Utiliser Mageia
Dernière mise à jour : 01/06/2014 à 09h38
Table des matières EN COURS D'ELABORATION
Annexe du tuto <a href="" target="_blank">http://www.mageialinux-online.org/wiki/conky</a>
- imagemagick
-python3
-python3-beautifulsoup4
-python-notify
-libnotify4
-curl
( à finir)
Conky principal
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
double_buffer yes
minimum_size 150
maximum_width 140
text_buffer_size 1024
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
default_color 000000
default_outline_color white
alignment top_right
gap_x 0
gap_y 30
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
color 000000
TEXT
CPU 1
${cpu cpu0}% ${freq_g 1} GHz
CPU 2
${cpu cpu1}% ${freq_g 2}GHz
CPU3
${cpu cpu2}% ${freq_g 3}GHz
CPU4
${cpu cpu3}% ${freq_g 4}GHz
RAM
$memperc%
PARTITION
/racine
/home
RESEAU
Down
Up
TEMPERATURES
Carte: ${hwmon 0 temp 1} °C
Allumé depuis :
$uptime
son lua
BARGRAPH WIDGET
v2.1 by wlourf (07 Jan. 2011)
lua_draw_hook_pre main_rings
Parameters are :
3 parameters are mandatory
Optional parameters:
-- MA 02110-1301, USA.
require 'cairo'
function conky_main_bars()
local bars_settings={
{ --[ Graph for CPU1 ]--
name="cpu",
arg="cpu0",
max=100,
alarm=50,
alarm_colour={0xFF0000,0.72},
bg_colour={0xFFFFFF,0.15},
fg_colour={0x48a3fd,0.55},
x=0,y=40,
blocks=50,
space=1,
height=2,width=6,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=60,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU2 ]--
name="cpu",
arg="cpu1",
max=100,
alarm=50,
x=0,y=112,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=132,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU3 ]--
name="cpu",
arg="cpu2",
max=100,
alarm=50,
x=0,y=184,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=204,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for CPU4 ]--
name="cpu",
arg="cpu3",
max=100,
alarm=50,
x=0,y=256,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="exec",
max=100,
alarm=50,
x=0,y=274,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for Memory ]--
name="memperc",
arg="",
max=100,
alarm=50,
x=0,y=330,
blocks=49,
space=1,
height=2,width=6,
angle=90,
smooth=true
{ --[ Graph for Root ]--
name="fs_used_perc",
arg="/",
max=100,
alarm=50,
x=0,y=401,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Home ]--
arg="/home",
max=100,
alarm=50,
x=0,y=455,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Down ]--
name="downspeedf",
arg="wlp2s0",
max=500,
alarm=50,
x=0,y=528,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
{ --[ Graph for Up ]--
name="upspeedf",
arg="wlp2s0",
max=500,
alarm=50,
x=0,y=583,
blocks=50,
space=1,
height=2,width=5,
angle=90,
smooth=true
name="hwmon",
arg="0 temp 1",
max=100,
alarm=50,
x=0,y=634,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
name="execi",
max=100,
alarm=50,
x=0,y=654,
blocks=74,
space=0,
height=2,width=6,
angle=90,
smooth=true
cr = cairo_create(cs)
end
end
cairo_destroy(cr)
cairo_surface_destroy(cs)
cr=nil
end
cairo_save(cr)
--check values
return
end
if t.max==nil then
return
end
--set default values
t.angle = t.angle*math.pi/180
--line cap style
local cap="b"
if v==t.cap then cap=v end
end
local delta=0
elseif cap=="r" then
cap = CAIRO_LINE_CAP_ROUND
elseif cap=="b" then
cap = CAIRO_LINE_CAP_BUTT
end
--end line cap style
--colours
if t.mid_colour ~= nil then
for i=1, #t.mid_colour do
if #t.mid_colour[i]~=3 then
end
end
end
if t.led_effect~=nil then
end
if t.skew_x == nil then
t.skew_x=0
else
end
if t.skew_y == nil then
t.skew_y=0
else
end
--end of default values
end
if t.mid_colour ~=nil then
end
end
return pat
end
end
end
return pat
end
return pat
end
if mode==3 then
else
end
return pat
end
local pat
if not t.smooth then
if t.led_effect=="e" then
elseif t.led_effect=="a" then
elseif t.led_effect=="r" then
else
end
else
if bg then
else
end
end
return pat
end
local y1=-t.height*pct/100
local y2,y3
y1 = -t.height*t.alarm/100
y2 = -t.height*pct/100
if t.smooth then y1=y2 end
end
if t.angle_bar==0 then
--block for fg value
cairo_set_source(cr,pat)
cairo_fill(cr)
cairo_pattern_destroy(pat)
-- block for alarm value
cairo_fill(cr)
y3=y2
else
y2,y3=y1,y1
end
-- block for bg value
cairo_fill(cr)
end
end --end single bar
for pt = 1,t.blocks do
--set block y
local light_on=false
--set colors
local col_alp = t.bg_colour
local col_led = t.bg_led
if pct>=(pcb*(pt-1)) then
light_on = true
col_alp = t.fg_colour
col_led = t.fg_led
col_alp = t.alarm_colour
col_led = t.alarm_led
end
end
end
--set colors
local pat
else
end
else
col_alp,col_led,3)
else
end
end
else
if light_on then
else
end
else
end
end
cairo_set_source (cr, pat)
--draw a block
cairo_move_to(cr,0,y1)
cairo_line_to(cr,t.width,y1)
else
cairo_arc( cr,0,0,
-t.angle_bar -math.pi/2 ,
t.angle_bar -math.pi/2)
end
cairo_stroke(cr)
end
end
local value = 0
if t.name ~="" then
--conky bug?
--end
else
value = tonumber(t.arg)
end
pct = 100*value/t.max
pcb = 100/t.blocks
cairo_set_line_cap (cr, cap)
cairo_translate(cr,t.x,t.y)
cairo_rotate(cr,t.angle)
tolua.takeownership(matrix0)
cairo_transform(cr,matrix0)
draw_single_bar()
else
draw_multi_bar()
end
--dot for reminder
cairo_fill(cr)
else
cairo_fill(cr)
end]]
local pat2
tolua.takeownership(matrix1)
if t.reflection=="t" then
elseif t.reflection=="r" then
elseif t.reflection=="l" then
else --bottom
end
end
cairo_transform(cr,matrix1)
draw_single_bar()
else
draw_multi_bar()
end
cairo_set_line_width(cr,0.01)
end
cairo_clip_preserve(cr)
cairo_stroke(cr)
cairo_mask(cr,pat2)
cairo_pattern_destroy(pat2)
end --reflection
pct,pcb=nil
end --setup_bar_graph()
--start here !
setup_bar_graph()
cairo_restore(cr)
end
2_33620
Cronographe
background yes
use_xft yes
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 310 310
maximum_width 310
text_buffer_size 2048
draw_shades no
draw_outline no
draw_borders no
alignment top_left
gap_x 40
gap_y 40
no_buffers yes
uppercase no
cpu_avg_samples 2
lua_draw_hook_post main
TEXT
son lua :
use in conkyrc
TEXT
require 'cairo'
--Position et taille horloge
local init={
nb=7*24,
formule='jour',
police="URW Chancery L",
taille=11,
text_color=0x000000,
text_alpha=0.4,
text_color_current=0x000000,
text_alpha_current=1,
point_color=0x000000,
point_alpha=0.4,
point_color_current=0x000000,
point_alpha_current=1,
hand_color=0xffff00,
hand_alpha=1,
center_x=158,
center_y=95,
text_radius=30,
point_radius=20,
hand_gap=0,
hand_larg=1.5,
hand_length=18,
point_ray=0.5
{text={""},
nb="",
formule='jour_num',
taille=10,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=100,
center_y=159,
text_radius=35,
point_radius=28,
hand_gap=0,
hand_larg=1.5,
hand_length=27,
point_ray=0.5
nb="",
formule='mois',
taille=10,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=215,
center_y=159,
text_radius=35,
point_radius=26,
point_ray=1,
hand_gap=0,
hand_larg=1.5,
hand_length=25
hour_24=true,
nb=12*3600, --12 or 24 *3600
formule='heure',
taille=22,
text_alpha=0.4,
text_color_current=0x1540fc,
point_alpha=0.4,
point_color_current=0x1540fc,
hand_color=0x1540fc,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=145,
point_radius=148,
hand_gap=0,
hand_length=75,
hand_larg=3.5,
point_ray=0
nb=3600,
formule='minute',
taille=12,
text_alpha=0.4,
text_color_current=0xff0000,
point_alpha=0.4,
point_color_current=0xff0000,
hand_color=0xff0000,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=140,
point_radius=130,
point_ray=0.5,
hand_gap=0,
hand_larg=3.5,
hand_length=100
nb=60,
formule='secondes',
taille=9,
text_alpha=0.4,
point_alpha=0.4,
hand_alpha=1,
center_x=158,
center_y=159,
text_radius=121,
point_radius=112,
point_ray=0.4,
hand_gap=0,
hand_larg=1.5,
hand_length=110,
progressif=true
-- petite montre du bas
hour_24=false,
formule='heure',
taille=10,
text_alpha=0.4,
text_alpha_current=0.4,
point_alpha=0.4,
point_alpha_current=0.4,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=35,
point_radius=28,
hand_gap=0,
hand_length=20,
hand_larg=1.5,
point_ray=0
nb=3600,
formule='minute',
taille=9,
text_color=0xa8a8a8,
text_alpha=0,
text_alpha_current=0,
point_alpha=0,
point_alpha_current=0,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=25,
point_radius=20,
point_ray=0,
hand_gap=0,
hand_larg=1.5,
hand_length=28
nb=60,
formule='secondes',
taille=9,
text_alpha=0,
point_alpha=0,
hand_color=0x000000,
hand_alpha=1,
center_x=158,
center_y=230,
text_radius=30,
point_radius=20,
point_ray=0.5,
hand_gap=0,
hand_larg=0,
hand_length=30,
progressif=true
function conky_main()
local cr = cairo_create(cs)
tolua.takeownership(extents)
local h, min, sec=time()
for i in pairs(init) do
end
end
cairo_destroy(cr)
cr=nil
collectgarbage()
end
value.progressif=false
end
else
end
end
local pos
-- Section Horloge
if value.decalage~=nil then
h=h+tonumber(value.decalage)
end
local text
nb=value.nb/3600
pos=heure(h, min, sec)
for i=1, nb do
local j=i-1
if value.hour_24==true then
text=value.text[i]
else
text=value.text[i+12]
end
else
text=value.text[i]
end
end
pos=minute(min, sec)
for i=1, nb do
local j=i-1
local text=value.text[i]
end
pos=sec
for i=1, nb do
local j=i-1
end
-- Section date
value.nb, pos=month()
for i=1, nb do
local j=i-1
end
value.nb=nb_jour*24
nb=nb_jour
pos=day(jour-1)
for i=1, nb_jour do
if math.mod(i, 2) == 0 then
text=string.format("%02d",i)
else
text=""
end
local j=i-1
end
for i=1, nb do
local j=i-1
end
else
for i=1, nb do
local j=i-1
if tonumber(text)==pos then
else
end
end
end
end
function date()
local nb_jour
if mois==12 then
nb_jour=31
else
end
end
function day(jour)
return hjour
end
function month()
end
function time()
return h, min, sec
end
function heure(h, min, sec)
return hs
end
function minute(min, sec)
local m=(min*60)+sec
return m
end
end
local width=extents.width
local height=extents.height
cairo_show_text (cr, text)
cairo_stroke (cr)
end
cairo_stroke (cr)
end
cairo_stroke (cr)
end
3_41597
