0
else
end
--end of default values
end
if t.mid_colour ~=nil then
end
end
return pat
end
end
end
return pat
end
return pat
end
if mode==3 then
else
end
return pat
end
local pat
if not t.smooth then
if t.led_effect=="e" then
elseif t.led_effect=="a" then
elseif t.led_effect=="r" then
else
end
else
if bg then
else
end
end
return pat
end
local y1=-t.height*pct/100
local y2,y3
y1 = -t.height*t.alarm/100
y2 = -t.height*pct/100
if t.smooth then y1=y2 end
end
if t.angle_bar==0 then
--block for fg value
cairo_set_source(cr,pat)
cairo_fill(cr)
cairo_pattern_destroy(pat)
-- block for alarm value
cairo_fill(cr)
y3=y2
else
y2,y3=y1,y1
end
-- block for bg value
cairo_fill(cr)
end
end --end single bar
for pt = 1,t.blocks do
--set block y
local light_on=false
--set colors
local col_alp = t.bg_colour
local col_led = t.bg_led
if pct>=(pcb*(pt-1)) then
light_on = true
col_alp = t.fg_colour
col_led = t.fg_led
col_alp = t.alarm_colour
col_led = t.alarm_led
end
end
end
--set colors
local pat
else
end
else
col_alp,col_led,3)
else
end
end
else
if light_on then
else
end
else
end
end
cairo_set_source (cr, pat)
--draw a block
cairo_move_to(cr,0,y1)
cairo_line_to(cr,t.width,y1)
else
cairo_arc( cr,0,0,
-t.angle_bar -math.pi/2 ,
t.angle_bar -math.pi/2)
end
cairo_stroke(cr)
end
end
local value = 0
if t.name ~="" then
--conky bug?
--end
else
value = tonumber(t.arg)
end
pct = 100*value/t.max
pcb = 100/t.blocks
cairo_set_line_cap (cr, cap)
cairo_translate(cr,t.x,t.y)
cairo_rotate(cr,t.angle)
tolua.takeownership(matrix0)
cairo_transform(cr,matrix0)
draw_single_bar()
else
draw_multi_bar()
end
--dot for reminder
cairo_fill(cr)
else
cairo_fill(cr)
end]]
local pat2
tolua.takeownership(matrix1)
if t.reflection=="t" then
elseif t.reflection=="r" then
elseif t.reflection=="l" then
else --bottom
end
end
cairo_transform(cr,matrix1)
draw_single_bar()
else
draw_multi_bar()
end
cairo_set_line_width(cr,0.01)
end
cairo_clip_preserve(cr)
cairo_stroke(cr)
cairo_mask(cr,pat2)
cairo_pattern_destroy(pat2)
end --reflection
pct,pcb=nil
end --setup_bar_graph()
--start here !
setup_bar_graph()
cairo_restore(cr)
end
2_33620
Cronographe
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 310 310
maximum_width 310
text_buffer_size 2048
draw_shades no
draw_outline no
draw_borders no
alignment top_left
gap_x 40
gap_y 40
no_buffers yes
uppercase no
cpu_avg_samples 2
lua_draw_hook_post main
TEXT
son lua :
use in conkyrc
TEXT
require 'cairo'
--Position et taille horloge
local init={
nb=7*24,
formule='jour',
police="URW Chancery L",
taille=11,
text_color=0x000000,
text_alpha=0.4,
text_color_current=0x000000,
text_alpha_current=1,
point_color=0x000000,
point_alpha=0.4,
point_color_current=0x000000,
point_alpha_current=1,
hand_color=0xffff00,
hand_alpha=1,
center_x=158,
center_y=95,
text_radius=30,
point_radius=20,
hand_gap=0,
hand_larg=1.5,
hand_length=18,
point_ray=0.5
{text={""},
nb="",
formule='jour_num',
taille=10,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=100,
center_y=159,
text_radius=35,
point_radius=28,
hand_gap=0,
hand_larg=1.5,
hand_length=27,
point_ray=0.5
nb="",
formule='mois',
taille=10,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=215,
center_y=159,
text_radius=35,
point_radius=26,
point_ray=1,
hand_gap=0,
hand_larg=1.5,
hand_length=25
hour_24=true,
nb=12*3600, --12 or 24 *3600
formule='heure',
taille=22,
text_alpha=0.4,
text_color_current=0x1540fc,
point_alpha=0.4,
point_color_current=0x1540fc,
hand_color=0x1540fc,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=145,
point_radius=148,
hand_gap=0,
hand_length=75,
hand_larg=3.5,
point_ray=0
nb=3600,
formule='minute',
taille=12,
text_alpha=0.4,
text_color_current=0xff0000,
point_alpha=0.4,
point_color_current=0xff0000,
hand_color=0xff0000,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=140,
point_radius=130,
point_ray=0.5,
hand_gap=0,
hand_larg=3.5,
hand_length=100
nb=60,
formule='secondes',
taille=9,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=121,
point_radius=112,
point_ray=0.4,
hand_gap=0,
hand_larg=1.5,
hand_length=110,
progressif=true
-- petite montre du bas
hour_24=false,
formule='heure',
taille=10,
text_alpha=0.4,
text_alpha_current=0.4,
point_alpha=0.4,
point_alpha_current=0.4,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=35,
point_radius=28,
hand_gap=0,
hand_length=20,
hand_larg=1.5,
point_ray=0
nb=3600,
formule='minute',
taille=9,
text_color=0xa8a8a8,
text_alpha=0,
text_alpha_current=0,
point_alpha=0,
point_alpha_current=0,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=25,
point_radius=20,
point_ray=0,
hand_gap=0,
hand_larg=1.5,
hand_length=28
nb=60,
formule='secondes',
taille=9,
text_alpha=0,
point_alpha=0,
hand_color=0x000000,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=30,
point_radius=20,
point_ray=0.5,
hand_gap=0,
hand_larg=0,
hand_length=30,
progressif=true
function conky_main()
local cr = cairo_create(cs)
tolua.takeownership(extents)
local h, min, sec=time()
for i in pairs(init) do
end
end
cairo_destroy(cr)
cr=nil
collectgarbage()
end
value.progressif=false
end
else
end
end
local pos
-- Section Horloge
if value.decalage~=nil then
h=h+tonumber(value.decalage)
end
local text
nb=value.nb/3600
pos=heure(h, min, sec)
for i=1, nb do
local j=i-1
if value.hour_24==true then
text=value.text[i]
else
text=value.text[i+12]
end
else
text=value.text[i]
end
end
pos=minute(min, sec)
for i=1, nb do
local j=i-1
local text=value.text[i]
end
pos=sec
for i=1, nb do
local j=i-1
end
-- Section date
value.nb, pos=month()
for i=1, nb do
local j=i-1
end
value.nb=nb_jour*24
nb=nb_jour
pos=day(jour-1)
for i=1, nb_jour do
if math.mod(i, 2) == 0 then
text=string.format("%02d",i)
else
text=""
end
local j=i-1
end
for i=1, nb do
local j=i-1
end
else
for i=1, nb do
local j=i-1
if tonumber(text)==pos then
else
end
end
end
end
function date()
local nb_jour
if mois==12 then
nb_jour=31
else
end
end
function day(jour)
return hjour
end
function month()
end
function time()
return h, min, sec
end
function heure(h, min, sec)
return hs
end
function minute(min, sec)
local m=(min*60)+sec
return m
end
end
local width=extents.width
local height=extents.height
cairo_show_text (cr, text)
cairo_stroke (cr)
end
cairo_stroke (cr)
end
cairo_stroke (cr)
end
3_41597
Ephéméride
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 380
maximum_width 380
draw_shades no
draw_outline no
draw_borders no
alignment top_left
gap_x 400
gap_y 40
no_buffers yes
uppercase no
cpu_avg_samples 2
TEXT
4_245fa
Nasa image du jour
background no
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 300 180
maximum_width 300
draw_shades no
draw_outline no
draw_borders no
default_color ffffff
alignment top_left
gap_x 50
gap_y 750
no_buffers yes
uppercase no
cpu_avg_samples 2
# 1h=60m=3600s #
# 1j=24h=1440m=86400s #
default_color ececec
color2 585858
color1 606060
TEXT
#!/bin/bash
#ragamatrix'script modified#
IMG="/tmp/image_nasa.jpg"
IMGPNG="/tmp/image_nasa.png"
convert $IMGPNG \
\( +clone -alpha extract \
son lua
require 'cairo'
home = os.getenv ('HOME')
--Fonction d'affichage
x=x+(w/2)
y=y+(h/2)
local cr = cairo_create (cs)
cairo_translate (cr, x, y)
if arc then
cairo_rotate (cr, arc)
end
cairo_paint (cr)
cairo_destroy(cr)
cairo_surface_destroy (img)
end
return ""
end
5_9f621
Météo 6 jours
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
#own_window_color 000000
#own_window_argb_value 0
double_buffer yes
minimum_size 470
maximum_width 470
draw_shades no
draw_outline no
draw_borders no
default_color white
alignment top_left
gap_x 565
gap_y 150
no_buffers yes
uppercase no
cpu_avg_samples 2
#use_spacer yes
uppercase no
color0 6495ee
template3 ${lua Lune_\1}
TEXT
# Répertoire des scripts
# Répertoire de sauvegarde
#Répertoire temporaire
TempShell=/tmp
periode=7
matinée=non
am=non
soiree=non
nuit=non
#Prévision à 8 Heures
Prev8heures=non
nbFoisHuit=1
Palier=20
update=60
notify=non
6_6fafd
Thermo
# Settings
max_specials 10000
max_user_text 1500000
background yes
use_xft yes
#xftfont Sans:size=12
#xftalpha 1
font Arial Rounded MT:size=7
total_run_times 0
own_window yes
double_buffer yes
minimum_size 500 325
maximum_width 500
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders yes
default_color white
default_shade_color black
alignment top_left
gap_x 550
gap_y 570
no_buffers yes
uppercase no
cpu_avg_samples 2
color1 86acad #darker blue
color2 b1c9c9 #lighter blue
text_buffer_size 100000
top_name_width 10
update_interval 1
TEXT
${lua conky_weather}
son lua :
version 4
-cleaned up a bit
-temp scale changing
-added forecast display
-added wind speed guage
-added hi lo thermometers
secs=300--set update interval
require 'cairo'
local result = { }
local from = 1
while delim_from do
from = delim_to + 1
end
return result
end
function conky_weather()
if updates>5 then
local timer=(updates %secs)+1
local data1=f:read("*a")
f:close()
local data={}
for i,v in pairs(data2) do
table.insert(data,data2[i])
end
end
--current
--forecast
local fdata1=f:read("*a")
f:close()
local fdata2={}
for i,v in pairs(fdata) do
table.insert(fdata2,fdata[i])
end
end
--day2
--day3
local start=68
--day4
local start=start+29
--day5
--day6
--day7
--day8
--day9
--day10
end--timer section
end-- if updates>5
cairo_destroy(cr)
cr=nil
return ""
end-- end main function
--eg day1.day
day=forecast day and date
con=conditions summary
hih=high temp
low=low temp
sri=sunrise
sst=sunset
mri=moon rise
mst=moon set
uvi=ultraviolet index
hum=humidity
ppt=chance of precipitation
snw=chance of snow
cld=cloud cover
mph=moon phase
wmh=wind speed in mph
wkm=wind speed in km/h
wkt=wind speed in knots
wdg=wind direction in degrees
wdi=wind direction in nesw
--setup text type and color
local font="Mono"
local fsize=10
local xpos=430
local ypos=30--first line
local gap1=fsize+2
--TEST
--ypos=490--first line
--xpos=200
--gap1=fsize+2
--gap=0
--wind direction compass
--windspeed dial
wspeed_dial(now.wsp,380,220)
--pressure barometer
--humidity bar
--current conditions display
end--display
--0 to 60 mph
--draw circle
cairo_set_line_width (cr,1)
local router=110
cairo_fill (cr)
cairo_stroke (cr)
--mph scale
local rout1=80
local rin1=rout1-10
for i=0,60 do
cairo_set_line_width (cr,3)
else
rin=rin1+5--set other lines
end--if i==
ppx=0+rout1*(math.sin(arc))
ppy=0-rout1*(math.cos(arc))
pix=0+rin*(math.sin(arc))
piy=0-rin*(math.cos(arc))
cairo_stroke (cr)
end--for i=
--mph reading
mph={0,10,20,30,40,50,60}
local rin=rin1-2
for i=1,#mph do
ppx=0+rin*(math.sin(arc))
ppy=0-rin*(math.cos(arc))
text=mph[i]
width=extents.width
cairo_show_text (cr,text)
cairo_stroke (cr)
end--for i= print inches
--kmh lines and numbers
--60kmh=96.5606
local m1=300/96.5606
local rout2=60
local rin2=rout2-5
local num=95
--print lines---------------
for i=0,num do
else
rin=rin2
end--if i=
ppx=0+rout2*(math.sin(arc))
ppy=0-rout2*(math.cos(arc))
cairo_stroke (cr)
end--for i --line drawing
--kmh reading
local rout=rin2-18
for i=1,#kmh do
ppx=0+rout*(math.sin(arc))
ppy=0-rout*(math.cos(arc))
text=kmh[i]
width=extents.width
cairo_stroke (cr)
end--kmh lines and numbers
--knots
--60kmh=52.1386
local m1=300/52.1386
local rout3=90
local rin3=rout3-5
local num=50
for i=0,num do
else
rout=rout3
end--if i=
pix=0+rin3*(math.sin(arc))
piy=0-rin3*(math.cos(arc))
cairo_stroke (cr)
--kmh reading
knot={0,10,20,30,40,50}
local rout=rin3+15
for i=1,#kmh do
text=knot[i]
width=extents.width
cairo_stroke (cr)
end
--scale labels
local text="mph"
cairo_stroke (cr)
local text="kmh"
cairo_stroke (cr)
local text="Noeuds"
cairo_stroke (cr)
local text="Mesures Vent"
cairo_stroke (cr)
--pointer
if ws==nil then ws=0 end
local wspd=ws
local m1=300/60
local m2=wspd*m1
local rout1=rout3
local rin3=7
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
end--wspeed dial function
local inum=string.len(text)
local degrads=(math.pi/180)
for i=1,inum do
cairo_rotate (cr, interval)
cairo_stroke (cr)
cairo_rotate (cr, -interval)
end
end--circlewriting
function humidity(x,y,hval1)
hval=hval1*1.5
yt=y-1
rh=200
rw=30
cairo_set_source (cr, pat);
cairo_fill (cr);
cairo_pattern_destroy (pat);
for i=1,11 do
lwid=-1
cairo_rel_line_to (cr,lwid,0)
cairo_stroke(cr)
end
hh=5
hw1=19
hw2=hw1+10
if hval==nil then hval=0 end
tx,ty=x+hw1,(y+150)-(hval+hh)
ix,iy=x+hw2,(y+150)-hval
bx,by=x+hw1,(y+150)-(hval-hh)
cairo_move_to (cr,tx,ty)
cairo_line_to (cr,ix,iy)
cairo_line_to (cr,bx,by)
cairo_line_to (cr,tx,ty)
cairo_fill (cr)
font="URW Chancery L"
fsize=16
cairo_stroke (cr)
label="Taux d'humidité"
cairo_move_to (cr,x+12,y+150)
cairo_show_text (cr,label)
cairo_stroke (cr)
end--humidity
cairo_move_to (cr,xpos,ypos)
cairo_stroke (cr)
end--function txt
function barometer(pr,px,py)
local router=110
cairo_fill (cr)
cairo_stroke (cr)
local rout1=75
local rin1=rout1-10
for i=0,40 do
rout=rout1-7
rout=rout1
else
rout=rout1-5
end
pix=0+rin1*(math.sin(arc))
piy=0-rin1*(math.cos(arc))
cairo_stroke (cr)
end
--inches reading
inch={28,29,30,31}
local rout=rout1+2
for i=1,4 do
text=inch[i]
width=extents.width
cairo_stroke (cr)
end
--942 to 1056
--27.5=931.25
--31.5=1066.70
local m1=300/135.45
local rout2=60
local rin2=rout2-5
local num=60
for i=0,num do
rin=rin2-5
else
rin=rin2
end
cairo_stroke (cr)
end
--millibars reading
local rout=rin2-18
for i=1,7 do
text=inch[i]
width=extents.width
cairo_stroke (cr)
end
--scale labels
local text="inches hg"
cairo_stroke (cr)
local text="millibars"
cairo_stroke (cr)
local text="Pression"
cairo_stroke (cr)
--pointer
if pr==nil then pr=27.5 end
local pres=pr-27.5
local m1=300/4
local m2=pres*m1
local rout1=rout1
local rin3=7
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
cairo_fill (cr)
----text
local horiz=px
local verti=py
local radi=87
local text="Tempete"
local font="URW Chancery L"
local fsize=16
local start=240
local text="Pluie"
local start=300
local text="Variable"
local start=340
local text="Beau"
local start=395
local text="Tres Sec"
local start=435
end--barometer
cairo_fill (cr)
cairo_stroke (cr)
for i=1,36 do
arc=(math.pi/180)*(i*10)
wpx=0+rout*(math.sin(arc))
wpy=0-rout*(math.cos(arc))
wix=0+rin*(math.sin(arc))
wiy=0-rin*(math.cos(arc))
cairo_stroke (cr)
end
--print directions
local fsize=14
for i=1,8 do
wdx=0+rdir*(math.sin(arc))
wdy=0-rdir*(math.cos(arc))
text=dirs[i]
width=extents.width
cairo_stroke (cr)
end
--indicator
if wdeg==nil then wdeg=0 end
cairo_fill (cr)
local sprm=nprm
cairo_fill (cr)
cairo_fill (cr)
cairo_stroke (cr)
local text="Rose des Vents"
cairo_stroke (cr)
end--compass
end
--top left mid circle
local xtl=x+r
local ytl=y+r
--top right mid circle
local xtr=(x+r)+((w)-(2*r))
local ytr=y+r
--bottom right mid circle
local xbr=(x+r)+((w)-(2*r))
local ybr=(y+r)+((h)-(2*r))
local xbl=(x+r)
local ybl=(y+r)+((h)-(2*r))
cairo_move_to (cr,xtl,ytl-r)
cairo_line_to (cr,xtr,ytr-r)
cairo_line_to (cr,xbr+r,ybr)
cairo_line_to (cr,xbl,ybl+r)
cairo_line_to (cr,xtl-r,ytl)
cairo_close_path(cr)
cairo_fill (cr)
cairo_destroy(cr)
return ""
end
7_b9fa2
